Old April 9th, 2017, 05:11 PM   #1
Twisthem488
Twisthem488's Avatar
Motorcycle(s): 2009 Ninjette
Easiest way to remove the top clip from from the forks?
I need to change out the fork seals on my newgen, and hopefully stop the leaking that's occurring. Since I've never done it before I felt much more comfortable trying it with a spare set of forks, so I bought some old 2004 forks on the cheap to perform a trial run. So my forks came in and I prepared to take them apart. Everyone says breaking free the bolt that holds in the damper rod is the hardest part, but both of mine loosened up without to much fuss. My question is, how the frick do you take out the clip in the very top?
This might have an easy answer, since it would normally be done while the forks are still in the triple tree, and that way the are clamped down. Unfortunately since mine are a spare set they aren't clamped into anything.
Using the image below as a reference, I know that you have to press 44029 down and then try to pick out 92033A. The problem I'm having is that whenever I press on 44029, the spring itself just compresses and the cap never clears the clip that I need to remove.
IF the forks are not in the tripe tree, is there an easy way to do this part? Apart from this, everything about taking apart the forks that has intimidated me for the past couple years was really easy. Now my main concern is that removing the forks from the bike will be as painless.
Side note, I can't attest to the quality of these forks, and since its a learning experience I don't intend to put new seals/bushings/oil in them, but if anyone ever finds themselves nearby and wants them when I'm done, they are all yours. The buyer on ebay said they are straight and did not leak.
Twisthem488 is offline   Reply With Quote
Old April 9th, 2017, 05:16 PM   #2
It looks the same as my pregen. I just push the cap down with a big philips screwdriver that I hold down with my chin while I use a jeweler's screwdriver to get under the clip near one end, and grab it with something like tweezers or long nose pliers. Then I work the screwdriver around and help it out with the pliers gently as needed.
Old April 9th, 2017, 05:26 PM   #3
ducatiman
ducatiman's Avatar
Just did EX500 fork work this weekend...the owner assisted...a 2nd set of hands really helps...one to press downwards on the cap...the other to extract the circlip.
Easily done solo if the forks are assembled, a 2 jaw gear puller can be used to depress the cap, thus freeing hands for extraction.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old April 10th, 2017, 11:55 AM   #4
Twisthem488
That looks like a helpful tool Ducatiman. What does it grab onto since the fork tubes are smooth up top?
Old April 10th, 2017, 12:39 PM   #5
ducatiman
ducatiman's Avatar
"if the forks are assembled"....each jaw clips under the upper triple, the centerbolt then presses the cap
wiki pictures, info and options http://faq.ninja250.org/wiki/How_do_...aps/pistons%3F
Custom Carb Service
Old April 10th, 2017, 04:42 PM   #6
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
Autozone has a small 2/3-jaw puller in their loan-a-tool program that works great (as long as the forks are still mounted).
Old April 10th, 2017, 06:42 PM   #7
Twisthem488
I'm as blind as I am ugly
[QUOTE=InvisiBill]Thanks! I might take advantage of that for the real fork seal replacement since they will still be mounted in the bike. I don't mind buying tools that I'll use often or with broad application but those gear pullers seems to have a very limited role. Borrowing one sounds right up my alley.
Old April 11th, 2017, 07:36 PM   #8
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Motorcycle(s): '09 250 SE 'Booger'
Got a small wrench and small socket? This works better without the aftermarket clipons and using the other bolt hole but this shows how ive been doing it.
Dave Wolfe is offline   Reply With Quote
Old April 12th, 2017, 11:53 AM   #9
Twisthem488
Thats a neat trick.
Any suggestions if the forks aren't on the bike as is the case with my "trial" forks that I bought?
Old April 12th, 2017, 12:52 PM   #10
As I said above, I just push the cap down with a phillips screwriver and hold it with my chin, etc.. (post #2 above). If it's not in the bike, you'd need to support it firmly somehow, leaning it on something, getting a friend to hold it for you, etc.. If a friend is available, maybe you can even use him instead of your chin. It's not a difficult thing.
If the slider is moving up when you push down, you need to hold the fork tube while pushing the cap. Something like a rag wrapped around the tube and the whole thing in a vise, or tie it to a tree, or whatever else you can make work.
Old April 12th, 2017, 01:57 PM   #11
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Originally Posted by Twisthem488 View Post
Thats a neat trick.
Im thinking hose clamp some rubber material to the top of the upper fork tube, then use a two or three jaw puller hooked around the rubber/hose clamp? Or find a friend or two and manhandle the thing to submission. It doesnt take a lot of force with stock springs/spacers. You just need to somehow hold the upper tube while you press down on the cap. Otherwise you just compress the whole fork and the caps wont budge.
Old April 13th, 2017, 12:04 PM   #12
ck.mecha
Motorcycle(s): 1969 Benelli Cobra 125, 1970 Honda CB160, 2009 Kawasaki 250R
I keep a spare upper triple clamp to work on the forks off the bike. Not only will it allow you to remove the cap easier, but you can clamp the upper triple clamp to your table and use it as a holder for the fork tube. Better than a vice, no scratches.
ck.mecha is offline   Reply With Quote
Old April 14th, 2017, 02:22 PM   #13
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
That gear puller would offer the most stability and probably be the quickest way, especially if you intend to put stiffer springs in the tube.
TEAM ALFALFA
www.apexassassins.com
Old April 14th, 2017, 02:30 PM   #14
The Sonic springs I put in my pregen are much stiffer than stock, but do not have any more preload, so the clips are just as easy to remove as they were.
Old April 14th, 2017, 07:57 PM   #15
Twisthem488
Tangential to this thread, this brings up a good point: I weight 210 (but have lost 26 lbs in the last 3 months!) and have been looking at stiffer springs. Stock is apparently .65 and racetech suggest .80-.85. Would you say stiffer springs are a worthwhile investment since I'll have the forks open? Does your bike feel much different after the upgrade?
Thanks for all the help everyone! I'm looking forward to at least working on them this weekend XD
Old April 14th, 2017, 09:04 PM   #16
Since the OP has gotten several helpful posts to answer his question, I don't imagine some thread drift is harmful now.
I installed the Sonic springs per their instructions, and put a newgen rear shock+spring in the rear. Both the front and rear are similarly stiffer now, and well balanced with each other. Sonic recommends a lot of fork oil, and that amount makes it about impossible to get to full travel. I plan to experiment with that a bit.
The biggest differences so far are not bottoming out on modest bumps, and feeling noticeably more solid in curves. I didn't realize how much it was squatting in turns before, but it is more confidence inspiring now. That is, good handling has gotten better, and spirited turns are more relaxed. Last year on the Dragon, both my 115 lb daughter and I (175 lbs) had a few peg feeler scrapes. When it happened to me, I was hanging off pretty far, and was surprised to hear it. I'm pretty sure that won't happen next month when we again attend the annual 2-stroke meet there.
Old April 15th, 2017, 05:18 PM   #17
Ram Jet
Ram Jet's Avatar
Has anyone gotten rid of that silly O.E.M. snap ring and installed a proper snap ring that can be removed with snap ring pliers? When I change my fork oil I'm gonna try it.
Bill
Old April 15th, 2017, 05:29 PM   #18
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Bill
just get a $7 gear puller and use that to keep both hands free and you won't have to worry about the snap ring.
TEAM ALFALFA
Old April 15th, 2017, 05:34 PM   #19
I really don't see that the stock ring is particularly difficult to remove.
Old April 15th, 2017, 06:43 PM   #20
Twisthem488
Well I had some freetime today to look at it and realized that I made the problem a lot harder on myself. I Its much easier if the forks are still in the triple tree since then the stanchion is clamped down, but since I'm attempting this first on a spare set of forks before I do it for real I didn't have that luxury. It turns out that when I was pressing down on the top cap I needed to hold onto the stanchion, but my vital mistake was just pushing down on the cap and letting the spring/dampening rod compress, which puts far too much pressure on the cap. When I realized this I just held onto the stanchion with one hand was was fairly easily able to press down the cap with the other, but then I ran out of hands
I went through the link that Ducatiman posted again (which is different than the wiki entry I found for fork seal change and had some different info) and figured I'd try the screw trick. I drill a screw into my workbech about waist high, pressed the cap into it, and popped the clip and cap right out!
Thanks for the help everyone. I know that I am starting with limited knowledge and confidence, but I think that in the end I'll learn quite a bit. Until next time I have a stupid question
Old April 15th, 2017, 07:06 PM   #21
Excellent!
Old April 15th, 2017, 07:24 PM   #22
Ram Jet
Ram Jet's Avatar
"The only true wisdom is in knowing you know nothing." - Socrates
I'm 69 and still learning. As a friend of mine used to say "I taught you everything I know and ya still don't know nothin'."
Bill
Old April 20th, 2017, 04:16 PM   #23
InvisiBill
InvisiBill's Avatar
Another tip is just to bend the last few mm of the ring while you have it out. That gives you a little "tail" to grab next time you're taking things apart.
Old April 20th, 2017, 06:35 PM   #24
Ram Jet
Ram Jet's Avatar
Great idea! Sort of like some piston pin circlips. Less expensive than snap rings also. Thanks. What do I do with the new snap ring pliers I just bought?
Bill
Old April 20th, 2017, 07:30 PM   #25
You'll find out soon enough.
Clip-ons above the top triple tree indr 2008 - 2012 Ninja 250R Tech Talk 4 July 4th, 2013 08:39 AM
Easiest way to remove carbs? chadh92 1986 - 2007 Ninja 250R Tech Talk 22 April 9th, 2013 06:59 PM
Easiest Frame Sliders to Install? ajcadoo 2008 - 2012 Ninja 250R Tech Talk 4 February 22nd, 2012 12:30 AM
What is the easiest method to remove the special edition decal design off my bike? NinjaFLYBY General Motorcycling Discussion 7 March 23rd, 2011 04:12 PM
How high should the forks be above the top triple tree? Animal78 2008 - 2012 Ninja 250R Tech Talk 4 February 5th, 2011 05:33 PM
