May 11th, 2014, 04:54 PM | #1 |
Join Date: Apr 2014 Motorcycle(s): 2012 Ninja 250 Posts: 64
How did I make it home today....
So, I think the picture explains it all..
So the backstory.. Was on a group ride with a few guys from our local forum. Ride was about 200miles round trip and had a lot of hills, curves , etc. We stopped to gas up, and everything was fine with my bike then, (checked it), gas station was like 60 miles from my home, so somewhere in those 60 miles the brake fell off.. I have tightened the bolts before, so not sure why the hell this happened. But while I was riding through like 2 miles of construction zone, with bumps potholes etc, had some crazy guy in a truck chasing me and honking. So I stopped.. and hes like, do you know your rear brake is like hanging off? So yeah... I ziptied it and slowly rode home. The brake pad is scratched a bit and the brake pads are chipped off a little, but seem to be okay. |
May 11th, 2014, 05:08 PM | #2 |
Motorcycle Nurse?
Join Date: Sep 2013 Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100 Posts: 606
How the ??????
I would go crazy with the Loctite from now on!!! |
May 11th, 2014, 06:10 PM | #3 |
motorcycle rider
Join Date: Apr 2009 Motorcycle(s): '14 Yamaha V-Star 650 Custom (silver) Posts: A lot.
That... is not good...
Did you service the brakes recently, or have someone service them for you? If the bolts are torqued down correctly, they shouldn't work loose like that.
'14 Yamaha V-Star 650 Custom (silver) |
May 11th, 2014, 06:21 PM | #4 |
Intrepid Adventurer
Join Date: Jan 2012 Motorcycle(s): 2004 GSXR 750 , 71 cb350streettracker, 07 Polaris Predator 500 Posts: A lot.
Use a torque wrench and loctite.
that is certainly absent minded mechanic work lol Glad you didn't have an accident. Who needs breaks any way!
LIFE IS NOT FOR REGRETS OR EXCUSES. Breath deep, seek peace. Embrace the Madness. Life is good, let it be |
May 11th, 2014, 06:22 PM | #5 |
Track Clown
MOTM - Sep '15
NO ****, looks like you barely turned any corners!
May 11th, 2014, 06:26 PM | #6 |
Jigglin' your Jiglets
MOTM - Apr '13
Unless it was raining I don't see a problem
May 11th, 2014, 06:53 PM | #7 |
Threadkiller
Join Date: Apr 2014 Motorcycle(s): Yellow '04 stocker, '89 FJ1200, '87 Ducati Paso, '71 Yamaha XS1b, '99 KLR650, '81 FXE 80, '97 KTM 200EXC , etc Posts: 430
Forget the Loctite, just tighten the bolts next time.
We call my friend "Fingertight" because he's always trying to do two or three things at once, (phone, bs'n, "where's my beer?") then forgets to tighten things down. Lesson learned? |
May 11th, 2014, 07:03 PM | #8 |
Well the bike only has 10xx miles right now, and I did check all the bolts at around 500 miles and they seemed tight to me. There was no service for the brakes yet. Man I am paranoid now.. going to go check every bolt, not sure what the guy before me did with this bike.. -.-
May 11th, 2014, 07:44 PM | #9 |
Join Date: Apr 2014 Motorcycle(s): 1995 ninja 250r Posts: 130
creepy. i think i will go check my brake studs.
your pretty lucky, it was the back and it didnt fall into the wheel locking it up. |
May 11th, 2014, 08:12 PM | #10 |
Que Buenos Son!!!
MOTM - Nov '14
This happened to me once, but the caliper wasn't all the way off just one bolt fell out and the caliper was most of the way off. Luckily I don't use the rear brake much. Didn't notice until I got home.
May 13th, 2014, 10:41 PM | #11 |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
May 14th, 2014, 05:35 AM | #12 |
dirty boy
MOTM - Apr '14
Crazy cuz you claim no service that would require removing the back brake caliper. When I took mine off the first time those bolts were on there real good. I ended up using 3/8" ratchet with hex key socket to break them loose.
May 14th, 2014, 07:34 AM | #13 |
hmmmm.... you will be surprised what you can ride though, parts coming off, fairings wrapping around your foot while leaned over and what not.
Put it back on and ride on. A lil dab of silicone on the bolts should solve the problem in the future without the issues that come along with locktite. If not, safety wire that stuff. Question for you, did you miss a service interval? Checking those bolts (and a lot of others) are part of the maintenance plans. Food for thought...
May 16th, 2014, 03:11 PM | #14 | |
Man I could not find the damn bolts anywhere, had to order them online, now need to wait 2 weeks. Its been 80 out all week, gah! |
May 17th, 2014, 07:22 AM | #15 |
Join Date: Dec 2013 Motorcycle(s): Ducati 999 2012 Ninja 250r Ducati748 Yellow finally running 2003 SV650 S (SOLD) Posts: A lot.
One thing everyone seems to have missed is: Do you ever use your rear brake? You should have noticed the problem the first time you applied the rear brake and the pedal just moved with no resistance. Glad to hear you did not crash.
May 17th, 2014, 07:56 AM | #16 | |
Also what I noticed is that where the bolt goes into, you have the actual frame holes and then the caliper its self with the bolt holes. A m7 bolt fits the holes in the caliper, but the holes in the frame are like m10, m12. is it suppose to be like that? Because if its only being held by the part in the caliper, its barely being held on. Both are threaded, so I would assume it would be suppose to be held by both? |
[crash.net - WSBK] - Sykes eager to â??make home round countâ?? | Ninjette Newsbot | Motorcycling News | 0 | May 21st, 2014 02:11 AM |
[crash.net - WSBK] - Rea hoping to make in-roads at home | Ninjette Newsbot | Motorcycling News | 0 | May 8th, 2012 10:10 PM |
Damn Google home page today! | HKr1 | Off-Topic | 9 | May 26th, 2010 05:00 PM |
I was at home today (maybe a slight WW on the picture) | Apex | Off-Topic | 7 | August 5th, 2009 12:21 PM |
[roadracingworld.com] - Today Capirossi Will Make Record 277th Grand Prix Appearance, | Ninjette Newsbot | Motorcycling News | 0 | August 31st, 2008 06:49 AM |
