August 28th, 2012, 04:30 PM | #1 |
150/60 Tire + Passenger
Wussup everyone. This is my first post but I have been following forums for about 4 months now. I've looked around and have not found an answer to this question. Can i carry a passenger on my 08 Ninja with a 150/60 tire? Or will 150 tire not allow me to carry a passenger? Thanks for the help.
August 28th, 2012, 04:35 PM | #2 |
ninjaholic
Join Date: Jun 2010 Motorcycle(s): 09' SE 250R (sold), 03' ZX-6R, 99' XL1200C SP Posts: A lot.
First of all, welcome to the forums or at least posting to the forums... secondly, what exactly are you thinking the 150/60 will or will not do that having or not having a passenger would matter?
I have a 150/60 and have ridden 2up with no issues... but was just curious as to what you thought might or might not make it possible
09' SE Ninja 250R $2,547.83 worth of mods installed... come on Unregistered, you know you want to know what? Check my Blog "Modification List" |
August 28th, 2012, 04:37 PM | #3 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
I dont see why not.
The only caveat to a 150 tire is that the rim pinches the tire a bit. There are plenty of people racing 150's on the back of the 250R, so I dont think your passenger would create a problem...unless they weigh 300lbs or something. |
August 28th, 2012, 04:43 PM | #4 |
August 28th, 2012, 04:46 PM | #5 |
Thanks everyone. Wasn't sure if the weight of extra passenger will affect the space of bigger tire.
August 28th, 2012, 05:11 PM | #6 |
Wartown, USA
The closest thing to touching a 150 is the chain guard, and even then there is 5mm or so of clearance. So again...unless the person is REALLY heavy, it's not going to rub anywhere.
August 28th, 2012, 08:21 PM | #7 |
Welcome! Depending on the weight of your passenger it will rub a hugger if you have one, at least on the brake reservoir. Bump up the rear shock to at least setting 3 if your passenger is 130+lbs. If you get a pre-gen your SOL. The tire is on the list yes... but the shock setting is waaaaaayyyyy more important.
August 28th, 2012, 08:24 PM | #8 | |
Jigglin' your Jiglets
MOTM - Apr '13
August 28th, 2012, 09:46 PM | #9 |
Join Date: May 2012 Motorcycle(s): Ninja 250 and Gsx-R 750 k8 (out of commission) Posts: 482
I run the battlax s20 hyper sport 150/60 rear and my wife rides a lot with me with no problems
Omoplariangle-bar |
August 28th, 2012, 09:48 PM | #10 |
MOTM - Apr '13
Tires will explode, passengers not advised
Pros and Cons of a 150 Tire? | tnr4 | 2013 - 2017 Ninja 300 General Discussion | 28 | April 26th, 2013 12:00 PM |
150 Rear Tire | TheJimmyEnglish | 2008 - 2012 Ninja 250R Tech Talk | 27 | August 4th, 2011 09:58 PM |
150/60/17 Rear tire | onepeon | 2008 - 2012 Ninja 250R Tech Talk | 91 | February 6th, 2011 12:04 PM |
WTB: 150 rear tire...;) | Plasma | Items Wanted | 0 | October 3rd, 2009 04:09 PM |
