April 9th, 2015, 04:27 PM | #1 |
Join Date: Jul 2013 Motorcycle(s): Green Ninja 250 2008!!!! Posts: 202
should I do intake or just rejet?
So I have an 08 and I bought it with a two Bros slip on and I've realized that I'm running lean and I also think I'm due a carb cleaning and new chain. So my main question is, should I also do an intake mod before I rejet? Is it important to do so or is it just more of a jetting hassle?
Any suggestions on jet kits or intake? I know factory pro and dynojet are the 250 favorites. Should I also synchronize my carbs? |
April 9th, 2015, 04:37 PM | #2 | ||
A very loaded questions, I'm not familiar with the NewGen airbox set up.
As far as jetting goes I'd go up one size on the mains, adjust the idle mixture screws, maybe shim the main needles if needed. But first start with a through and meticulous carburetor cleaning, and make sure all is right, make only one change at a time, be sure to set the float height as this is the most crucial and overlooked part. Here's some how-to guides Quote:
Any questions please feel free to ask
April 9th, 2015, 04:57 PM | #3 |
Thanks for all the info! So you think I should do all that with stock intake snorkel and all?
April 9th, 2015, 05:05 PM | #4 | ||
Here's my 2¢ Quote:
April 9th, 2015, 05:16 PM | #5 |
I'm looking for least hassle and least money spent so that the answer I was looking for :P keep the intake stock and clean the carbs sounds like a good first step to me, any idea what size jets I should look into? Stock is 98 and I'm looking to go 100+ correct?
April 9th, 2015, 05:33 PM | #6 |
One size at a time, I would advise small steps, and be sure to get OEM jets as aftermarket sizes don't follow the same sizing sometimes.
I also recommend getting a K&N drop in Air filter.
April 9th, 2015, 06:23 PM | #7 | |
April 9th, 2015, 06:58 PM | #8 |
April 10th, 2015, 05:51 AM | #10 |
Every time you make a mod you need to deal with fueling to get it right again. So do all the simple mods at once. When I got an AreaP full exhaust I did the following:
- Remove snorkel - Remove Kleen Air system (didn't get a block-off plate... just put a rubber cap over the breather and plug the remaining hoses) - K&N filter - Rejet This stuff is easy, not expensive and will work great. By the way... it's a good idea to keep what you take off for when you eventually sell the bike. It's a plus.
April 12th, 2015, 05:37 AM | #11 |
Wannabe Reborn
Search the forums for the jetting database where other riders have posted their exact setups (exhaust type, jetting settings, etc) so that you have an idea of where to start. It helps because if you buy a Stage 2 kit, but really need a Stage 3 kit, then your the proud owner of some parts you don't need....plus it takes some of the guesswork out. Understand that someone else's exact settings won't copy to your setup and make it perfect, it will get you close. Things to consider are ambient temperature, altitude, etc.
April 12th, 2015, 04:57 PM | #13 |
Very true Alex.s.
I personally would go up one size on the main jets, tune the idle mixture screws, then if necessary shim the main needles if needed. The carburetor mains are on the lean side from the factory, personally save your money and don't buy a jet kit IMHO.
April 12th, 2015, 06:48 PM | #14 | |
"Carbureted powersports vehicle manufacturers do not jet their carburetors perfectly, for two reasons. First, there are emissions considerations, mostly affecting the idle and midrange carburetor circuits. Consequently these circuits are jetted leaner than normal, and should be richened slightly for better performance. However, this rarely requires more than an adjustment to the idle mixture screw, and in some cases an adjusted slide needle height. Second, manufacturers ship their product to many different places across the globe. They purposely jet too rich on the main jet, the carburetor circuit that presents the most liability in terms of engine overheating. Therefore, all road-going powersports vehicles are jetted "fat" on the main jet. Contrary to what many people believe, but true nonetheless. Manufacturers do this because they cannot jet individually for each market, so they simply err on the rich side rather than the lean side, because the latter would present more problems. The fact is, engines are much more forgiving of a 3% rich condition than an equal lean condition, and just as importantly, few customers will notice a rich main jet, while nearly all will complain about a lean one." |
Time to rejet? | Felipe the Ant | 2008 - 2012 Ninja 250R Tech Talk | 14 | July 5th, 2011 09:15 PM |
Need help after rejet | hurttech | 2008 - 2012 Ninja 250R Tech Talk | 8 | April 11th, 2011 10:08 AM |
How to Rejet with Dynojet? | AtotheVzy | 2008 - 2012 Ninja 250R Tech Talk | 1 | October 15th, 2010 11:47 PM |
Do I need to rejet because of move?? | DsmRacing | 2008 - 2012 Ninja 250R Tech Talk | 4 | June 28th, 2009 11:02 PM |
Rejet?? Dyno jet? | tinng321 | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 9th, 2009 10:43 AM |
