#1 |
Join Date: Aug 2010 Motorcycle(s): 2009 Ninja 250r Posts: 61
Raising the tail end
Hey,
Any advice on how I can go about raising the rear end of my bike approximately 0.5 - 1.0 inch? ![]() I understand you can use Hayabusa lowering links, but I believe that raises the rear end two inches and I dont want to go that high. |
#2 |
Resident Old Guy
Maybe a taller tire? What size do you have now?
Cranking the shock up, will make the spring compress less, when you are on it... What is your objective? |
#3 |
Soon to be BT-016 150/60R17. I have them but havent had the time to get them installed.
Does anyone make raising links for the rear of our bikes? I searched quite a bit last night, but didnt find anything other than lowering links. |
#4 |
I've thought about raising mine. I made some cheap lowering links out of some old bar stock to lower the bike about 2" for the GF. They are extremely simple, just a flat bar with a couple of holes in them :P . Mine have three holes in them and normally it is at stock height (there is about 1.5" extra link that sticks below the bike), and we just move the bolt to the other hole when she wants to ride. Based on Kelly's observations after lowering the front I have contemplated make another set of links with a slightly offset "base" hole to raise the rear about half an inch from stock when on "my" setting, for the a similar same affect on reducing rake as lowering the front.
Factory Pro Jet Kit, K&N R-0990 Pod Filter, Sportisi VR Black Exhaust, BRT TIS Ignition, White Paint, and 16/41 Sprockets. Soon: Maybe a 37T Rear Sprocket if I get things running like I'd hoped. |
#5 |
How thick is the metal used in lowering links? Maybe I will just make mine.
I have the front lowered 22mm at the moment, and wanting to raise the rear a bit to get the rake that I want. I do not want to lower the front end anymore as I really do not want the forks to stick out any further. |
#6 |
I think 3/16" x 1-1/4" steel was closest to stock. However, Im sure you could go much thinner or narrower. Look at how little material there is between holes on aftermarket adjustable aluminum links, and you will see it really can't take much to hold it all together. But I went with near-stock dimensions because I didn't care enough about a half pound of weight savings on my street bike to potentially risk them giving out :P .
![]() Last futzed with by JMcDonald; December 15th, 2010 at 10:56 AM. |
#7 |
I may just make mine! I would have to take some measurements, it does seem easy enough..
Has anyone ever used the Hayabusa lowering links to raise their 250r? And if so, how much did it raise the rear? You can find these links for $20 on Ebay, it would definitely be the easiest option if the height would be ideal.. |
#8 |
2" Sounds like a huge amount! I have no numbers or data to support this, but it seems like you could end up with chain tension problems because there would be a more forward-rewardcomponent of motion ot the rear wheel when the swingarm pivots over bumps.
Yeah I just took off one of the links and used it as a template. I clamped the link together with two strips of barstock and drilled through the original link and through the bars on my drill press. I then just estimated the distance to the hole based on reviews. On most links, it seems with the holes right next to eachother, they each adjust the bike's height by about 1". So, I put the holes about 2 spaces next to eachother, and indeed it lowered the bike by about 2". For raising it, I might just offset the hole by just the radius of the hole, to get about a half inch higher. You could also stagger the holes so you could have .5" and 1" raised. This would just give you some more adjustability between a full 1" and stock.
#9 |
I agree with you. 2" is way too much!!!
I really want to stay between 0.5 - 1.0 inch. I contacted Soupy's who said they can make a custom adjustable arm, which would allow me to raise/ lower the bike 2 inches each way. But, $123 plus shipping sounds a little rich for me. |
#10 |
Ah heh, yeah Im sure it would be very nice but yeah it would be a bit too much for me too
#11 |
I am going to try and find some links with 5mm to 10mm tighter spacing.
By chance, you wouldnt know what the spacing for the holes are on the factory links, do you? I can check when I get home, but that will be a few hours from now. lol |
#12 |
what about a thicker, more comfortable saddle?
#13 |
I've been looking for an excuse to go ride somewhere, so I'll go measure the links in a few minutes at my parents' house :P .
backinthesaddleagain, he wants to raise the rear so the whole bike leans "forward" a tiny bit more. This will have the affect of making the angle of the forks a hair more vertical, which will make the steering a little quicker and more aggressive (it will require a bit less force to turn the bike, basically).
#14 |
ah i should have read his other posts.
#15 |
[QUOTE=JMcDonald;241185]I've been looking for an excuse to go ride somewhere, so I'll go measure the links in a few minutes at my parents' house :P .
QUOTE] JMcDonald, you are the man!! Thanks!! Trying to get these links ordered today, and its difficult to get out of work to go visit the bike. lol |
#16 |
K, the distance between the inside edges of the factory link holes is 5.99" or 152.2mmm . The hole diameter is pretty snug around a 31/64 ( 12.2mm) drill bit. So the distance between centers is 164.4mm.
Posted via Mobile Device |
#17 |
Join Date: Apr 2010 Motorcycle(s): 2009 Honda CBR600RR Posts: 633
Raising the rear is fine and dandy but how do you go about raising the front without buying new forks?
When you move one end you have to move the other end. If your doing this because it sags to much when you sit down you need to adjust the rear shock preload.
"Riding a motorcycle is like playing sports, not everyone is cut out for it." - WVNinja |
#18 |
#19 |
I think in a post subsequent to his original post he is looking to make turn in easier by effectively changing the rake and/or trail. I myself think the ninja has easy turn in, but can probably increase ease of turn in with different tires.
#20 | |
Solution to problem? Lean more.. I have had the pegs hitting ground around turns no problem.
#21 |
Yeah Nate could easily lose stability when changing geometry of the bike.
#22 |
Join Date: May 2009 Motorcycle(s): 2007 EX250 (street), 1994 EX250 (Race), 2008 250R (Race), 2000 250 (project), 1991 EL250 (a cruiser!) Posts: 287
If you're really interested in having true adjustability you can always try making or buying a turnbuckle style dog bone that has "infinite" adjustability.
#23 | |||
![]() Kelly, I don't think he is trying to compensate for the tires, but was merely answering another poster's question about which size he had / was planning on. Also, it seems he is raising the rear for the exact same reason you considered doing so (though you chose lowering the front instead): Quote:
And here is another quote of Kelly's explaining exactly why someone might want to do this: Quote:
I have been somewhat hesitant to make these changes, though. While I think it might be cool to have a more aggressive-riding bike for when I ride, I have had headshake on three occasions (all when slowing down on higher-speed curves on the highway) and I feel it would only be more likely with less rake. I know headshake is nothing to pee yourself over, but it is one step closer to a nice tank-slapper :P .
#24 |
I dunno I don't see the point. I rode my 250 pretty hard keeping up with the 600 + bikes and never had a problem. If anything I had a harder time keeping up on the straight aways than in the turns.
I'll note though my 600 turns like a dream compaired to the 250. The 600 wants the turn everytime, its no effort at all to get leaning into them.
#25 |
#26 |
I feel like that exactly explains the point of doing this.
#27 |
Well conidering the 600 has a completely different setup as far as rider position bike height and length not to meantion tire size and roll from lip to lip. These are all major factors in how the bike handles.
#28 |
kkim,
How low is your front end? I think I remember reading that you lowered your front end 1 1/2 inches.. I essentially want to do the same thing but I have lowered mine 7/8 of an inch in the front. I do not wish to lower it anymore as I do not want the forks sticking out any further. This is why I am looking to raise the rear end of the bike approximately 1/2 inch. |
#29 | |
Agreed! And I am not going to questions anything you have mentioned. But, my intention is to get the 250 to react a little more so like a supersport. I know it will never be one, but also experimenting with my first motorcycle and learning a lot along the way. I dont think I am doing anything to drastic (Im not raising the rear end 3 inches and lowering the front 3 inches). I do realize that every slight change does make a difference, and maybe I will stay with my front being lowered 22mm. Last futzed with by cbowman78; December 15th, 2010 at 09:07 PM. |
#30 |
Thanks for doing that! Its really appreciated!
#31 | |
#32 | |
Currently, the forks stick out one inch from the top of the triple clamp.. I would love to hear your feedback!!!! |
#33 |
if you're looking for a quicker turning bike, lower the front end.
I can't see trying to manufacture your own links to raise the back unless you are really good at fabrication, know how to properly design for the intended result and know your materials well enough to make the correct selection on what the needs are to support the entire rear section of the bike. The last thing I would want would be to be second guessing my choice of a home made link in the middle of a fast, high speed sweeping turn. ![]() the front end kits are pretty much proven to work w/o issues, so I would do that instead. On the other hand, if you add clipons, you wouldn't even need a front end lowering kit and can play with the amount of drop that works best for you. I wouldn't go too low with the forks, but I've had no clearance problems with the setup I have. Add a set of rearsets in addition to the clipons and the bike takes on an entirely new, sporty flavor that leaves you wondering how you lived without them once they've been installed. ![]() Not the best combo (clipons and rearsets) for the new rider as it's not the most friendly setup with regards to slow speed ergonomics and developing back muscles, but for a rider looking for a better/quicker turning and a more aggressive riding position to work from, it can't be beat. Last futzed with by kkim; December 15th, 2010 at 08:53 PM. |
#34 |
Well I think I will leave the rear end alone.
I have just installed Woodcraft Clipons and a set of the Cycle Control rear set adjuster plates. While installing the clipons, I lowered the front forks at the same time. I havent had the chance to ride it yet(Damn Canadian winters) but it feels a lot different sitting on the bike with those modifications. I will enjoy it as is.. Hopefully Santa brings me more goodies!!! ![]() |
#35 | |
Posted via Mobile Device Last futzed with by JMcDonald; December 15th, 2010 at 07:34 PM. |
#36 |
One more thought on raising the back end.
it can be done by using a slightly longer rear shock. I think Ducky installed a zx6 shock in his bike... yup, here it is. http://www.ninjette.org/forums/showthread.php?t=36055 |
#37 |
Ah, good to note.
FWIW, the stock links are just annealed hot-rolled steal (about the most basic steel you can get). Mine are made of the same stuff, and I've had them for maybe 3-4k miles with obviously no problems. I wouldn't trust drilling the hole as close as they did without a lot of testing to make sure they will hold up, but making a basic fixed-height link should not be any cause for worry.
DIY: Lowering the front end. Raising the Forks | zartan | 2008 - 2012 Ninja 250R Tech Talk | 102 | September 10th, 2021 05:55 PM |
Raising the tail? | ninja2007 | Ninjettes At Speed | 26 | September 10th, 2014 09:14 PM |
End tail cover thing (seat cowl) | reabo | 2008 - 2012 Ninja 250R Tech Talk | 7 | January 21st, 2013 09:51 AM |
Raising the seat/tail on a pregen (dogbones?) | CZroe | 1986 - 2007 Ninja 250R Tech Talk | 21 | July 3rd, 2012 12:31 PM |
[visordown.com] - BMF Tail End Show moves to Lincs | Ninjette Newsbot | Motorcycling News | 0 | August 4th, 2010 08:10 AM |
