July 21st, 2013, 07:27 PM | #1 |
new rider who needs advice on trip from today
Hey guys, so today I went riding alone for the first time from Jersey City Heights (Carlton) to Liberty State Park in NJ. Everything was going good until I got to the park. As I was engine braking and dropping my gears from third to first, I realized that my bike was no longer running and had shut down completely right before I stopped. I turned it back on fine and continued riding to another lot. Parked for about 2 hours and decided to get back on. As I was riding, and coming to a complete stop the same way as prior, I experienced the same problem. This time though, I couldn't get the bike to start again. My gas was decent; had about a galloon and a half. So, I called my friend and asked him to jump my bike with his portable charger. Once he connected it to my battery, the bike started right up and I was able to park it again. Once again, I didn't ride for a few hours and got back on and rode a block and the same issue happened once more. I pulled over, and jumped it with a car this time but it took about 30 minutes before I was able to get it running while having my chock all the way up and my tank on reserve. My exhaust was completely cold during this time; don't know if that effects anything but something I noticed. So basically what I'm asking is, has anyone experienced anything like this or have any advice on what I should do? I took off my battery and I'm going to charge it fully and will add gas next time I ride. Could it be wire problems, shortage, or flooding? Any advice will be great. Thanks
July 21st, 2013, 07:33 PM | #2 |
Try fully charging your battery and fill the tank up. Sounds like your battery may be going bad.
July 21st, 2013, 08:04 PM | #3 |
Welcome to our site, Juan !!!
Is your idle as high as 3000 when the engine is cold and the choke is open? Is the idle at ~1500 after the engine is warm? If so, take a look at this: http://faq.ninja250.org/wiki/Troubleshooting When trying to re-start the engine when it is warm, don't apply choke; rather, crack the throttle open while cranking.
July 22nd, 2013, 05:12 AM | #4 |
Sup Juan! I am with snake here.
Check the battery- is it maintenance free or is there many little caps to add water? Basically, add water if you need Battery terminals - tight & clean Have a battery charger? Charge the battery overnight. If you have no charger, time to buy one, your a bike owner!!! Ensure the gas cap vents are clean and clear too
July 22nd, 2013, 06:30 AM | #5 |
As already noted - check the battery. The fact that it started when you jumped it tells you that is most likely your problem.
Chances are you will need a new one if it isn't charged enough after a fair amount of riding to restart the bike. Also check your warm idle speed as Motofool noted, and get some fresh gas (87 - without ethanol if possible). It wouldn't hurt to add 1 oz per gal of Techron Concentrate fuel system cleaner. Check the inside of the tank to see if there is any amount of rust. Also check the air filter to make sure it's in decent shape. |
July 27th, 2013, 10:47 AM | #6 |
MSF Coach!
Join Date: Jun 2012 Motorcycle(s): 2003 ninja 250 Posts: 886
broken record time, battery.
buy a smart charger like a battery tender, DO NOT let shops charge it, ive lost 2 batteries because of workers who didnt know what they where doing. spend 30-40$ and save hundreds in the long run.
Hey Unregistered wanna ride the dragon? Ninjette group ride! May 16th-20th Join the Ride!!http://www.ninjette.org/forums/group.php?groupid=35 |
July 30th, 2013, 12:10 PM | #7 |
Wsup guys, sorry for the late response. So i finally got time to work on my bike and its running true again. I charged the battery and it starts fine with choke and stays on. Also, had to put gas and now its great. Thanks for all the advice. I will definitely use and recommend this site for any problems i have.
August 1st, 2013, 05:36 AM | #8 |
I had a similar problem with the bike stalling when coming to a stop. In short, it was because I had high test gas in there. Put regular and the problem went away.
Also, if it doesn't start with the choke, try it without the choke. It could be flooded. And yes, your battery also sounds weak. I hope that when you jumped the bike to the car that you turned the car off first. If not, then you will probably be needing a new voltage regulator too.
New rider-need some help/advice..bike keeps stalling | VQ35 | 1986 - 2007 Ninja 250R Tech Talk | 8 | June 6th, 2013 10:41 AM |
Looking at a bike today, advice on checklist. | OddlyOrdinary | General Motorcycling Discussion | 6 | October 11th, 2011 10:45 AM |
I gave Ben Spies some riding advice today! | algerath | General Motorcycling Discussion | 4 | August 28th, 2011 03:38 PM |
New Rider, need advice | Suave | 2008 - 2012 Ninja 250R Tech Talk | 14 | June 27th, 2011 12:09 AM |
Preparing for a trip. Needing some advice. | dubojr1 | General Motorcycling Discussion | 3 | June 7th, 2010 12:40 PM |
