May 27th, 2014, 10:45 AM | #1 |
Join Date: Mar 2014 Motorcycle(s): nina 250r 2010 Posts: 10
2010 ninja 250 wont stay on!
Hi,
My bike wont stay on anymore. I ride almost every day, except for Jan-Feb of this year due to the snow/cold. It rained pretty hard on Day 1 or Day 0. Day 2, Bike runs fine, idles fine, revs normally, It went to at least 8k rpm. (did not try riding it). I did see some water drip out from under the seat on the left side. Day 3 It turned on and revs up to 3k rpm. when I twist the throttle more, it sputters and lowers rpm. Tried for few minutes, to see if it would go higher, since a cold bike would sometimes do that. Nope, it slowly got worse. The idle rpm kept dropping over time til it just stalls. Day 4 No improvement; it turns on and idles really low, then stalls. So what is going on? From the searching around forums, I think it's the carburetor. Either water in gas, maybe gummed up carburetor? |
May 27th, 2014, 10:54 AM | #2 |
Did you try fresh gas?
May 27th, 2014, 10:59 AM | #3 |
I added gas a day before the rain. So tank is at least half full.
May 27th, 2014, 11:00 AM | #4 |
Water will collect in the float bowls of the carbs. If you suspect water in the gas, it's best to just drain the entire system and start fresh.
May 27th, 2014, 11:01 AM | #5 |
Track Clown
MOTM - Sep '15
are you using the choke and letting the bike warm up before turning the choke off?
May 27th, 2014, 11:11 AM | #6 |
It stalls with the choke on, after a few seconds.
May 27th, 2014, 11:38 AM | #8 |
Thanks, I will youtube how to drain float bowls.
May 27th, 2014, 02:42 PM | #9 |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
Yea, water in the fuel. I was able to get away with just draining the bowls when this happened to me.
May 27th, 2014, 07:47 PM | #10 |
yes! after draining the bowls, it started!! it's still bogging a lil bit, but it went away after riding for a while. The fluid that came out was clear, so i guess it's clean? I think it happened because the drain next to it was clogged with dirt/bits of leaves? I wiped it off, but what can I pour down that drain to make sure it's clear and not clogged? Rubbing alcohol? Or should I use an air compressor to make sure it's clear, and then pour something.
May 27th, 2014, 07:55 PM | #11 |
Nice! Do a stabil treatment and run through that tank of gas as soon as your can.
Air gun on the compressor here to clear the drain/overflow.
My 250 Wont go more than 55 mph...!!!! | Knobs28 | 2008 - 2012 Ninja 250R Tech Talk | 14 | May 19th, 2016 06:20 PM |
2007 Ninja 250 wont start...any suggestions? | tkessler | 1986 - 2007 Ninja 250R Tech Talk | 11 | February 26th, 2014 10:36 AM |
09 Ninja 250r wont stay idle without choke | TqAmsNy | 2008 - 2012 Ninja 250R Tech Talk | 11 | March 20th, 2013 01:38 PM |
Idle jumps to 9000 rpm on choke then wont stay idle after off | Shawn250 | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 19th, 2012 06:45 AM |
HELP!!! New ninja wont stay running; suggestions? | synapsekiller17 | 2008 - 2012 Ninja 250R Tech Talk | 19 | November 4th, 2010 01:11 PM |
