Old February 6th, 2014, 07:24 AM   #1
agentbad
agentbad's Avatar
Can you adjust preload without the kawi tool?
So I got a 300r shock recently to replace my pregen shock but it didn't come with the tool to adjust the preload. I've read of people just using a screw driver and hammer to gently hit the adjuster into the level you want but that seems a bit excessive.
Old February 6th, 2014, 07:27 AM   #2
Removing the wheel gives you much more room to work.
Old February 6th, 2014, 07:38 AM   #3
agentbad
agentbad's Avatar
Perfect thanks a bunch.
Old February 6th, 2014, 08:13 AM   #4
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
You'll also have a much easier time of it if you unload the rear suspension first.
Either put a jack under the rear shock linkage and get the back wheel off the ground, or hoist the back of the bike via the rear subframe/pegs/whatever.
Old February 6th, 2014, 08:18 AM   #5
Bob2010
Bob2010's Avatar
I was able to use the supplied tool to turn the setting once.
The next setting , I have either have no leverage or no clearance to move it again
It would be easier with the tire off I suppose but on the fly changes is what I was trying to do
2010 Red Ninja 250
2009 Black Ninja 250
Old February 6th, 2014, 08:27 AM   #6
old3
It is easier to just pop the shock out of the bike.
old3 is offline   Reply With Quote
Old February 6th, 2014, 09:52 AM   #7
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Invest in a spanner wrench
Old February 6th, 2014, 10:47 AM   #8
I had the same problem, try moving to the other side of the bike or get an extra person to help you push or pull. You can adjust it to all settings with the wheel/tire on the bike. Powahhhhh through it!
Old February 6th, 2014, 02:21 PM   #9
Bob2010
Bob2010's Avatar
yah I guess that could sound like I was being wimpy with the wrench but unless I was doing it wrong , I didn't see any room to allow it to move far enough to the next notch
I'll check it out again this spring when I bring the bikes home Maybe I was doing it wrong lol
2010 Red Ninja 250
Old February 6th, 2014, 04:11 PM   #10
ally99
Ninja chick
ally99's Avatar
Motorcycle(s): '13 Ninja 300
MOTM - Dec '13, Feb '15
YESS! @alex.s taught me you can use a flat head screwdriver (the longer the better) and a hammer and adjust the preload!
Postwhores are COOL! ~Allyson
Old February 6th, 2014, 05:49 PM   #11
agentbad
agentbad's Avatar
So just angle it between the teeth of the adjuster and hammer in the desired direction?
Old February 7th, 2014, 08:41 AM   #12
Pretty much
Old February 7th, 2014, 08:42 AM   #13
It's not gentle though. You gotta smash it pretty hard
Old February 7th, 2014, 09:15 AM   #14
Rogue
Hooligan
Rogue's Avatar
Motorcycle(s): 2013 Ninja EX300
+1 Not only do they make the job way easier, but they're not all that expensive.
Qui patiens est, teres. Teres est, ieiunare. | Twitter: @Rogue_300
Rogue is offline   Reply With Quote
Old September 2nd, 2014, 09:48 PM   #15
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
I read the manual. Perhaps I missed it. But how do you know what setting you're supposed to set it to? For regular street riding, what do you guys set it to? I think the 2nd notch (see pic) is the default according to the manual???
Should we set the preload based on total weight of rider & gear? If so, is there a guideline for settings based on weight? Or do we set preload based on the type of riding we intend to do? Does one preload setting work better for aggressive (street) riding vs casual/cruising street riding?
Old September 3rd, 2014, 07:45 AM   #16
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
http://www.ex-500.com/wiki/index.php...ension_Preload has a ton of info explaining how preload works and how to set it for proper sag.
Contrary to popular belief, preload has no effect on how much weight a spring can support (the spring's rate determines that). Changing preload changes the range in which the spring operates. Increasing preload to compensate for extra weight makes it feel stiffer (less squishy) because the spring compresses less when you hit a bump, but that's only because you've already compressed (pre-loaded) the spring some beforehand. However, the spring will compress down to the same total length over the same bump (because the spring rate and the force are the same) regardless of how much preload you have on the spring.
More sag allows for more suspension movement over bumps, but the extra movement will make it feel more squishy. On normal commuter duty, you'll probably want more sag. At the track, you may want less to get a tighter feel as opposed to worrying about comfort and huge potholes.
Old September 3rd, 2014, 08:23 AM   #17
Flying
You will need to experiment. Jack the preload up to 5 and reduce the setting by 1 until you feel right, then bring it down one more to see if that setting feels better, if not bring it back up to your original number.
There is no magic setting, only general guidelines (loose on street, stiff on track and twisties, so and so inches of sag) and preferences. Suspension becomes a science when you are looking for that perfect sweet spot of firmness and shock absorption.
The stock setting is the lowest, 1. Whoops, this is the 300 tech forum. I don't know, go with your manual.
Old September 3rd, 2014, 08:41 AM   #18
agentbad
agentbad's Avatar
I'm on position 4 right now and the bike stays nice and planted in turns but I may knock it down to 3 because I do a lot of commuting so I kind of need the best of both worlds. Once you switch over to a stiffer shock you can really feel how spongy the front suspension is.
Spark plug removal tool or tool kit landon1 Items Wanted 11 April 1st, 2015 07:03 PM
Rear preload? nikeeric86 Ninjettes At Speed 9 April 18th, 2014 01:47 PM
Setting the Preload sm0kediver 2008 - 2012 Ninja 250R Tech Talk 82 August 26th, 2012 09:31 PM
[webbikeworld.com] - Roadgear Sport Touring Tool Pouch Tool Roll Review Ninjette Newsbot Motorcycling News 0 October 7th, 2009 01:30 PM
