October 26th, 2013, 08:20 PM | #1 |
Your face
Join Date: Jul 2013 Motorcycle(s): 2014 Honda CBR650f Posts: A lot.
Do you leave any fairing bolts off?
October 26th, 2013, 08:37 PM | #2 |
So, where's the reverse?
How are they annoying? Are they not catching the threads? Splain to me Lucy.
October 26th, 2013, 09:19 PM | #3 |
Your face
In order to put them back, I have to bend my arms in ways that they're not meant to bend. If they were bolts you just screwed in, that'd be fine and dandy. But they're not. I need to get the nut on the inside of the fairing so the bolt can catch. And it's not very fun
October 26th, 2013, 09:19 PM | #4 |
MOTM - Jan '18, Sep '13
I don't put bolts in because the rubber grommets rotted away and the holes won't hold bolts anymore lol.
ETA: I have none of the bolts that you're talking about on my bike Last futzed with by tfkrocks; October 27th, 2013 at 06:56 AM. |
October 26th, 2013, 09:48 PM | #5 |
I put those in on the street fairings on the ninja yes. However on other bikes and my R6, not so much. Zip ties are effin' awesome.
October 27th, 2013, 04:46 AM | #6 |
Wannabe Reborn
Know what you mean OP. I have one on each side instead of two, thats all the farther I could get my hand into the nose sections, through the handle bars, etc. Anyone know of a good fix for that, or the replacement parts for the rubber grommet with nut inside?
Thanks~
October 27th, 2013, 05:26 AM | #7 |
Join Date: Aug 2013 Motorcycle(s): 08 ninja 250r Posts: 93
yup OP, having only one of the two in won't hurt you. Those darn little rubber things keep falling off when i put the bike back together too.
October 27th, 2013, 06:20 AM | #8 |
Certified looney toon
MOTM Jul '13, Jul '14
Hurm, odd, those side ones catch easily for me. The two I hate putting back in are two plastic rivets on the bottom that connect the two lower cowlings. I've given up on the one in the front but the bottom two i futz with even though it's a PITA.
October 27th, 2013, 09:37 AM | #9 |
I gotcha. The rubber grommet holding the nut ripped on mine so the fairing bolt would never catch. I glued the rubber together but that only held up for one season.
October 27th, 2013, 01:55 PM | #10 |
Your face
I think what I'll do is glue the nuts in place on the inside. That way I won't have to reach into the front end of the fairing
October 27th, 2013, 04:18 PM | #11 |
Join Date: Sep 2013 Motorcycle(s): 09 Ninja 250 Posts: 13
All mine rotted. I have not replaced them.
October 27th, 2013, 04:21 PM | #12 |
All you need is to replace the wellnuts. The size.. I don't remember -- take the little bolts to the hardware store to find the [metric] thread size -- from there most wellnuts are standard sized off that.
October 27th, 2013, 04:25 PM | #13 |
I believe they are 5mm well nuts. I had some ordered at fastenal but I never got the call of them arriving. I have heard the Ace Hardware may have them. I have not made it out to that area to have a look. If I find them. I will post back.
October 27th, 2013, 04:28 PM | #14 |
#squid
Join Date: Jul 2011 Motorcycle(s): Track dedicated 2008 ZX6R Posts: A lot.
MOTM - Jul '16
Mine don't hold on the zx, and now something is buzzing, it's extremely annoying because I can't find the source.
October 27th, 2013, 05:43 PM | #15 |
Wannabe Reborn
Never thought of gluing them in. What type of glue do you think would hold the best?
If it's 5mmx1.0 thread, it's so close to a 10-32 thread that either or can be used. That's an if though. Sometimes those are easily available.
October 27th, 2013, 06:33 PM | #16 |
Your face
October 28th, 2013, 04:16 AM | #17 |
Wannabe Reborn
A quick search for 5mm wellnuts on eBay showed reasonable prices. $25 for an $18 with free shipping. Probably cheaper if you keep looking. Maybe those are better than what Kawi provides. Wonder if I could make some stainless threaded sleeves?
October 28th, 2013, 11:11 AM | #18 |
Your face
You should find out, then send me some if it's successful
"even a proper fitting helmet can 'get loose'" -csmith |
October 28th, 2013, 11:54 AM | #19 |
Wannabe Reborn
I have access to a lathe, and material, but to make 20-30 for a bike would be a far stretch. Would probably have to thread the exterior so that it would hold inside plastic hole, and put a shoulder on it. Over tightening would probably break the plastics. I tend to over design things.
October 29th, 2013, 12:52 AM | #20 | |
Your face
October 29th, 2013, 10:04 AM | #21 | |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
I also feel your pain with those bottom rivets. Very frustrating. |
October 31st, 2013, 08:30 PM | #22 | |
Your face
But when you're putting those bolts in (the ones I circled), you don't find it frustrating to maneuver your arms so you can get the nut on the inside of the fairing?
October 31st, 2013, 09:28 PM | #23 | |
Oh wait a minute, are you saying you don't have wellnuts behind them so have to reach in to hold a regular nut on the back side of the tab so that the bolt will screw in? If you still have the tab, maybe the cost of the wellnut would be worth removing the hassle. According to Kawasaki Parts House, it's this:
October 31st, 2013, 11:13 PM | #24 | |
Your face
Doesn't look like I have the right ones??
October 31st, 2013, 11:31 PM | #25 |
Looks like you have the right ones (that's definitely the right bolt) but it doesn't look like you have all of the wellnut. Maybe, as others have commented, something has happened to the rubber to prevent it from staying in the tab it's supposed to be in. Like it rotted, or dried out, or maybe was over tightened at some point. Dunno.
Your's kinda looks like these.. I'm going to guess over tightened and you are just left with the rubber part that holds the gold nut and not the rubber part that goes into the tab on the lower cowling.
November 1st, 2013, 08:27 AM | #26 |
Definitely. Sure looks like you don't have the right part, intact. I was confused about this whole thing as well, but several people chimed in with the same problem. I did realize at one point they all had '08s listed.
Fairing Bolts question | Alex | 2008 - 2012 Ninja 250R Tech Talk | 6 | April 15th, 2015 08:55 AM |
Fairing bolts | vhayduk | 2008 - 2012 Ninja 250R Tech Talk | 1 | December 3rd, 2013 09:04 AM |
7 fairing bolts and 3 windscreen bolts for pregen. | Monkeytofu | Free stuff! | 5 | November 29th, 2012 11:03 AM |
WTB PreGen Fairing bolts and other misc bolts | xlatinox | Items Wanted | 1 | June 8th, 2011 05:32 AM |
Fairing Bolts | nebraskan | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 18th, 2011 08:48 AM |
