Old June 28th, 2009, 09:42 AM   #1
delvey91
Fuel Injection FTW
delvey91's Avatar
Motorcycle(s): Old:2008 Kawasaki Ninja 250R New:99 ZX6R 'G2'
Rev meter Problem
Hiya guys,
Got a annoying problem with my rev counter,
Every time i rev past 9,000 the rev neddle stops for a split second and then carrys on rising up to 12,000 like normal, Its really annoying as you can see it out the corner of your eye whislt riding. It has nothing to do with the engine speed as this sounds fine
1999 Kawasaki ZX6R 'G2'
Got: Powerbronze Irdium Screen, Powerbronze Rear Hugger, A.R.T Racing Slip on can
delvey91 is offline   Reply With Quote
Old June 28th, 2009, 10:18 AM   #2
komohana
komohana's Avatar
Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock
i had this happen to me on a different motorcycle, and older honda 'ceptor, and it the motor eventually began to cut out with the rpm drops. come to find out it was a spark unit going bad. not saying it's that here, but wanted to share the similarity.
Remember when sex was safe
and motorcycles were dangerous?
komohana is offline   Reply With Quote
Old June 28th, 2009, 10:26 AM   #3
same thing as a CDI or ignitor?
Old June 28th, 2009, 10:30 AM   #4
komohana
komohana's Avatar
yes...they were just smaller than a cigg. pack. said tach got signal from there on the honda.
Old June 28th, 2009, 01:15 PM   #5
Banzai
Psychic war veteran
Banzai's Avatar
Originally Posted by delvey91 View Post
Hiya guys,
Classic indication of a CDI going bad. WELCOME TO THE CLUB!
After 3 CDIs and 2 Tachs, this same problem is where I'm at with my bike. Check out the thread on the CDI issue to see about details and check if you have any of the other problems associated with the bad CDIs.
Old June 28th, 2009, 01:57 PM   #6
delvey91
Fuel Injection FTW
delvey91's Avatar
Ah thanks very much, It seems thats my problem, I have been getting worse petrol mileage. It used to do 220 miles to a tank and now its only doing 170
So i need a new one of these. http://cgi.ebay.co.uk/KAWASAKI-ZX250...3%3A1|294%3A50
Old June 28th, 2009, 05:28 PM   #7
Banzai
Psychic war veteran
Banzai's Avatar
Perhaps not, might be something else going on. Yours is the first FI bike I've heard of having the CDI problem. ????? This bears looking into!
Old June 29th, 2009, 06:49 AM   #8
HKr1
IC2(SW)
HKr1's Avatar
Dont think the fi bike would have the cdi. Everytime I have seen those type of ignition coils, there controled by the ecm.
Old June 29th, 2009, 08:40 AM   #9
Banzai
Psychic war veteran
Banzai's Avatar
Our CDI controls our coils, true, and the ECM in the FI bikes is just an expanded version of our CDI with a few more computer chips.
I'll take a look at the wiring diagram for the FI bikes later and see what kind of commonality there is.
Whatever the FI bikes call it, it'll control the fuel injection as well as the timing curves for the ignition.
Old June 29th, 2009, 10:47 AM   #10
delvey91
Fuel Injection FTW
delvey91's Avatar
Apparently it is a problem with FI bikes....
I went to my local dealers today as my bikes still under warranty and explained to the technician the problem etc.
He said he has had the same problem on two other bikes that have been used all through the winter months like mine. Apparently the inside of ECU becomes condensated and upsets the electric gizmos etc. I am having the new one fitted on wednesday so i will see if that cures the problem. The guy seemed pretty sure it would though.
Thank god for the 2 year warranty
Old June 29th, 2009, 11:12 AM   #11
Banzai
Psychic war veteran
Banzai's Avatar
Wow, that sucks. First we've heard of that over on this side of the pond. Sorry you folks suffer from it, too.
Our cycle is CDI, tach, repeat until customer gets frustrated and doesn't want to try again, warranty expires, or customer stops coming back to spend money.
Apparently someone on another board was told by their Kawi dealer that it's as simple a fix as a reflash of the CDI chip, and that they know it's a good fix. I'm thinking someone doesn't know what they're talking about. If it was that easy, everyone all over the web would be reporting that, NOT the cycle of replacement parts.
Last futzed with by Banzai; June 29th, 2009 at 05:54 PM.
Old June 29th, 2009, 12:32 PM   #12
Rayme
Rayme's Avatar
Motorcycle(s): '04 sv650s
These needs to be seriously better ventilated if it holds true.. woah !!!
I've put 3000 KM on my bike and I think I got that problem (carburator version) with the CDI. I was driving at 120 KM and RPM was indicating 9000 RPM +, where it should have been lower (around 8300-8400) like usual because I got a larger sprocket up front. Only happened once on a particulary hot day... I'm out of warrenty, if I get more problem I'll adress the ventilation with some mods.
There's 2 types of people in this world, those who complain and those who act.
Rayme is offline   Reply With Quote
Old June 29th, 2009, 05:52 PM   #13
Banzai
Psychic war veteran
Banzai's Avatar
After reviewing the wiring diagram for the FI bikes, the tach gets it's signal directly from the ECU. It is NOT in parallel with the signal to the coil like it is with the carb bikes.
Old June 29th, 2009, 09:19 PM   #14
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
i get it every so often at 8K, for a split second, wouldn't feel it if i didn't see the needle stop. unable to recreate on demand.
Old June 30th, 2009, 02:04 PM   #15
HKr1
IC2(SW)
HKr1's Avatar
They call it a "Digital" Ignition.
Hey Chief, you got a pdf copy of the FI schematic?
Old June 30th, 2009, 03:09 PM   #16
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
wiring diagram for all models is in the service manual - seems that Indonesia is different than our bikes too...
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old June 30th, 2009, 03:43 PM   #17
Banzai
Psychic war veteran
Banzai's Avatar
Yup. Need it?
Old June 30th, 2009, 03:51 PM   #18
HKr1
IC2(SW)
HKr1's Avatar
Yeah, what do they have.... a parking light
Yup. Need it?
PM sent
Old June 30th, 2009, 04:05 PM   #19
noche_caliente
That's who has it! I saw the cutout for it in our headlight, but couldn't figure out where it came from! I want one!!!!
Old July 1st, 2009, 03:08 PM   #20
delvey91
Fuel Injection FTW
delvey91's Avatar
I had the new CDI fitted today and the problem is gone
I dont know if the MPG has improved has havent done enough miles.
Old July 1st, 2009, 03:11 PM   #21
That's great news, Jack!
Now, can you get someone at Kawasaki of EU to kick somebody's a$$ over at Kawasaki US?
Old July 1st, 2009, 05:28 PM   #22
HKr1
IC2(SW)
HKr1's Avatar
I got the parking lights on my camaro. There on some overseas Hella Halogens, I got them coming on with the oem parking lights. Also made a voltage regulator so they run on 6 volts. Gives them a nice gold look
City lights, thats what there called.....
New CDI, must be some custom install???
Last futzed with by HKr1; July 1st, 2009 at 06:45 PM. Reason: remembered name
Old July 2nd, 2009, 12:07 AM   #23
delvey91
Fuel Injection FTW
delvey91's Avatar
Thumbs up
I meant ECU
Meter / Gauge cover Riverdale Items Wanted 0 September 13th, 2013 06:30 PM
Trip meter not working soggybottom 1986 - 2007 Ninja 250R Tech Talk 4 April 7th, 2013 11:37 AM
08 to 12 meter faces loz944 2008 - 2012 Ninja 250R Farkles 2 May 25th, 2012 04:05 PM
FS: Meter Assembly & Meter Cover Kangxi Motorcycle-related 2 May 16th, 2012 11:01 AM
