December 9th, 2014, 09:21 PM | #1 |
Join Date: Jul 2010 Motorcycle(s): '08 Ninja 250R Posts: A lot.
MOTM - Oct '15
Artsy photos of my 250 engine rebuild
They be here, in chronological order. Thought I'd share, if in case you're into black and white photography....
http://thedandooligan.wordpress.com/...might-as-well/
My therapist has 2 wheels and a seat. If you are ever in doubt to my tone, please refer to my avatar. |
5 out of 5 members found this post helpful. |
December 9th, 2014, 09:30 PM | #2 |
December 10th, 2014, 02:11 AM | #3 |
Freedom for Germany
Well done
December 10th, 2014, 08:34 AM | #4 |
Track Clown
MOTM - Sep '15
nice!
December 10th, 2014, 08:59 AM | #5 |
December 10th, 2014, 09:05 PM | #7 |
ran when parked
Join Date: Aug 2013 Motorcycle(s): Freeride 250R, KLX250SF, mopeds Posts: A lot.
MOTM - Sep '17, Dec '14
Where's the step-by-step how-to?!
Thanks for sharing!
Instagram: @katie.baden |
December 11th, 2014, 02:08 PM | #8 |
Is that "oil pump gear" issue something to be concerned about if I change the clutch pack or plates?
December 28th, 2014, 08:48 AM | #9 |
Any idea how much weight is safe to take off the flywheel?
Did you deck the head? If so, how much did you take off and was your cam chain tensioner okay with taking the slack out? I'm likely swapping to a manual tensioner because my stock one allows a lot of the 'kawi tick'. Most importantly, do you have any good reading material for crank balancing? If I'm not 110% comfortable with it, I will leave all that stock. I just figure I'll read up on it now and see if there's anything I can do while it's apart. Like you say, while I'm in there, I might as well. |
December 28th, 2014, 12:45 PM | #10 | |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
December 28th, 2014, 01:47 PM | #12 | |
Mine's been ticking a while. A good long while. |
January 7th, 2015, 04:44 PM | #13 | ||
MOTM - Oct '15
Most of my previous how-to's are all on newninja.com, but this happened while that site got abandoned and I was completely burned out on riding - never thought it could happen, but it most certainly did, so unfortunately from the cylinder removal down I don't have any documentation.
No other mods to the head as I wanted to get a baseline for how much power the counter-balancer wasted. Crank-balancing should be done by a professional with a machine. You can do it by hand, the old school method, but since this is such a high revving engine it's best to use the technology available to do it right. To disable the counter balancer is a pretty involved process to, and would be best if you took the bottom end to a professional to balance the crank and eliminate the counter balancer. Found out the "kawi-tick" was the cam chain slapping the cylinder wall, and a second spot, much louder when it gets really bad, on the valve cover, so, get that tensioner in there ASAP.... Thanks for all the positive feedback.
Racer X engine rebuild. | Racer x | 1986 - 2007 Ninja 250R Tech Talk | 14 | April 21st, 2018 04:26 PM |
Engine Teardown and Rebuild | Rustitution | 1986 - 2007 Ninja 250R Tech Talk | 77 | February 27th, 2017 09:17 PM |
Need Help Oil,engine rebuild | meggyewill | 1986 - 2007 Ninja 250R Tech Talk | 10 | July 22nd, 2014 02:39 AM |
Engine Rebuild | FvnnyL3tt3r1ng | 1986 - 2007 Ninja 250R Tech Talk | 210 | November 2nd, 2013 07:16 PM |
Engine Rebuild Question | jayman87 | 1986 - 2007 Ninja 250R Tech Talk | 16 | December 21st, 2012 09:30 PM |
