Old December 8th, 2011, 11:23 PM   #1
naughtylion
Motorcycle(s): 2012 Kawasaki Ninja 250R
Backfiring/Popping & Running Lean
I've had a look around this site but can't really find a specific answer to my question - apologies if it's been answered before hidden away in another thread
I noticed my bike popping with the stock exhaust maybe once or twice in the two months I've had him. It was always in the morning when kicking over for the first time with the choke on.
I've since installed a yoshi slip on (completely aware this is for w@nk-factor only) and it's either started doing it more, or just become more noticible. I was wondering is this is an indication that it's running lean? It may sound great on a beasty engine, but with a loud exhaust IMHO this bike sounds better when it's running smoother and purring along, because the exhaust (although sounding better than stock) already highlights how tiny the engine is.
So my question would be (in the event that popping has no indication on lean/rich) is there any way to tell if your bike is running lean? Running lean will cause damage in the long run, right? I can't afford to rejet for a few months but if there's any indication I have that it's running fine I'd feel more comfortable about putting it, and the snorkel romoval, off for a while. But then again it happens more when downshifting to brake with the choke on in the morning, which would mean it's running richer... no?
Any help, as always, would be much appreciated. Thanks guys!
naughtylion is offline   Reply With Quote
Old December 9th, 2011, 12:37 AM   #2
cuong-nutz
cuong-nutz's Avatar
The popping you are hearing is due to the kleen air system installed on your bike. You can remove it and plug it up and it will rid you of the popping. You may benefit from adding 2 washers under your carb needles.
You can find all the information in the DIY section here:
http://www.ninjette.org/forums/showthread.php?t=5586
Removing Kleen Air System
Shimming the Carb needles
Lots of good information to read and educate yourself
HalfFast Racing Team
Old December 9th, 2011, 07:14 AM   #3
/moved to new-gen tech
Old December 13th, 2011, 02:45 PM   #4
kenji_808
Motorcycle(s): 2009 CT Blue 250R(Sold), 2008 Black & Silver Honda CBR600RR(Current)
i have basically the same setup you have except i have a K&N drop in filter. I used two shims under my needles and it reduced the afterfiring a little and did increase power a bit, iirc majority of the 250s run lean from the factory, few are the exception.
i Just recently did the kleen air delete i now i have zero afterfires.
kenji_808 is offline   Reply With Quote
Running Lean? Kristofferzero 2008 - 2012 Ninja 250R Tech Talk 14 April 20th, 2012 10:06 PM
Am i running lean? OGjackafidy 2008 - 2012 Ninja 250R Tech Talk 8 September 19th, 2011 07:06 PM
new akrapovic slip on.. popping/backfiring questions ninjaflav 2008 - 2012 Ninja 250R Tech Talk 4 August 4th, 2011 07:04 PM
Backfiring/popping on deceleration iggysmalls 2008 - 2012 Ninja 250R Tech Talk 4 September 23rd, 2010 03:37 PM
Backfiring and popping Keenan84 2008 - 2012 Ninja 250R Tech Talk 13 April 21st, 2010 09:01 PM
