Old September 1st, 2015, 05:49 PM   #1
benferry
Motorcycle(s): kawasaki ninja 250r
something is leaking... help
Hello,
so im new to ninjette... But I have an odd problem I think. MY ninja 250 2007 is leakin something dark black out the left exhaust near kickstand and gear shifter. Nothing is dripping on it that I can tell. I just changed the oil a week or so ago. (Havent riden it since the oil change either). White smoke is coming out the exhaust.
Please Help.
benferry is offline   Reply With Quote
Old September 1st, 2015, 06:12 PM   #2
/moved to pre-gen tech
(General is only for threads that really don't have a home anywhere else)
Old September 1st, 2015, 06:27 PM   #3
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Is it a full-on leak? Or just oozing a tiny bit?
Old September 1st, 2015, 06:28 PM   #4
I very well may just be water (condensation) and carbon from the pipe dripping out - which is normal. The white smoke is most likely condensation as well. Water is a byproduct of combustion.
Take a close look at what it is. Does it dry if you let it sit? Is it slippery? Did it show up after a short trip? Do the engine fluids (coolant, oil) stay at the proper levels?
Go for a long ride (after checking your fluid levels) and see if it comes back when you park it.
Old September 1st, 2015, 07:43 PM   #5
May it be too much lube on the chain that has accumulated under the cover due to the centrifugal effect of the front sprocket?
Old September 1st, 2015, 08:03 PM   #6
YES!!!
Old September 1st, 2015, 08:48 PM   #7
benferry
wow thanks for the quick responses...
It is a slow leak/drip... the drip is increased when the throttle is applied. Iv'e been doing some work on it this summer with the gauge cluster, so haven't rode it yet. This leak just started yesterday out of random... It hasn't done this at all out of the several times I've started it... I've cleaned the carbs several times over this summer too. Here is some pics... the oil level seems to be ok, its hovering around the 1/2 to 3/4 mark. Whatever is leaking doesn't seem to have a smell to it, at least to me.
here is a link to the images.
Let me know if these help, The two images that I drew on seems to be the spots where it is dripping the most.
Thanks
Old September 2nd, 2015, 03:20 PM   #8
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
No smell? Usually water, condensate inside the exhaust. Black would be from the soot being washed out with it. Does it feel greasy? Smear it on a white paper towel to confirm the color and to look for particles.
One of the primary results of combustion is H2O, along with CO2. When the exhaust is cold that H2O condenses inside the exhaust. Later it gets hot enough to blow it out as first steam, then vapor. If your exhaust is leaking then that water will drip out.
Old September 3rd, 2015, 05:37 PM   #9
dcj13
Participant
dcj13's Avatar
Smell (and taste) are useful in determining the origin of fluids found under vehicles: motor oil; coolant (sweet but poisonous); gasoline; hypoid oil (cars, shaft drive bikes); ATF (chesnutty odor); water (car a/c condensation); or cat urine.
Old September 4th, 2015, 07:54 PM   #10
benferry
Smile
Hey Guys,
So great responses... I havent tasted it yet, sort of freaks me out. Let me give you some more background on this bike. It has been sitting for two years (shame on me) Some of the front end cluster gauge was broken, and I had no drive to fix it). Now that I am fixing it and fixed it I am having this leak problem. Now if this sparks any new ideas what might be issues with this leak, Please let me know.
Now an update on the bike. It seems to be having a hard time starting now and keeping running when it does. I took out the spark plugs yesterday and BOTH of them had some residue of oil on them! It was not a whole lot of amount, the bottom two threads and the bottom of the plug itself. Not sure if this is a possible issue with the stem valves or piston rings??
As soon as i figure out how to post pics in a efficient way I will. (any help on the pics situation would also be greatly appreciated)
Old September 4th, 2015, 08:29 PM   #11
benferry
Hey Guys,
So here are some pics. Hope you can view them
Cheers
Old September 4th, 2015, 09:07 PM   #12
https://www.ninjette.org/forums/showthread.php?t=5611
Old September 5th, 2015, 12:21 PM   #13
benferry
hey Guys,
So a quick update/question
I went in an talked to a motorcycle store and talked to the service people. His first thought with the leak and being black is that my mixture is to rich and I possibly need to re-jet my my carburetor. The end of the spark plugs are fairly black too. So he basically said that my bike can't burn up the oil due to being to rich so it just spits it out the exhaust.
Which this all makes sense to me. What he was saying is just a possibility too. Any opinions on this would be great. My bike now is having a hard time starting and running - and maybe that could be to the rich mixture and loosing combustion.
Old September 5th, 2015, 12:40 PM   #14
Yes, faulty tuning of the carbs can cause hard starts and a rich air to fuel mix, resulting in a drip, drip out of the exhaust in the joint areas. This type of leak normally has a distinct smell of gas though... Stuck floats in the carb bowls can also cause this issue but again, the smell of gas should be easily detectable.
Old September 5th, 2015, 12:56 PM   #15
benferry
oh ok. perfect thanks for the response. Ill see if I can attempt a taste test... since I cant detect the smell of it very well.
Old September 5th, 2015, 04:19 PM   #16
RickM
Motorcycle(s): 2000 EX250
You said you did a recent oil change.
How much oil did you put in? Any chance you overfilled the oil. The Vapor hose from the carb canister goes into the airbox on the left side right about above the muffler joint. So if you over filled the oil it will get into the airbox via the crank breather and can leak out the left side of the airbox. Just one more thing to check.
If it was gas it'd be easy to tell by smell. it's more likely oil and condensation in airbox
RickM is offline   Reply With Quote
Old September 5th, 2015, 05:43 PM   #17
benferry
Well guys,
I appreciate all the help and advice you guys gave me. I learned a lot about the extents of motorcycle engines.
But I think I found the culprit today. I decided to take off the carburetor just to check it out, and i found that on the left side the main fuel jet was unscrewed completely! So I put it back and my ninja eventually started up... and no leak!!
So I guess it was getting a rich mixture and having to blow out some of that excess it couldn't burn through combustion.
So I took it for a spin... and i did notice (looked like blue smoke) out of the exhaust when riding for a short short time. So will need to look into that now... cant remember if blue smoke is related to coolant or oil... but time for research.
AGAIN THANKS FOR ALL YOUR HELP AND ADVICE.
I GREATLY APPRECIATE IT.
Old September 5th, 2015, 06:24 PM   #18
xXecuterXx2
ChocolateMilk Addict
xXecuterXx2's Avatar
Motorcycle(s): '05 EX-250 "Kallie" 85 KLT 110 ATC "Murdock"
Blue smoke means your burning oil, i'd suggest draining the oil in the airbox thru the drain hose. Look at the oil fill hole, then look left towards the back of the bike, around 7 inches back you'll see an assortment of rubber hoses, one has a clamp and a plug take those off and drain whats in there. btw white smoke means you're burning water, blue means oil.
xXecuterXx2 is offline   Reply With Quote
Old September 6th, 2015, 11:46 AM   #19
Glad you found the problem.
It all makes sense. Extra fuel being dumped in the engine and being pumped out the exhaust. It mixes with the condensation in the pipes/muffler and dissolves some of the carbon - creating a black watery/oily fluid.
Radiator Leaking Apex123 2008 - 2012 Ninja 250R Tech Talk 7 November 9th, 2014 03:27 PM
Ninja Leaking Chewitt38 2008 - 2012 Ninja 250R Tech Talk 10 August 1st, 2013 12:35 PM
Coolant leaking into oil and oil leaking out of somewhere. Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 31 May 25th, 2013 04:09 PM
Leaking coolant Chuffmonkey 2008 - 2012 Ninja 250R Tech Talk 5 May 30th, 2012 11:47 PM
leaking a little gas h0yitsdom 1986 - 2007 Ninja 250R Tech Talk 15 July 11th, 2011 04:57 PM
