Old March 4th, 2016, 05:26 PM   #1
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
2014 concorse burnt +side battery cap
So the bike almost has 7k miles on it and last week it started flashing low batter volts at me. Well I take it on a ride and looking at the volts they stay at 14.2 this is normal. So I use it a few more times and then it starts flashing it once more so I figure the batter is going out even tho its less then a year old. Got the bike 5-1-15 ish so I pull out the battery and I find this?
Old March 4th, 2016, 05:28 PM   #2
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Loose connection? Was the screw tight?
It looks like it was loose and arcing.
Goin' fast on slow bikes!
Old March 4th, 2016, 05:30 PM   #3
^^^^ I feel the same thing
Old March 4th, 2016, 05:44 PM   #4
fishdip
fishdip's Avatar
I was think this also but it was on like extra tight.
Old March 4th, 2016, 06:01 PM   #5
Battery tender in top shape? It is that time of year and all, if in doubt check it with a meter. Since you got it open, you can also check the regulator as well to ensure the voltage coming back to the battery is within spec.
If not either of those things, check the main fuse and starter wires for looseness.
Old March 4th, 2016, 06:06 PM   #6
fishdip
fishdip's Avatar
Arizona no battery tender lol. The volt meter reads 12.6 volts on it. The bike is saying its at 12.4 I will need to test it with the bike running.
Old March 4th, 2016, 06:52 PM   #7
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Yup, this. Could be a bad R/R over volting the battery.
Or just simple a cruddy connection, although it looks clean!
Old March 5th, 2016, 01:20 AM   #8
fishdip
fishdip's Avatar
So I hooked up my hand held volt meter and went for a ride its keeping the battery at a set 14.6 volts but the volt meter on the dash reads 14.2
Old March 5th, 2016, 08:17 AM   #9
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
0.4 volt loss through all the wires and the circuitry in the display isn't bad. It's fine.
Your DMM may not be calibrated correctly either. I wouldn't worry about it.
Targa signal burnt out Tigerpaw 2013 - 2017 Ninja 300 Tech Talk 4 December 18th, 2013 04:00 PM
FS: Battery Tender 021-0128 Battery Tender Plus 12V Battery Charger (Automotive) tagg Amazon Postbot Amazon - Popular Motorcycling Items 0 April 23rd, 2013 04:52 PM
FS: Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger (Automotive) ta Amazon Postbot Amazon - Popular Motorcycling Items 0 April 23rd, 2013 04:52 PM
burnt chrome exhaust Rayme 2008 - 2012 Ninja 250R Tech Talk 15 February 24th, 2012 11:46 PM
Burnt leg on tail pipe Anthony_marr General Motorcycling Discussion 32 August 7th, 2009 11:53 PM
