Old March 27th, 2013, 02:10 PM   #1
JBinSD
Motorcycle(s): '13 Ninja 300, '99 SV650 tracked
Rear Brake Bleedout?
So I did my front SSBL today, and changed my rear tire, and checked my rear brake, and like almost nothing, full pedal travel, and no pressure. The routing of the OEM brake line does a little roller-coaster up and down, and putting on Vortex rearsets raised the cylinder another couple inches.
To be honest, I don't know if I've ever had a back brake, since I never use it, but now I'm pissed. I re-bled the line about 6 times, and it would hold pressure when the caliper was off and on an equal level with the resevoir, but would lose pressure when its bolted on the caliper perch. Wtf?
I'm going to switch out the rear line with SS tomorrow morning before hitting the track, but have any of you had this problem? I'm bleeding from both the bleeder value and the banjos trying to get rid of any air, but each time I get pressure built up, I bolt on the caliper and whoosh, pedal travel with no pressure.
Fookin weird, I'm hoping the new line will solve it, but wanted to see if anyone else had a similar experience or advice.
thanx,
Joel
JBinSD is offline   Reply With Quote
Old March 27th, 2013, 02:30 PM   #2
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
You have to be missed something in the equation but from your description I can't say what.
Old March 28th, 2013, 05:45 AM   #3
geeker
geeker's Avatar
Motorcycle(s): 2022 Honda CRF300L Rally, 2015 Ninja ZX6R 636, 2014 Ninja 1000, 2013 Ninja 300 (sold), 2011 Ninja 250R (sold)
Are you using the brake light switch with the rearsets? When I put in new tires, I noticed a little seepage from the fitting between the rubber hose and the caliper banjo. I never lost pressure though. They still work like the day I took delivery of it.
geeker is offline   Reply With Quote
Old March 28th, 2013, 05:59 AM   #4
Joshorilla
Bass Master General
Joshorilla's Avatar
Hmm, so you're bleeding the caliper off the bike "raised up I hope"? Are you using a piece of wood simmilar thickness or slightly thicker to your disc between your pads? Obviously air is getting in somewhere, either you havn't got it all out or more in being introduced somewhere, this could be the banjo bolt crush washer gap or the piston seals on the calipers, or simply you havn't let it all out and it's retained in the line, do the pistons and seals look to be in good condition? And is the banjo bolt tightened to spec "no too tight as it's aluminium!"?
Old March 28th, 2013, 06:27 AM   #5
May it be a defective master cylinder?
http://upload.wikimedia.org/wikipedi...ke_diagram.gif
If you cannot build pressure and keep it at any point, and have never used the system, chances are that the seals of the master cylinder piston have hardened or/and that the compensation and inlet ports are clogged.
Old March 28th, 2013, 08:04 AM   #6
JBinSD
Than guys, helpful thoughts. IGeeker, I did remove the brake light switch with the new rear set install, so that could have affected it. I did elevate the caliper and put a wrench between the pads too, and it would hold a seal upon elevation, but lose pressure only after the caliper was bolted on the perch. Replacing the line with SS today, hope that's the fix, but I appreciate the input guys, thanx :-)
Old July 18th, 2013, 04:21 PM   #7
JBinSD
Just reviving this thread again, as I still haven't gotten the rear brake working. I noticed there are some curious bracket type things on the right side of the swingarm, and now I'm wondering if that affects the caliper and how it sits on the perch.
checking to see if anyone's messed with this and figured it out before. . . .
Thanx,
joel
Old July 18th, 2013, 04:26 PM   #8
felo
Motorcycle(s): Ninja 300R
Thanx,
joel
that bracket type things is where the oem brake hose goes
felo is offline   Reply With Quote
Old July 18th, 2013, 04:35 PM   #9
JBinSD
Thanx Felo, I knew it was for the brake hose, but that pic helps by pointing out the pistons on my caliper seem to be hitting the hose brackets, that may be a reason why the brake is not functioning. I also noticed I routed my brakeline differently, so it approaches the banjo from the front, instead of looping around to the back. Not sure if that has an impact or not. .. hmm.
Old July 18th, 2013, 04:50 PM   #10
JBinSD
I'm also wondering if I have the caliper perch flipped or something; after looking at the picture of the 250 caliper and mine, it looks like my caliper isn't far enough forward.
Anyone have a pic of their (working) 300 caliper? Doubt they're diff than the 250, but ya never know. . .
Old July 18th, 2013, 04:54 PM   #11
felo
i have a 300 and is the same , the only difference is that the 300 caliper is black
Old July 18th, 2013, 04:55 PM   #12
JBinSD
OK, thanks, is the caliper forward of the hose guides, or right there? If you look at my pic above, my caliper actually contacts the hose clamps, and I think that may impede the travel of the pistons, does your caliper touch the hose guide?
Old July 18th, 2013, 05:02 PM   #13
felo
well i dont have the bike close to tell you exactly but here are 2 google pics that i found
just try and take the line out and do the process again, try and get the caliper out and push the pistons in , if that makes any diference. just take your time
Old July 18th, 2013, 05:14 PM   #14
regardless of the outside of the caliper or what its pressed against, putting hydraulic pressure into the cylinder should expand the piston out into whatever. doesn't matter if its doing it correctly or not. and it should put resistance on the pedal at a certain point. if you do not reach a point where enough pressure is built up to extend the piston, and not enough pressure is built up to hold the pedal back, then you have a leak in the system somewhere. could be seals, maybe the line. if the brake caliper pot cylinder was rusted and not moving you would still build pressure in the master and the pedal would have resistance. the fact that the pedal never gets enough pressure to provide resistance means that pressure is either not being built up or it is quickly dissipating. my vote is on a damaged master cylinder seals.
Old July 18th, 2013, 05:23 PM   #15
JBinSD
hmm, thanx Alex, but the thing is only 6 mos. old, and I replaced the line with SS, AND it pressures up when the caliper is not on the perch, so I'm trippin' as to why it loses pressure once its put in place. . . I guess its possible the master cylinder seals were fried from the beginning, as I've never used a back brake before, but since I seem to enjoy a good runoff at Chuck rather frequently, I guess I need to get it dialed. . .
Old August 2nd, 2013, 06:44 PM   #16
Xtina
Xtina's Avatar
Motorcycle(s): 2013 Ninja 300, 2007 Gsxr 600, R6-sold :(
So if there is not pressure on the pad and you keep putting fluid in the reservoir, where is the brake fluid going? Is it leaking out? If there's fluid in there it has to go somewhere, either leak out or compress the caliper.
Xtina is offline   Reply With Quote
Old August 2nd, 2013, 07:59 PM   #17
Lychee
sail away
Lychee's Avatar
here is a really insightful question.
Old August 4th, 2013, 06:21 PM   #18
JBinSD
The volume of fluid is not increasing, but the pressure is dissipating somewhere.
Old August 6th, 2013, 02:26 PM   #19
sousuke86
sousuke86's Avatar
Motorcycle(s): 2011 Ninja 250R SE
When you bleed the caliper make sure you have the bleeder screw facing UP.
You'll get pressure but air bubbles will remain in the line no matter how much you bleed them.
sousuke86 is offline   Reply With Quote
Old August 6th, 2013, 03:20 PM   #20
I just had this happen to me today. Mine was a crimped in the large feed tube from the fluid reservoir to the master cylinder. When the raised rearsets are installed, it kinks the stock feed tube. NO crimps or kinks in the main.
Last futzed with by csmith12; August 6th, 2013 at 03:31 PM. Reason: spelling
Old August 6th, 2013, 03:26 PM   #21
JBinSD
Hmm, thanx guys, I'll check them both and see if there's any air. . .
Old August 6th, 2013, 03:35 PM   #22
What mine looked like for reference.
Rear Brake Lever Travel is Excessive and Rear Brake won't Lock Tire. N-m 1986 - 2007 Ninja 250R Tech Talk 14 July 17th, 2014 04:13 AM
08+ rear wheel, right rear set, rear brake system, seat cuong-nutz Items Wanted 2 October 6th, 2013 05:37 PM
Rear Brake Doesn't activate Brake Light And DOT3/4 FRONT BRAKE OIL coelgrim 2008 - 2012 Ninja 250R Tech Talk 16 March 11th, 2013 05:10 PM
For sale: 2003 ninja 250 rear brake pedal and rear shock ReDnEcK Motorcycle-related 0 October 6th, 2010 12:02 PM
