March 17th, 2013, 08:53 PM | #1 |
Join Date: Feb 2013 Motorcycle(s): 1999 Ninja 250ex 1989 Ninja 250ex 2005 Ninja 250ex 2007 Ninja 250ex 2011 Ninja 250r 1993 CBR600 Posts: 199
Custom Race Day Mufflers and Fairings!
Hey guys I picked up a full set of fairings for $60 so I decided it would be cool to make some dedicated raceday fairings as well as modify my stock mufflers a bit aside from the already present baffle removal.
Here is a short video on the progress so far. I still have a lot of work to do and will happily keep you guys up to date should be done by tonight.
"I had so much fun crashing my Ninja" - Said by No One Ever |
March 17th, 2013, 08:56 PM | #2 |
Lol, that is cool but wondering if track day tech will have an issue with sharp points.
March 17th, 2013, 09:00 PM | #3 |
I was thinking the same thing so if they do they are only tacked on and can be ripped off if need be. But we also trimmed the points on the ends too to eliminate the previous sharp points. It was James Bond I'm going to slice you if you get to close status prior.
April 11th, 2013, 04:13 PM | #4 |
Garage Monkey
Join Date: Apr 2011 Motorcycle(s): 03 Ninjette Posts: 166
How did you go about the baffle delete
April 11th, 2013, 04:40 PM | #5 |
(Yes it is really this easy.)
Take a cut off wheel and hack the end of the muffler off then twist the baffle out. Some people will drill the rivets out for the back plate then attempt to remove the baffle so you can put it back together if you want but mine were too rusted to do so. besides they look much cooler if you hack them close to where the baffle meets the inner tray. My bike was rejetted because it does give you a bit more of flow just as a heads up. (ie mine was rejetted for pod filters and this actually seemed to give it a bit more kick after I hacked the mufflers.) Ohh and it is very loud. Sound quality changes too when you have them closer to the inner tray. It becomes less raspy (tinny sounding) which is nice. But the tinny sound wasn't bad actually gave it variance in sound from 0 to WOT rather than a deep sound throughout. Hope that gives you what you need! Goodluck!
April 12th, 2013, 02:06 AM | #6 |
Garage Monkey
so cut it off right behind the weld at the back side of the "cap" at the end of the can? I popped the rivets then beat it mercilessly trying to get one to pop out just to see if I would like more noise from the small engine... wether it lead to 2bro's or custom cans or whatever... if all else fails, M4 is local and the owner is a friend of a friend's friend or something so... *shrug* just really want to see what the twin 1/8th liter cylinders sound like screaming unleashed some, and want to compliment my pod filter mod as well.
Cannot believe how solid they are still on there with no rivets... I may put some penetrating oil on that end plte while I'm at work and take the torch to it if she hasn't loosened up... maybe bring home a pipe expander and use that to pull the core part of the tip out. |
April 12th, 2013, 02:25 AM | #7 | |
April 12th, 2013, 03:24 PM | #8 |
Join Date: Apr 2013 Motorcycle(s): 2004 Ninja 250 Posts: 465
A sound clip would be awesome when you have them installed!
April 12th, 2013, 04:21 PM | #9 |
Ahh I shoulda done that...they were only on the bike for a week and I crashed it so it is stripped down in my garage currently.
April 12th, 2013, 05:39 PM | #10 |
MOTM - Mar '13, Jun '14
Bombs would be OK but rockets would be cheating.
Mufflers | brenthedtke83 | 1986 - 2007 Ninja 250R Tech Talk | 3 | July 30th, 2013 08:49 AM |
Custom Fairings for pregens? | CalvinAmI | 1986 - 2007 Ninja 250R Farkles | 10 | June 10th, 2013 08:22 PM |
Mufflers within the headers? | JMcDonald | 2008 - 2012 Ninja 250R Tech Talk | 7 | August 8th, 2012 12:10 PM |
exhaust mufflers | james250ninja | 2008 - 2012 Ninja 250R Tech Talk | 1 | November 15th, 2011 11:17 AM |
mufflers sounds | james250ninja | 1986 - 2007 Ninja 250R Tech Talk | 2 | April 18th, 2010 08:57 PM |
