Old May 7th, 2009, 10:35 PM   #1
headshrink
headshrink's Avatar
RAM on Steering Stem?
I'm working on a couple different solutions, but I wanted to check if one of these (pic to follow) mounts will fit on our bikes?
Old May 8th, 2009, 12:20 AM   #2
I don't think so, isn't that one designed for bikes with hollow steering stems? Ours is capped with the actual nut that you tighten.
Old May 8th, 2009, 12:52 AM   #3
headshrink
headshrink's Avatar
Thanks! You saved me $15 (plus shipping) and at trip to the mechanic to undo what I broke
Old May 8th, 2009, 12:58 AM   #4
I just use their standard u-bolt ram mount around the left handlebar, inboard of the left grip. Here's a link to pics of my GPS mount.
Old May 8th, 2009, 04:24 AM   #5
headshrink
headshrink's Avatar
I'm working on a little something I think you all will like (and copy)..... ordered more parts today, will see in about a week if it works
Old May 8th, 2009, 08:05 AM   #6
py2e
py2e's Avatar
Motorcycle(s): 2009 BLACK Kawasaki Ninja 250R
I have one that fits in that little screw hole near the levers (you gotta pop the cover off).
py2e is offline   Reply With Quote
Old May 8th, 2009, 10:59 AM   #7
headshrink
headshrink's Avatar
Gotta pic to share?
Old May 8th, 2009, 11:02 AM   #8
py2e
py2e's Avatar
http://www.theyeagergroup.com/ninja_250_RAM_Mount.htm
not my bike, but this is where I first saw it.
Old May 8th, 2009, 11:03 AM   #9
py2e
py2e's Avatar
I also have one for sale if you want. PM me if you're interested.
Old May 9th, 2009, 02:10 PM   #10
Techno250
bikeless n00b
Techno250's Avatar
Motorcycle(s): None yet. My dream machine is a BLUE 250R.
I freakin' love this forum.
>> fastest=[["green",510],["blue",475],["red",650]].sort{|a,b| a[1]<=>b[1]}[0][0].upcase;fastest
=> "BLUE"
Techno250 is offline   Reply With Quote
Old May 15th, 2009, 11:18 AM   #11
FroggyGreenInSD
FroggyGreenInSD's Avatar
Motorcycle(s): 08 Green 250, 12 Ninja 650 (also green, it's the fastest color!)
I just found this new RAM mount called the Motorcycle Twist and Tilt (RAM-B-360U). I mounted it to my left handlebar. See the pics attached. With the shortest arm they have, I can mount my Flip UltraHD just about where the center nut is. It's behind the windscreen so background noise is minimized. I'm trying to upload a video I took this morning to YouTube, if I'm successful I'll post a link.
FroggyGreenInSD is offline   Reply With Quote
Old May 15th, 2009, 11:22 AM   #12
I like it!
Old May 14th, 2011, 06:28 PM   #13
CantDecide
FroggyGreenInSD: When you used that mount, you have to take the lower bolt out of the handle-bar mount right? Does the replacement bolt still hold the handle bar in position well? Does the kit come with a spacer or anything to fill the recessed space and hold the mount where it belongs, or does it just hold it together with pressure?
Thanks!
CantDecide is offline   Reply With Quote
Old May 28th, 2014, 10:05 AM   #14
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
I'm bumping this as that Motorcycle Twist and Tilt (RAM-B-360U) is just freaking cool!
<-- Linky
Old May 28th, 2014, 03:07 PM   #15
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
How many gigs..errr..oh you're talking about the mount!
The Bike | The Truck
Old May 30th, 2014, 06:28 PM   #16
Gaorilla
Motorcycle(s): 09 Ninja 250
This is what you want to do for the ram mount:http://www.theyeagergroup.com/ninja_250_RAM_Mount.htm
Make sure you get (RAM part # RAM-B-349U) instead of the other one, otherwise you will have to rethread the hole on your motorcycle. it happened to me.
I installed it in my right side that way it will only cover the fuel gauge. After you install the one inch ball, the other pieces should fit with no problem.
Hope it helps.
Gaorilla is offline   Reply With Quote
Steering Stem Nut Tool Lemonfresh 2008 - 2012 Ninja 250R Tech Talk 5 April 5th, 2015 08:30 AM
Steering stem bearing justdrew 2008 - 2012 Ninja 250R Tech Talk 3 February 5th, 2015 07:57 AM
Steering stem bearings- Grease or no? MrSavvy 2008 - 2012 Ninja 250R Tech Talk 12 June 10th, 2014 07:06 PM
Tighten the steering stem nut, please tell me how coelgrim 2008 - 2012 Ninja 250R Tech Talk 23 December 29th, 2012 03:24 AM
steering stem nut snowfish 2008 - 2012 Ninja 250R Tech Talk 2 April 14th, 2010 07:12 AM
