January 1st, 2013, 04:12 PM | #1 |
How Fast Can You Go App?
January 1st, 2013, 05:54 PM | #2 |
just went through deals gap in kneedragger mode.
17555 Tapoco Road, Robbinsville, NC 28771 7801 Happy Valley Rd Tallassee, TN surprising how many curves have to be negotiated at lower than 40mph.
January 1st, 2013, 06:08 PM | #3 |
Yea, I did part of my normal route. Interesting results compared to what I normally do vs. what others "say" they do. I routinely say "it's a challenge to take this route @ 55mph the whole way". According to this app, it's not possible at 40 degrees, in which I agree. Now if you increase the lean..... different story. I will have to change my story next season. Veteran riders: "Try to take it at 55mph but there are a few corners you must slow down for".
Willow KY Falmouth KY 40 degree 55mph limit
January 3rd, 2013, 12:56 PM | #4 |
dirty boy
MOTM - Apr '14
I played around with it on a few roads, one i have never taken on my bike. I am assuming red circles are speed? despite me saying 95mph speed limit it says 120+? in some? I am guessing it is just stating max speed possible for lean angle despite listed speed limit?
Regardless, it had one killer turn listed at 21mph which i agree with, but then another at 40mph which is probably close to being right but would definitely be pushing it But then i did a small section of my daily commute, and it listed one turn at 31mph..... I routinely take it at 35-40mph with out serious lean and have taken it faster when riding aggressive. So it tells me that the program is most likely limited by google maps and how accurate of a depiction it gives of the turn/curve. But fun little program either way. |
January 3rd, 2013, 01:07 PM | #5 |
Yea, red circles are the speed in which that corner can be negotiated at the parameters set; max speed and max lean angle. Given the vagueness of google maps (maps in general), I would expect it to be off every now and then. No substitute for knowing the route first hand.
His goal is to create an app that can guide you down unfamiliar routes. For this to be of any real value a "margin of error" must be built in and somehow not overestimate a corner, ie. error on the side of caution at the very least.
January 3rd, 2013, 01:17 PM | #6 | |
it can't determine banking of the road and vertical slope changes, but it still accurate for 90% of curves in my commute, since the land is flat here. the deal gap scenario is probably off by a good margin, lol.
January 4th, 2013, 11:01 AM | #7 |
Join Date: Jun 2009 Motorcycle(s): Yamaha R6 (street), GSXR 750 (track) and a Harley FXDB Posts: 140
Nice find, Chris!
This site may become a staple in how I find new roads during the winter. Now take what you want from what I am about to say... Either I ride like an asshat while I am on my almost 700lbs cruiser with a 30 degree lean angle... This site is off... Or this site will give you a general idea on an unfamiliar road... ...but, I did punch in one of my favorite stretches of road. 45mph speed limit, 20-25mph posted signs, site says as low as 30mph on some of the turns but I know for a fact I dont fall below the speed limit on this road.
Previous rides: Ninja 650, Ninja 250, Goldwing and a Nightster |
January 4th, 2013, 11:32 AM | #8 |
One of the biggest factors is missing from his math in the app is camber. Since the google map data only gives elevation for a given gps point, 90 degrees is hard coded into the formulas for any given speed, lean and radius of the turn. Most all experience riders know that good camber can call for faster speeds.
Anyway... don't take the speeds as 100% (see my margin of error comment above). Also, there are at least 50+ factors that can be added to an equation that will result in different speeds for any given corner. I see it similar to you, I see a twisty road on a map but when I ride it.... It's sometimes is less than I expected. Hopefully this will help weed out some of those trips. But then again... I have seen some very cool things and made some new friends in unexpected places.
January 4th, 2013, 12:09 PM | #9 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
Um....ok, so here's my local fun spot.
Start Position: GPS Lat/Lng, street address or intersection. 32.648517,-83.760388 End Position: GPS Lat/Lng, street address or intersection. 32.724079,-83.986616 There is NO way you can take the Jordan Chapel turn doing 110. I'm currently the fastest on that corner, and 80 is tops, with the knees dragging, and the rear right on the verge of sidewall. I don't care what bike you do it with. And you'd better have your apex spot on too, right at the 35mph max sign or you're in the corn. The rest of the track sounds about right, with the exception of the turn right before causey, which is a corner where it starts 5 positive, and switches to a 8 negative camber, and any nutcase that tried it at 90 is dead. Literally. The last guy to try it, went to his funeral headless...they found it a couple of days later. This section of road is deceiving...it looks like a few long straights with just long sweepers, but they are tricky decreasing radius corners, and with oddball cambers that change mid-turn. You'll come in at 100+, everything's going fine, and then it tightens up on you, and changes camber....crap bricks for the newbs. |
[motogp.com] - Marquez: “There are a lot of fast riders on fast bikes” | Ninjette Newsbot | Motorcycling News | 0 | March 24th, 2015 06:30 AM |
[superbikeplanet.com] - Yamaha's Lorenzo Shakes Off Fast Crash To Set Fast Time in Se | Ninjette Newsbot | Motorcycling News | 0 | October 16th, 2014 10:50 PM |
[kropotkin thinks...] - 2014 MotoGP Sepang 1 Day 1 Round Up: A Fast Rossi, A Fast Ope | Ninjette Newsbot | Motorcycling News | 0 | February 4th, 2014 11:40 AM |
[superbikeplanet.com] - It's Dry He's Fast. It's Wet He's Fast. Stoner Again In Secon | Ninjette Newsbot | Motorcycling News | 0 | June 10th, 2011 08:00 AM |
[superbikeplanet.com] - There's An App For That. WSBK iPhone App Debuts | Ninjette Newsbot | Motorcycling News | 0 | April 9th, 2010 07:30 AM |
