#1 |
First fall from side stand
![]() I normally use the central stand. Yesterday I parked over grass and used the side stand, because it seemed to be more stable. Well,....the stand penetrated the dirt little by little and, ...swapppp!, to the ground my beloved 250 went. The bike has been naked for a while, so there was no damage to the fairing. However, the steel support for the left mirror got deformed, moving towards the front light. How could I re-bend the support, without breaking it to look symmetrical with the right side? Thanks |
#2 |
You risk breaking it if you bend it back. Just bend the other side to match.
#3 |
It's probably not all that noticeable so I would just leave it as is.
#4 |
MOTM - Mar '13, Jun '14
Heat
#5 | |
Join Date: Jan 2011 Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r Posts: A lot.
#6 |
Thanks guys.
I just updated my personal info. Yes, I thought about applying heat, but re-painting will have to follow. The deformation is severe, so, I don't think that the fairing will fit. Besides, the mirror has lost some range of adjustment. |
#7 |
If it bent out of shape without heat, then it can bend back. A vice may be helpful. Heat can cause damage to the joint or possibly crack the mirror. Beating on it to straighten it also runs the risk of cracking the glass. If all else fails, ebay sells a bunch of them fairly reasonable.
Ninja Mirrors on Ebay |
Side stand switch | geeker | 2013 - 2017 Ninja 300 Tech Talk | 17 | October 21st, 2012 08:27 PM |
Side stand spring came off on a freeway... | RedOctober | 2008 - 2012 Ninja 250R Tech Talk | 3 | March 13th, 2012 08:05 PM |
Proper bike rake/lean on side stand? | Swampotter | 2008 - 2012 Ninja 250R Tech Talk | 5 | September 4th, 2011 11:03 AM |
side stand set aside | Ntotot | General Motorcycling Discussion | 19 | September 10th, 2009 08:30 PM |
