June 15th, 2016, 08:39 AM | #41 |
MOTM - Sep '14
Keep calm and ride on -Motofool Never quit on a rainy day -ally99 |
June 15th, 2016, 09:21 AM | #42 |
Join Date: Jan 2012 Motorcycle(s): 2008 (Black) Kawasaki Ninja 250R Posts: 151
Correct me if I'm wrong but I thought for the new gen 250 you had to get a tire that was 16 for the rear. Hence the limited number of tires that will fit.
I recall buying one rear tire that was larger and I spent one hell of a time trying to get it on, eventually I resorted to using a ratchet strap and finally came to the bright conclusion that no way in heck was the thing going to bead properly. Live and learn |
June 15th, 2016, 09:24 AM | #43 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
Michelin Pilot Street, Best Bang for the buck you can get, traction, life, awesomeness.
140 rear size will be a bit bigger, still work just fine. My 105 HP Ténéré only runs a 150, and on top of that, I'm running knobs. I've ridden this thing around some turns faster than I've ridden any other bike, even the ninja. When I'm hanging off the bike on the edge of the knobs, I was getting some looks. It was awesome. I have a ninja 650 Wheel that matches the style, is an extra inch wider so a 150 will look proper. I'll sell it. it wouldn't work for me, tire too wide, many other things, but hey someone else can give it a shot.
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
June 15th, 2016, 09:25 AM | #44 | |
MOTM - June '15
good luck getting a 16" tire on a 17" wheel....lol 2008+ is 17"
June 15th, 2016, 09:58 AM | #45 |
Just sittin on my stool..
Join Date: May 2016 Motorcycle(s): 2012 Ninja 250 Posts: 429
I didnt say it was a 600, I said a BIGGER bike...
June 15th, 2016, 10:00 AM | #46 |
Agree, looks aside, a 120 is a good compromise between big bike look and ridability. And... there are sooooo many 600's with a 120 front.
EDIT: realistically, the front end of a ninja has enough problems on it own without adding to them.
June 15th, 2016, 10:01 AM | #47 | |
June 15th, 2016, 10:04 AM | #48 |
MOTM - June '15
old tires, bad wear, wrong pressure, poor suspension setup.
all things that could cause that, not 3/4 of an inch less of usable tread width
June 15th, 2016, 10:06 AM | #49 |
June 15th, 2016, 10:23 AM | #50 | |
MOTM - Sep '14
June 15th, 2016, 10:44 AM | #51 |
June 15th, 2016, 10:53 AM | #52 |
Private Joker
MOTM - Mar '14
Out of interest what was it then?
Most bikes do have much better suspension and components than the ninja, our bikes are built out of the bargain bin also, if you're on the original tires it may be a good idea to switch them out anyway since they'll be near the end of their lifespan (tires and helmets, 5 year rule) I'd go for michelin pilot street radials (make sure they're the radials, the R3s are coming out with a bias ply version which is not as good despite being cheaper) 140 rear is the most I would put on the 250. On the 300 I'd consider a 150 but it's not remotely needed. The michelins offer the following: -good grip in the dry for street use, you can drag knee on these without too much issue. If that's your goal go with the pirelli option since they really love to lean -excellent grip in the wet (designed as a toned down rain tire) -fantastic life, I got ~10k out of mine and I wasn't remotely easy on them. I can also put them back on if I really want to. I've heard as high as 20k miles out of these which is more than enough for anyone to be happy with. -They'll provide that more planted feel you're looking for
June 15th, 2016, 10:56 AM | #53 | |
Either the rider is too tight, the suspension is cheap and isn't doing much for those road irregularities, or some combination of both. The rider part is likely because you're new, no offense. This is also a cheap bike. It has cheap suspension components. Also, I'd be floored if you, as a new rider, could tell the difference explicitly between what the front and back of the bike were doing. I know I couldn't. That took time and some brown'd pants to figure out. That said, check that your back wheel isn't loose, same with the suspension, etc. It's a worthwhile check to make sure that your bike is safe to ride. Easy stuff first. |
June 15th, 2016, 12:23 PM | #54 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
Whenever I hear of these symptoms on a 250 I always assume the blinker fluid is low. It's surprising the amount of things that the blinker fluid impacts.
I'd check that first. |
6 out of 6 members found this post helpful. |
June 15th, 2016, 12:53 PM | #55 |
Join Date: Jul 2015 Motorcycle(s): 2001 Ninja 250, 2019 Harley Ultra Classic, 2001 Suzuki SV650 Posts: A lot.
MOTM - Jan '16
June 15th, 2016, 02:10 PM | #56 | |
EX500 full of EX250 parts
140*70% - 130*70% = 98-91 = 7mm. Or (140-130)*70% = 10*70% = 7mm. The sidewall is 7mm taller, meaning the tire diameter is 14mm larger, and the rear axle would be raised 7mm (~1/4"). And yes, these are based on the tire size category numbers; different tire models will have slightly different measurements in reality. That extra 1/4" will raise the seat a bit, and make the steering a bit twitchier. As stated, it's not going to drastically alter how the bike operates, but it will be slightly different, and that much harder for a short person to reach the ground.
June 15th, 2016, 02:11 PM | #57 | |
If you want to change the looks of your bike, go for it. Just don't lie about your reasoning. It's pointless to yourself and to others, and only hurts your credibility. As someone who upgraded from the stock 130/70 to a 150/60 on a wider wheel (on a slightly-bigger little Ninja), I can tell you the wider tire does not alter the stability on a rough road. P.S. I spent $923 in total on this upgrade. You can compare the pics above to see how visible the change is and if it's worth the money to do it right. The NewGen isn't as bad as the PreGen/500, but the single best change I've made on my bike is spending $90 and 30 minutes to drop in new fork springs to match my weight, within a few months of buying the bike. On the other hand, I've had a Penske shock (~$800 new) sitting here for over 2 years that I haven't bothered to install yet, because my cheapo swap is miles ahead of the stocker for my weight. Real Soon Now™ I'll get that Penske in... I'm not stupid enough to ask a woman about her weight, but you can look at the links above to see how well the stock rates match your weight. If the springs are too soft, the wheels will be flailing around excessively underneath you. If the springs are too stiff, the wheels can't absorb bumps and will skip. If the springs are mismatched, the bike will act like a rocking horse. Getting springs of the right rate will allow the wheels to move the proper amount to absorb bumps while supporting your weight. It's amazing how much smoother my ride is now that I have stiffer springs.
June 15th, 2016, 02:18 PM | #58 | |
What else would you suggest in 150/60 and 110/70?
June 15th, 2016, 02:35 PM | #59 | |
Join Date: Aug 2013 Motorcycle(s): 2012 Ninja 250 Posts: 450
I would honestly get a new tire and wheel bearings if the wheel feels as if it gets wobbly over bumps. I would really have someone check the rear out to make sure all the bearings in the wheel and swing arm are good with no problems. |
June 16th, 2016, 02:21 PM | #60 |
Join Date: Apr 2016 Motorcycle(s): 09' Ninja 250R Posts: 12
Im currently trying to decide between a few tires for my 09 250. i was going to decide between a battleax bt45 and conti go or even now perhaps the pilot street. but im sticking with the stock sizes of 110/70/17 and 130/70/17 anything bigger in the front and you will probably have to move the fender up to keep it from cutting into the front tire. anything bigger than a 140 in the rear changes the entire reason for owning a 250 in the first place. got to ask your self would you put a bigger tire on your car than the rim calls for?
*edit* you also answered your own question. you said you rode a bigger bike and it felt more stable. that was because its a bigger bike. bigger in general is always going to be more stable, and i don't mean just tires. weight plays a lot into it as well. tire quality, suspension. all of those are gonna be better even in stock form on a bigger bike than a stock ninja 250. |
June 16th, 2016, 04:11 PM | #61 |
Fast-Guy wannabe
MOTM - Jan '13
have you considered a new rear shock? ohlins makes a much better shock then stock and with the properly rated spring in the rear i'm sure all your stability issues would disappear. Also a slightly tall shock will make the bike sportier looking.
Rear Brake Lever Travel is Excessive and Rear Brake won't Lock Tire. | N-m | 1986 - 2007 Ninja 250R Tech Talk | 14 | July 17th, 2014 04:13 AM |
rear tire | akcalhoun | 2008 - 2012 Ninja 250R Tech Talk | 7 | February 21st, 2013 09:22 AM |
need new rear tire?? | mhesse | 2008 - 2012 Ninja 250R Tech Talk | 5 | June 30th, 2011 04:46 AM |
rear tire | james250ninja | 1986 - 2007 Ninja 250R Tech Talk | 5 | October 16th, 2010 12:58 AM |
Wide rear tire | Snake | 1986 - 2007 Ninja 250R Farkles | 22 | February 15th, 2010 09:30 AM |
