January 23rd, 2014, 04:38 AM | #1 |
Join Date: Jan 2014 Motorcycle(s): 2009 ninja 250r Posts: 9
My first ninja a couple of questions
Hi all i'm new around here great site very informative
I just purchased an 2009 ninja 250r with only 940 klms on the clock original owner had a heart attack and could not ride anymore the bike is in mint condition and I got it for a very good price. my question is after five years of mostly sitting would it be wise to replace anything? IE brake fluid,tyres that kind of thing The bike had a service at 500 klms Any help will be appreciated Thanx |
January 23rd, 2014, 04:47 AM | #2 |
Join Date: Aug 2012 Motorcycle(s): '11 250R SE (FI), '14 Daytona 675, '14 Sprint 1050 GT SE Posts: 121
Hi,
nice looking bike! I think brake fluid should probably be replaced after about 2 years so after 5 I would say yes. Many tyres also have a lifespan around 6-7 years I think, so worth checking. In the UK, there is a date code stamped on the tyre when they were manufactured, perhaps they do the same in Thailand? You could then look up the tyre manufacturer recommendations and see whether they are too old. I suspect an oil change would be a good idea, and also any petrol left in it has probably gone bad so I think it would be a good idea to drain it all and use new. With fuel injected models I don't think you have to worry about carbs gumming up but the same problems affect fuel injectors I believe so it may be difficult to start until the new petrol starts coming through. It might be worth considering an "injector cleaner" additive in the first tank though I have never used it myself. The other fluid that comes to mind is coolant. Probably worth looking in the reservoir tank and seeing if the fluid seems to be separating or any other signs of deterioration in which case probably change that too I'm afraid... HTH, Pete Last futzed with by dooby; January 23rd, 2014 at 04:48 AM. Reason: spelling |
January 23rd, 2014, 04:53 AM | #3 |
Thanx dooby
I'll check all things you mentioned. I'm a noob with bikes I havnt riden in years it's all new to me again . Looking forward to the fun. |
January 23rd, 2014, 06:40 AM | #4 |
It's a long boring story
Join Date: Jul 2013 Motorcycle(s): 2012 Ninja 250 Posts: 167
I just put a 2007 zx6 back into service after about 4 years of sitting. Things that absolutely needed changing were oil and brake fluid. The brake fluid collects water and will corrode the entire system. I drained the gas and ran some injector cleaner. It did run rough for the first 100 miles and it didnt get to full power till almost 700 miles. Some of that may have been the rider. That was my buddies first bike and he never rang it out till he got more comfy. He has put thousands on the old tires and the date shows them at 7 years old. I dont know if thats smart, but take it for what its worth
#41 MCRA alex.s :crashing is a normal part of life... people are just in denial about that. |
January 23rd, 2014, 07:08 AM | #5 |
January 23rd, 2014, 07:22 AM | #6 |
Welcome!
January 23rd, 2014, 07:36 AM | #7 |
Thanks guys
I will be sure to change all the fluids and I might just buy new tyres to be safe Great site you guys have here |
January 23rd, 2014, 07:37 AM | #8 |
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
Join Date: Nov 2013 Motorcycle(s): 2009 Ninja 250R and 2014 Triumph 675R Posts: A lot.
Welcome!!!
January 23rd, 2014, 06:36 PM | #9 | |
Private Joker
MOTM - Mar '14
for good grip wet/dry but less longevity: -Pirelli Diablo Rosso II http://www.revzilla.com/motorcycle/p...-ii-rear-tires http://www.revzilla.com/motorcycle/p...ii-front-tires -Michelin Pilot Street Radials http://www.revzilla.com/motorcycle/m...ial-rear-tires http://www.revzilla.com/motorcycle/m...al-front-tires for longevity while still being able to have fun once in a while dual compound tires are the best: -Bridgestone Battlax bt45 http://www.revzilla.com/product/brid...formance-tires there are other options that work as well but these seem to be the best at the moment for your $$$ and tires aren't something you want to skimp on too much. (your tire sizes are 110/70-17 front and 130/70-17 rear but you can get away with a 140/70-17 rear if you want to but I believe you won't be able to use the edge of the tires (which you likely won't be doing as a beginner anyway)) |
January 23rd, 2014, 08:06 PM | #10 | |
I'll go with the Pirelli's sound like a good all rounder. |
January 23rd, 2014, 08:08 PM | #11 |
Private Joker
MOTM - Mar '14
January 23rd, 2014, 09:22 PM | #12 |
Those are two different types of tires. The Pirelli Sport Demons are an older-generation bias-ply design, but very sticky compound. They are available with high speed ratings, and were one of the go-to tires for track use on earlier ninjettes before radials became more available. The Pirelli Diablo Scooter tires are a completely different tire, with a newer design, but still bias-ply as well I believe. Newer compound, probably better treadlife, but a low speed rating (92 mph, I believe). They are a good choice for the 16" pre-gen wheels, but for the 17" on the newgen 250's and the 300, there isn't a reason to choose them over any of the other more attractive options.
January 23rd, 2014, 09:23 PM | #13 | |
Private Joker
MOTM - Mar '14
A couple silly questions | auntymunga | 2008 - 2012 Ninja 250R Tech Talk | 3 | April 22nd, 2014 07:23 AM |
Couple simple questions.. | corksil | General Motorcycling Discussion | 21 | February 14th, 2014 11:26 AM |
Couple of questions | ninjaryda | 1986 - 2007 Ninja 250R Tech Talk | 7 | April 20th, 2013 05:14 PM |
A couple newbie questions | Snoman13 | General Motorcycling Discussion | 44 | September 29th, 2009 08:43 PM |
Couple of questions | pantera | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 6th, 2009 01:27 AM |
