July 18th, 2012, 09:29 PM | #201 |
Join Date: Jul 2011 Motorcycle(s): 2010 250R FI, 2006 ZX10R Posts: 175
received your email
I'm Selling wider (4.5" & 5") aftermarket Wheel for N250r/N300r/Z250/Z250r |
July 19th, 2012, 10:11 PM | #202 |
VROSSI wheels now available in black/white
July 19th, 2012, 10:47 PM | #203 |
Roy, I noticed you removed those front Sprocket cover.. is it for intention of easy cleaning?
July 20th, 2012, 07:07 AM | #204 |
Join Date: Jul 2012 Motorcycle(s): 2009 Ninja 250R SE Posts: 262
July 20th, 2012, 09:04 AM | #205 | |
Join Date: May 2011 Motorcycle(s): 07 Ducati S4RS, 02 Ducati 998R, 02 Honda 954RR, 07 Yamaha R1, 92 Honda NC30 (VFR400), 08 Kawasaki Ninja 250R Posts: 30
Here are pics of my other bike's exposed front sprocket: Honda 954RR Fireblade Yamaha R1 Ducati 998 Ducati S4RS Monster
STEALIN' my daughter's lil' Ninja and carvin' it up with the big boys!! |
July 28th, 2012, 04:13 AM | #206 |
black out of stock, white available 9 sets
August 9th, 2012, 02:04 AM | #207 |
Freedom for Germany
For those interested in wider rims for the Ninjette.
You can also get them here, just send the guy an email about shipping-cost. http://www.psmmotorsport.com/index.p...&product_id=67 |
August 10th, 2012, 06:50 AM | #208 |
Join Date: Jun 2011 Motorcycle(s): 2005 zx6r, 2009 250R Posts: 14
Sorry it took so long to post up pics of the 4.5" wheels. Pilot power 160's
Here are a bunch of shots of my girlfriends (also a member here) bike that I installed them on, I appologize if the pick are crappy... cell phone shots Started out black Powder coated them gold... by Dublast powder coating, awsome guy to work with. |
August 10th, 2012, 07:01 AM | #209 |
More pics...
Picture with the girlfriend, cause I know you leg humpers wont let it be unless I post at least one of them. |
August 10th, 2012, 10:01 AM | #210 |
black & gold, very nice combination!
August 10th, 2012, 10:45 AM | #211 |
August 10th, 2012, 11:01 AM | #212 |
Thanks... the pilot power 160's were a very tight fit, so much so, that we ended up going down 3 teeth on the rear sprocket in order to move the wheel back a little bit and gain some clearance.
With the stock sprockets and chain, the tire would rub on the swing arm. Needed to pull the wheel back about 1/2" to get the minimum clearance, 3 teeth lower on the rear sprocket did that and put the adjusters about 3/4 of the way out... should be fine for a while. She has a few hundred miles on the new setup and loves everything about it, -3 on the rear sprocket made the bike much nicer to drive also. Less revs and no loss in acceleration... for her anyways, 5' nothing and 94lbs... not much to pull around. |
August 27th, 2012, 11:05 AM | #213 |
Join Date: Feb 2012 Motorcycle(s): 2012 Kawasaki Ninja 250R Posts: 83
Damn I want some new rims after looking at the pictures.
Wandyhee, email sent. |
August 27th, 2012, 12:11 PM | #214 |
Join Date: Feb 2010 Motorcycle(s): 2009 Ninja 250 2016 Ninja 300 1994 KTM 300 EXC Posts: 123
I am going to buy a 150 rear tire and wanted to push the rear tire back to give more clearence what size chain should I buy?
August 27th, 2012, 12:29 PM | #215 | |
It's what I did to get lower rpm's on my commute as well. I think I'm a 15/42 now. Prolly cheaper this way too. Up to you.
August 27th, 2012, 01:38 PM | #216 |
So I would just have to change the sprocket size then? And can I go 160 on the stock rim?
August 27th, 2012, 04:47 PM | #217 |
email replied
August 27th, 2012, 08:05 PM | #218 |
Accesories Guru
Join Date: May 2011 Motorcycle(s): '99 EX250(Cafe/fighter project) Posts: 537
August 27th, 2012, 08:35 PM | #219 |
US$345 including shipping to USA
August 28th, 2012, 12:38 AM | #220 |
Join Date: Aug 2012 Motorcycle(s): many kawasaki 2 stroke triples and a 250R now. Well no more 250R, 2013 300 now Posts: 146
Coming from the "skinny tire" era, fat tires on low HP bikes are only fashion.
For performance, including racing, you want the smallest tires to do the job. Lighter rotational weight, less steering effort and quicker transition are 3 advantages, and probably less cost as a bonus. I vintage race, and my 500 2 stroke puts out 84 RWHP. I use a 100 front, and 110 rear. (both on 2.15" rims) And when/if I ever finish my 250 2 stroke vintage racer, it should be around 50 RWHP and I will be using a 90 front and 100 rear. And the big 1000 vintage super bikes are limited to 140 rear tires, and they are 100 plus HP. So even the stock 130 on the Ninja 250 is more fashion than necessity with 30 to 40 HP. So if you are out to look cool with fat tires, that's cool. But for performance, fat rim and tire money could be used better elsewhere... That's my 2 cents....... |
August 28th, 2012, 12:48 AM | #221 | |
Join Date: Jan 2012 Motorcycle(s): Ninja 250r - Track whore, Ninja 300 - SOLD, KTM RC390 - Orange Hulk, Ducati 899 Panigale - Red Devil. Posts: A lot.
August 28th, 2012, 04:35 AM | #222 |
Accesories Guru
August 28th, 2012, 04:53 AM | #223 |
So many cool pics...
August 28th, 2012, 05:12 AM | #224 |
yep, both front and rear
August 28th, 2012, 05:13 AM | #225 |
A 160 is not advised on a stock rim. A 150 will work in most brands and yes going down some teeth on the rear sprocket will give you some additional chain length to get that 150 some clearance from the swing-arm.
August 28th, 2012, 08:12 AM | #226 |
Ok I'll go with the 150 I still like the way that looks. And if I didn't want to change the sprocket size what chain size would I need to get to have more clearance?
August 28th, 2012, 08:41 AM | #227 |
I think our bikes take a 106 link chain. If I were you I would order at least a few extra links and cut to fit your application.
August 31st, 2012, 03:20 AM | #228 |
Join Date: Jul 2012 Motorcycle(s): 2010 Ninja 250R Limited Edition Posts: 20
Hey Andy,
I'm looking at getting one off you. Can you check your email, please? Thnx! |
August 31st, 2012, 03:47 AM | #229 |
noted, been riding for the whole day today. just arrived at the destination. will check it up
August 31st, 2012, 04:10 AM | #230 |
August 31st, 2012, 08:28 PM | #231 |
Would you sell a single rear vrossi wheel instead of the set? I just can't get myself to need to change my front wheel. I just want to upgrade my rear wheel tire combo.
August 31st, 2012, 09:59 PM | #232 |
Freedom for Germany
Why then not take this one: http://cyber-ninja250r.darkbb.com/t1...nja-250-45inch
This is the best quality and its the same design like oem. |
September 1st, 2012, 01:23 AM | #233 | |
Jigglin' your Jiglets
MOTM - Apr '13
I did just order a 120/70 front and 190/50 rear though
September 1st, 2012, 02:55 AM | #234 | |
sorry mate, the come by pair from factory and we only sell it by pair. you can get rear only wheel brand Chemco which also 4.5" wide and has same spoke design as OEM wheel as in link below http://ninja250r-parts.blogspot.com/...3-front-4.html
September 4th, 2012, 04:12 AM | #235 |
Freedom for Germany
@2012NewRider - the 4.5" rim you can also get in the USA already.
Sportisi's offering it at 379.99 USD and it seems they have one in stock http://sportisimotorsport.us/index.p...products_id=41 |
September 16th, 2012, 09:06 PM | #236 |
Accesories Guru
@wandyhee, another question about the Vrossi rims, do I need to buy a different kind of bearings and bushing or does it use the same as the stock one? Very interested in purchasing a set around December, as an xmas present for myself but need to know as much as possible first.
September 16th, 2012, 09:13 PM | #237 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
Anyone care to guess of he 300s rims will fit on a 250?
September 16th, 2012, 09:44 PM | #238 |
MOTM - Apr '13
Why so you can put 140s on it?
And cmon, you want those ugly ass spider jizz wheels?
September 16th, 2012, 09:46 PM | #239 |
Accesories Guru
September 17th, 2012, 04:41 AM | #240 | |
[motorcyclistonline] - Plug and Play, or Pray? | Answers | Ninjette Newsbot | Motorcycling News | 0 | May 27th, 2014 07:30 PM |
FS: VROSSI 3" Front & 4.5" Rear, Plug & Play for Ninja250 (08-12) & Ninja300 | n250r | Motorcycle-related | 1 | January 19th, 2014 07:39 PM |
L.E.D Dioded mod, Plug and play!! | Syphontek | 2008 - 2012 Ninja 250R Farkles | 2 | July 7th, 2012 07:11 PM |
Koso rx-2 plug and play kit F/S | dyeforever | Motorcycle-related | 2 | May 14th, 2011 02:31 PM |
[motorcycledaily.com] - Plug-and-Play | Ninjette Newsbot | Motorcycling News | 0 | August 7th, 2009 01:20 AM |
