Go Back   ninjette.org > General > !%@*#$%!)@#&!%@ I crashed!
Old September 22nd, 2011, 06:51 AM   #1
TxriderMike
TxriderMike's Avatar
Motorcycle(s): Ninja 250cc Black
My front turning signal
ok I did it... i finally dropped my baby and I'm have written her a formal apology and promised her I would fix her. My front left turning signal light has gotten knocked off. The light is not cracked or anything. It just fell off and the wires are disconnected... how do i reconnect the wires. my fingers are not 2 cm wide so I can't put my fingers inside the light to reconnect the wires. any suggestions? I'm 21 in the military and my budget isn't very big. I also would like to know what is the best oil to use when I change it because I have put 1700 miles on my bike and have yet to change it. I know I am a horrible person, but I have been very busy since I bought the bike and the kawasaki place I bought the bike at want to charge me 220 for a clutch something, and a oil change! I am not stupid so a little direction to get me started would be GREATLY appreciated! THANKS! O my bike is a 2011 black ninjette.
TxriderMike is offline   Reply With Quote
Old September 22nd, 2011, 06:56 AM   #2
TxriderMike
also everyone is telling me my stock tires are terrible. I have been advised to go larger and with a different tread pattern. I am a Behavioral health specialist with little to none motorcycle knowledge other than riding, so please talk dumb to me when explaining anything so I can learn lol. If anyone needs medical advice let me know, but anything on that bike I need HELP lol!
Old September 22nd, 2011, 07:53 AM   #3
U5er
Sorry to hear about it bud. Sounds like you dropped at a stand still yeah ? You need to remove the fairing (the side panel) to reinstall the light. Here is a link with instructions:
http://www.ninjette.org/forums/showthread.php?t=9933
Here is the link to all DIY threads:
http://www.ninjette.org/forums/showthread.php?t=5586
Good luck!!
U5er is offline   Reply With Quote
Old September 22nd, 2011, 11:12 AM   #4
TxriderMike
i was actually riding
Old September 22nd, 2011, 11:26 AM   #5
WhiteRice
Kamikaze Squirrel
WhiteRice's Avatar
Motorcycle(s): 2010 250r
Undo the screw holding the lens to the back housing.
Pull the wires through the back housing and connect to the reflector assembly.
Reassemble lens and back housing.
WhiteRice is offline   Reply With Quote
Old September 22nd, 2011, 11:28 AM   #6
TxriderMike
awesome ill try it right away i just got off work
Old September 22nd, 2011, 01:04 PM   #7
The stock tires aren't fantastic, but as long as you keep them properly inflated (around 28psi front, 32psi rear, measured when cold), and let them warm up a bit before leaning them over too far, they will behave perfectly fine.
No, you don't need to get larger tires to be safer. Yes, you can get stickier tires that provide more ultimate grip when riding the bike more aggressively, but the tires aren't going to be the reason a new rider can ride safely or not.
Old September 22nd, 2011, 01:24 PM   #8
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
so...... Did you do the 600 mile service? It sounds like that's what they wanted to do which is...you know....fairly important. Worth $220 important, some might say.
Old September 22nd, 2011, 01:46 PM   #9
TxriderMike
I DID IT!!! didn't need to even take anything off whiterice. I did exactly as you said took me about 3 min no problem. Now my lights work just fine, and it snapped right back on.
Old September 22nd, 2011, 01:49 PM   #10
TxriderMike
so how important? i just changed my oil myself (with a help of a friend) and he did the clutch. only other thing i think i remember the guy mentioning is the bike chain... is that something i could do myself?
Old September 22nd, 2011, 05:54 PM   #11
Trailerboy531
I honestly don't know exactly what it entails but I know it's important. If it's just clean/lube the chain you could easily do it yourself but there may be more. It's got to be on the site somewhere, I would be surprised if Alex didn't know.
Old September 22nd, 2011, 05:56 PM   #12
There's a wiki article, and a DIY thread about what happens at the 600 mile service. Yes, it's possible to take care of it at home without too much trouble, but make sure you have the full checklist.
(wiki is at a link at the top of every page, or simply wiki.ninjette.org. All DIY threads are linked from a sticky thread at the top of the new-gen tech section.)
Old September 22nd, 2011, 06:44 PM   #13
Havok
Internet Slut
Havok's Avatar
Motorcycle(s): 04 FZ1, 07 FZ6
You will HAVE to do you chain yourself if you wait till service to do it things can go bad. It is recommended to do it every 400 miles. I find it easier to do it in time intervals so i do my chains every 2 weeks. Its cheap and easy to do. For convenience i suggest getting a rear stand. You wont need a super expensive one, the 30 dollar one from harbor freight will do you just fine.
How i do mine is i get it up on the stand and put it in neutral so the back tires can spin. I spin the tire while spraying this stuff:
on the two inside parts of the rollers. After spraying it on i use a chain cleaning brush to scrub the chain, this stuff will remove all the grit and grime. After scrubbing it use a clean shop rag and spin the back tire again and wipe the chain clean. Once done with that you guessed it spin the back wheel and spray the chain one more time with the teflon doing the inside parts of the rollers and let it set up. let it set up a few hours with over night being the best option. takes 10 mins tops.
Havok is offline   Reply With Quote
Old September 22nd, 2011, 06:47 PM   #14
Havok
Internet Slut
Havok's Avatar
Ohh i forgot under no circumstance will putting it in first gear and letting it idle on the stands to move the tire for you work out well. Its a very very very bad idea.
Old September 22nd, 2011, 07:57 PM   #15
TxriderMike
thank you guys very much. I appreciate all of the outstanding advice. I couldn't ask for more. I'm sure I will have many more questions to bother you with in the near future. I will take care of all of this right away. My next question is how do i take that back fender off? the "duck bill"
Old September 22nd, 2011, 11:24 PM   #16
Trailerboy531
The big thing that hangs over the back wheel? Well... There should be a couple of bolts attaching it that you could easily find to unscrew and remove it. Or you could do the newbie way: give it way too much gas, wheelie, and fender chop that mofo!
Old September 23rd, 2011, 06:11 AM   #17
TxriderMike
I have taken off like 6 bolts from the back that i thought would take it off. Needless to say I was highly mistaken, I guess I will just take every bolt off that F**** and see where is goes. I want to customize my bike so that it looks diff. I will definately start a new thread with before and after pics. I also want to be the one that puts in all the work, so I may learn how to DIY everything that pertains to my bike. After I get off work I will go buy that chain brush.. could you pick that up at walmart? Or should I just go to my local bike shop? I get military discount so it really doesn't matter which one I go to. (walmart is closer)
Old September 23rd, 2011, 06:38 AM   #18
WhiteRice
Kamikaze Squirrel
WhiteRice's Avatar
A dremel
Old September 23rd, 2011, 06:42 AM   #19
TxriderMike
Originally Posted by WhiteRice View Post
A dremel
lol really?
Old September 23rd, 2011, 06:47 AM   #20
WhiteRice
Kamikaze Squirrel
WhiteRice's Avatar
The cheap alternative to buying a kit, search "fender chop".
These pics sikuss took are a good example
Red: Fender chop
Black: Fender eliminator kit
Green SE: Stock
Old September 23rd, 2011, 06:56 AM   #21
TxriderMike
cool! i really wish i could see the back end of those bike pics though i think i like the chopped look better...
Old September 23rd, 2011, 11:44 AM   #22
lol really?
Definitely check out the DIY sticky at the top of the tech section, there are instructions (and hopefully pictures) about all kinds of mods you can do to your bike:
There are a few threads in there that talk about fender modifications, here's one of the simplest:
http://www.ninjette.org/forums/showthread.php?t=964
But there are a few more there as well.
Tail Light and Front Turning Light Install Help foxdanger 2008 - 2012 Ninja 250R Tech Talk 2 May 23rd, 2014 07:36 PM
WTB 08+ Front Brake lever/Bar End/ Front Turn Signal 1LoneWolf Items Wanted 3 July 8th, 2013 02:50 AM
Front right signal not working. 2010ninjablue 2008 - 2012 Ninja 250R Tech Talk 3 May 14th, 2012 03:50 PM
Front caliper behavior when turning right samw 2008 - 2012 Ninja 250R Tech Talk 5 April 28th, 2012 03:25 PM
Needs a turning signal dlebe250 Items Wanted 6 May 29th, 2011 05:15 PM
