#1 |
Switching tire compounds (all bikes)
I just ordered a Michelin Road Pilot 4 rear tire for my other bike. The tire coming off is the original OEM tire. The front OEM tire still has a bit of meat on it, so I opted to save cost by waiting to replace that one.
Is there a consensus on changing 1 vs. 2 tires when the tire types/compound are changed? I know it would be optimal to change them both together, but is it safe to mix until the front also needs to be replaced?
#2 |
My 2 cents, ride whatever you want, just don't outride the weakest tire. It's as safe as you make it.
#3 |
OEM tires usually suck, and I've replaced brand new ones after 500 mi for that reason, so I would recommend getting something better on there - especially the front.
The front will wear a lot less than the rear, so you may be able to get 2 rears for 1 front. Good tires are a must. You won't regret it. |
#4 |
@csmith12 makes an excellent point, it will only perform as well as the weakest link, personal I've always done both at the same just to keep everything up.
violente et ignorantia ZX-2R BLOG Twitter and Instagram = Ghostt_Scott I'm not here to change your mind, just to inform. ![]() |
#5 |
Que Buenos Son!!!
MOTM - Nov '14
You'll probably be fine as long as your not pushing that hard. What is the OEM tire btw?
Don't do something because it's easy,.. Do it because it's not! If you aren't going forward, then you're falling behind. ![]() ![]() |
#6 |
Dunlop Sportmax D222
#7 |
The worst new tires I've ever had on a cycle were OEM Suzuki Dunlop 220s. That's the ones I replace at 500 mi.
#8 |
My D222s seem better than the OEMS that came on my Ninjette; but I also have 50K miles of experience between them, so it could be the added rider confidence/competence between those two experiences that make it difficult to compare.
[roadracingworld.com] - Pirelli Bringing Soft And Intermediate Tire Compounds To Imol | Ninjette Newsbot | Motorcycling News | 0 | June 24th, 2013 07:20 AM |
[roadracingworld.com] - Bridgestone Bringing Only Two Front Tire Compounds To Sepang | Ninjette Newsbot | Motorcycling News | 0 | October 18th, 2011 01:10 AM |
[roadracingworld.com] - Bridgestone Bringing Softer Rear Tire Compounds To Mazda Race | Ninjette Newsbot | Motorcycling News | 0 | July 19th, 2011 10:40 AM |
[roadracingworld.com] - Bridgestone Will Bring Softer Tire Compounds To Assen | Ninjette Newsbot | Motorcycling News | 0 | June 23rd, 2009 08:20 AM |
[visordown.com] - Car drivers could save £6500 by switching to bikes | Ninjette Newsbot | Motorcycling News | 0 | September 15th, 2008 09:54 AM |
