August 13th, 2014, 06:43 PM | #1 |
Raising the tail?
Are any aftermarket dog bones available that lift the rear, without going to adjustable links?
I'm a fan of fewer moving parts. Curious if these are available... I'd like it to go up an inch or two. Zach |
August 13th, 2014, 07:38 PM | #2 |
Join Date: Jun 2012 Motorcycle(s): 1998 Ninja 250 2007 Yamaha R6 2003 Honda RC51... sold :( Posts: 205
If you have the older 2007 and before bike, you can just install the 08+ 250 shock and you'll sit higher by a bit, and you can adjust the preload.
August 13th, 2014, 07:58 PM | #3 |
I've got a 300 shock on her right now.
Namely, she feels small and I'd like to raise the tail... and at a later date put a Ninja 500 front end on her, as I've read that raises the front about 1 1/2 to 2 inches too. |
August 14th, 2014, 04:09 PM | #4 |
Private Joker
MOTM - Mar '14
shorter dogbones
be warned though, you can raise it too much personally my 250 setup is insanely aggressive. I raised the rear a bit and then lowered the front a lot. It didn't make the bike feel one bit bigger but my back has noticed
August 14th, 2014, 05:49 PM | #5 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
Raise hell, an praise dale
#3 |
August 15th, 2014, 10:07 AM | #6 |
Fighting Texas Aggie '05
There are lifting bones from http://burkhartcycle.com/store/index...roducts_id=204
August 15th, 2014, 10:09 AM | #7 |
Join Date: Sep 2012 Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B Posts: 315
Bigger tire
August 18th, 2014, 01:15 PM | #8 |
Join Date: Jan 2011 Motorcycle(s): 15 CBR300R, 14 BWS50, 09 FZ1, 09 Ninja 250, 06 CRF450R Motard, 03 ZX-6R Posts: 422
I want more legroom on my 09 250. I just did 2089kms in 2 days and my legs cramped early in the trip. Anyone try those dog bones above?
15 CBR300R, 14 BWS50, 09 FZ1, 09 Ninja 250, 06 CRF450R Motard, 03 ZX-6R 636 |
August 18th, 2014, 01:20 PM | #9 |
New links won't affect legroom. To do that, you'd have to lower the pegs or raise the seat. Safest thing would be to have an upholstery shop re-contour your seat to raise you up an inch or so.
August 18th, 2014, 01:24 PM | #10 |
You're right. Sorry for the stupid mistake. I have a Corbin seat on my bike which robbed me of some much needed legroom. I will be contacting Corbin to see what they can do. Thanks.
August 18th, 2014, 09:36 PM | #11 |
Track Clown
MOTM - Sep '15
I was attempting to figure something out for my bike, its an '08. I crashed this weekend losing the front and too often i felt like there was not enough weight on the front end. I was thinking raising the rear about an inch would help with the geometry. I have .80 springs in the front and a GSXR shock for the rear.
August 28th, 2014, 03:12 PM | #12 | |
Join Date: Aug 2013 Motorcycle(s): CRF450X, CRF250R/SM, Husky 630 SMS, Ninja 250R Posts: 144
August 28th, 2014, 05:32 PM | #13 | |
August 28th, 2014, 09:48 PM | #14 | ||
Track Clown
MOTM - Sep '15
August 29th, 2014, 12:13 AM | #15 |
have you tried getting on the gas sooner? why not go wide open before the apex?
August 29th, 2014, 06:17 AM | #16 | |
dirty boy
MOTM - Apr '14
You could probably drop the front a little as well, a little up front and a little in the back IDK? whatever works
August 29th, 2014, 09:28 AM | #17 |
Track Clown
MOTM - Sep '15
i know it is suppose to help, but i had no confidence. i guess i have a year to ponder the issue and make some tweaks to the bike.
August 29th, 2014, 10:42 AM | #18 |
what do you think kept you from having the confidence to get on the gas earlier? was the front unsettled when turning in fast? were you chasing someone quick and it made you charge corners? in the corner you crashed on, do you think you would be able to make your turn-in happen faster? that way you can get down quicker which means you can get on the gas sooner? i know trailing into the turn makes it feel smoother coming down but you're just robbing yourself of time on the throttle when you wait all the way to the apex to get back on it. and trailing in that far really puts a lot of strain on the front end. typically, once you are all the way leaned over and wide open, it's pretty hard to lose the front from underweighting it. i have wheelied out of corners on the 636 more times than i would have cared to. overweighting it with too much brakes, or simply not enough gas though.... now we're talking lowside material
August 30th, 2014, 04:32 AM | #19 |
Track Clown
MOTM - Sep '15
The next session I went out, i was going through a double left and the front slipped again. Not sure how I did not low side there, but i kept it up.
September 9th, 2014, 07:06 AM | #20 |
Found these today...
http://bluecollarbobbers.com/product...s#.VA8JM2Oa8vo Supposed to lift the rear an inch to inch and a half. Anything cheaper out there? $96 is a bit more than spending money... Zach |
September 9th, 2014, 07:19 AM | #21 | |
Not aware of anything, but it's a simple part, so my solution is to make them.
If there is enough interest I can make more than one set. I would need eye to eye length you'd want. Quote:
September 9th, 2014, 08:41 AM | #22 |
Join Date: Apr 2011 Motorcycle(s): 2015 636 ABS - 69 Honda 305 Posts: A lot.
I cant recall the site off hand but theres another guy who makes them in different lengths for like 20 bucks. I got the 1.25 lift since i bought the gsxr shock since everyone claimed it lowers the rear by an inch. I surely have more than a .25 lift on it, im going to raise my front .25 or .5 since the front feels a bit twichy at low speeds.
September 9th, 2014, 09:10 AM | #23 | |
You'd almost want to have some links made in several sizes and try some different options to see what works. Unfortunately changing links is more work than adjusting ride height in a premium shock. |
September 9th, 2014, 09:13 AM | #24 |
But 20 minutes of my time is worth not spending the addition $500+ to me. Im not going to race, just do track days. I think raising my front the little extra will help, the bike felt great at my last track day anyway. I should have went with a 1.00 raise, but i wont complain about the additional height since im tall and that gives me alittle more clearance.
September 10th, 2014, 04:33 AM | #25 |
I'd be curious who does them for $20...
Namely I'm not sure what length center to center to ask for to get the lift. Zach |
September 10th, 2014, 09:14 PM | #27 | |
Track Clown
MOTM - Sep '15
Raising the rear? | ahamay | 2013 - 2017 Ninja 300 Tech Talk | 7 | April 27th, 2013 06:54 PM |
Raising clipons. | beached | 2008 - 2012 Ninja 250R Tech Talk | 3 | March 19th, 2013 11:45 AM |
Raising the seat/tail on a pregen (dogbones?) | CZroe | 1986 - 2007 Ninja 250R Tech Talk | 21 | July 3rd, 2012 12:31 PM |
Raising a ruckus | rz3r0 | The Ex-Ninjetters Lair | 10 | October 23rd, 2011 04:06 PM |
Raising the tail end | cbowman78 | 2008 - 2012 Ninja 250R Tech Talk | 36 | December 15th, 2010 10:26 PM |
