Old May 30th, 2018, 05:00 PM   #1
jcgss77
Its not a 250,its a Ninja
jcgss77's Avatar
Motorcycle(s): '11 CBR250R, '22 CFMOTO 300NK
Carb work...forgot about the gas
Sooooo, I just got a new bike, and the previous owner went and let the air filter disintegrate, which means the air lines in the carbs got clogged with...gunk. So I got it all cleaned out, and I went and forgot about putting some gas into the carbs. I also installed a new fuel filter, and the deal is now bone-dry.
Is there an easy way to run gas through the system, so my battery doesn't go dead from cranking? I don't know how old it is, but it has been pretty good so far, but I don't want to chance it, as I am pretty much broke and when I moved into my new place, I ended up getting rid of a lot of my stuff, which includes many of my tools and gear for working on my bike.
I think I need an eyedropper to get the gas into the filter, but is there a trick to getting some down into the carbs without having to take the whole thing apart again? I am not in a big hurry, since I am still waiting for the new air filter to come in.
jcgss77 is offline   Reply With Quote
Old May 30th, 2018, 06:41 PM   #2
Apply at least 10-in.Hg vacuum to little petcock hose. This opens valve and drip fuel through filter into float bowls.
Old May 30th, 2018, 08:32 PM   #3
Danno is right, except it doesn't take anywhere near that much vaccuum to open the petcock. A tube into your mouth and some moderate sucking will do it.
If it took ten inches, the petcock would close every time you opened the throttle all the way.
Old May 30th, 2018, 09:37 PM   #4
jcgss77
jcgss77's Avatar
Thank you for the replies!
So, just apply a little lung pressure to the carb side of the fuel filter will bring some of it down? Am I hearing you correctly?
Old May 30th, 2018, 09:40 PM   #5
No, a little sucking on the vacuum line to the petcock.
It's made to automatically turn on the flow of gasoline when it sees carb vacuum (engine running), and turn it off when you shut off the engine and the vacuum stops. Sucking a little on the vacuum line will make it think the engine is running and it will open.
Old May 30th, 2018, 09:43 PM   #6
jcgss77
jcgss77's Avatar
Ok. And that should then start the pressure down to the fuel filter, and then it is (hopefully!) smooth sailing?
Old May 30th, 2018, 09:45 PM   #7
Nextbesthing
Nextbesthing's Avatar
Motorcycle(s): 95 ninja 250, 08 KLR 650
Damn you Bernoulli!
Nextbesthing is offline   Reply With Quote
Old May 30th, 2018, 09:45 PM   #8
THusker
Leave the fuel line to the carb in place and apply suction to the port on the Petcock to open the valve.
THusker is offline   Reply With Quote
Old May 31st, 2018, 04:26 PM   #9
VaFish
VaFish's Avatar
MOTM - Jan '16
That just sounds so dirty.
Old June 1st, 2018, 07:16 AM   #10
ducatiman
ducatiman's Avatar
^ but doesn't have to be
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old June 1st, 2018, 09:04 PM   #11
jcgss77
jcgss77's Avatar
Ok, so I went and picked up the new air filter today, and after putting everything back together, I tried the suction on the fuel line deal...and it in no way worked. So either I have a petcock that is going bad, or more likely I was just too worried about getting gas in my mouth, I just opened up the choke and cranked the bike, and as I was watching the new fuel filter, it filled up, then a couple cranks later it fired right up. Ran like a top, and before I could take it for a ride, I got a call where I needed to pick up my kids. So the first ride is going to have to wait, but we are running. Thanks so much everyone!
Old June 2nd, 2018, 06:24 AM   #12
For future reference, there is a fuel inlet fitting on the petcock, and a fuel outlet fitting. There is a third fitting for vacuum on it. That's the one you suck on. Unless the diaphragm in the petcock is ruptured, you can't get gasoline in your mouth from that fitting.
Old June 2nd, 2018, 09:45 PM   #13
Yep, there’s TWO hoses exiting petcock. Bigger hose is fuel line, leave it alone. Smaller one is vacuum line to turn on fuel flow. Hook up a 2-Ft section of vacuum hose and suck on it.
Old June 4th, 2018, 05:44 PM   #14
sarcaz
Motorcycle(s): Ducati Monster, Ninja 250
Or just prime it?
The purpose of the PRI setting on the petcock is to fill up (prime) the carb after it’s bone dry. Set it to PRI for 15 seconds and then set it back to On. This shouldn’t require vacuum to operate.
sarcaz is offline   Reply With Quote
Old June 4th, 2018, 05:49 PM   #15
Pregens don't have a prime position. The have off, on, and reserve. On and reserve both require vacuum to pass fuel.
Old June 4th, 2018, 05:50 PM   #16
sarcaz
Apologies, I assumed it was the same as mine (1986).
Old June 4th, 2018, 07:11 PM   #17
Well, I learned something too then, because I didn't know the very early ones had prime too. My old H2 has a prime position, which is pretty handy since it's kick start only.
Last futzed with by Triple Jim; June 4th, 2018 at 08:16 PM.
Please help! Forgot hose connections to gas tank Animoto 2008 - 2012 Ninja 250R Tech Talk 6 June 15th, 2014 08:54 PM
Carb problem... dies when on the gas jboyd12 2008 - 2012 Ninja 250R Tech Talk 43 April 9th, 2014 03:31 PM
carb work james250ninja 1986 - 2007 Ninja 250R Tech Talk 34 September 19th, 2011 12:45 PM
Gas Tank Removal; Carb Boots aweesner 1986 - 2007 Ninja 250R Tech Talk 1 September 6th, 2011 06:53 AM
Finally doing some carb work HMB-ninja 2008 - 2012 Ninja 250R Tech Talk 6 June 7th, 2011 08:38 PM
