Old January 5th, 2014, 03:09 PM   #1
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
2009 r6 winter project
So.. there's a lot of things that needed to be fixed and upgraded and after cursing at the bike for hours when we changed the spark plugs we decided the motor was going to come out for the valve adjustment. Forks are getting new fluid. New sprockets and chain. Plastics are being repaired and painted. Adjustments are being made to various cables and what not. Cats were taken out of the exhaust pipe. I'm sure there is some other stuff but that's the gist of it.
Yesterday we stopped right before the engine removal because we didn't have a socket big enough for the sprocket (30mm for those who care). And today we stopped just short of adjusting the valves because the feeler gauge could only go to .203 and we need one that goes down to .1
Old January 5th, 2014, 03:19 PM   #2
Have the ecu flashed while you got it torn down.
Remove throttle limit
Choose a map based on the gas you wanna run
Enable the built in quick shifter
Make the speedo accurate
ect... ect...
go go go!
Old January 5th, 2014, 03:21 PM   #3
My buddy OhioYj does this. If you send him the ecu lemme know, and I will watch the flash personally.
http://www.r6-forum.com/forums/showt...331&highlight=
Old January 5th, 2014, 03:23 PM   #4
TnNinjaGirl
Ms. Personality
@csmith12 OMG thank you!!! You read my mind. Oh and how much$$
Old January 5th, 2014, 03:26 PM   #5
TnNinjaGirl
Ms. Personality
And I also need to chat with someone about the fork oil and adjustments.
Old January 5th, 2014, 04:00 PM   #6
Well, I believe he does these for free + cost of shipping (USPS flat rate). If not, lemme know and I will chat with him about a referral.
What questions do you have? There are a few of us "more serious" r6 riders on this forum.
Old January 5th, 2014, 04:30 PM   #7
TnNinjaGirl
Ms. Personality
From what I understand the stock oil weight is Yamaha 0wt which is equal to every aftermarket oil 5wt. He had his suspension set up and the low speed compression is 3 clicks and the high speed compression is 2 clicks on the front fork. The tuner said he needed new oil. The question is: Should I put stock 5wt/yam0wt or put 7.5w or even 10wt in them and reset the dials up front.
He doesn't really wheelie. He's ~170lbs with full gear and most of his riding is advanced twisties. When I rode it I felt like the front end dove and didn't stick well in corners. That's what makes me think the weight needs to go up. Or maybe the original oil is that degraded? The rear end feels planted if not a little soft as well.
Either way I'd be curious to see what a few other's spec sheets look like because his is all over the place.
Old January 6th, 2014, 03:33 PM   #8
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
Dang. that's a lot of work for a valve adjustment. haha. I did my valve check over my Christmas break. Just pulled the throttle body assembly and radiator and it was easy.
The www.ModMy250.com guy
Old January 6th, 2014, 03:40 PM   #9
haha. you took the engine out just to do the valves? pretty funny. sure is easier when the engine's out isn't it? it's a nice bike but those mirrors are hideous.
Old January 8th, 2014, 08:49 AM   #10
TnNinjaGirl
Ms. Personality
Valves checked in spec. Next project is to do the fork oil.
Old January 8th, 2014, 09:42 AM   #11
Suspension can be a moving target sometimes. As the rider's wants and needs from the bike changes over time. At 170lbs, I would say to stick with the stock oil weight unless there are some custom valves installed or future plans to race.
What are his preferred sag numbers and do you think they need to be changed?
If a 250 rider thinks the forks dive and the owner/rider agrees, then it sounds like the sag measures can go a bit tighter, ie add more preload. Different riders might shoot for different numbers even on identical bikes. What are the preload lines set at? For example, mine are at 3 for spirited paced street rides and track time.
So 2 clicks out on the low speed seems ok. How many turns out on the high speed (12mm nut)? There are no clicks on the high speed, just have to count turns. This is most likely what you need to adjust (assuming your preload is good).
Old January 8th, 2014, 09:53 AM   #12
Remember to write your current settings down before changing anything.
Old January 8th, 2014, 10:09 AM   #13
TnNinjaGirl
Ms. Personality
It was originally set up by a professional. Settings are written down. 31mm sag 15 turns on the high speed.
It feels iffy in the corners and nose dives like a mofo
My 250 with RaceTech and new fork oil felt much better than this thing does.
I'm hesitant to move it up to 10wt oil because he really doesn't ride the bike really hard right now. When he starts going to the track (trying to convince him to get a 250 for the track instead) I might move him to 10wt oil. He's also losing weight which makes me want to stay with 5wt. Not that it is hard to change if we need to.
Either way the bike is set up to what seems to be common settings for his weight and I feel like it is very plush (I weigh a tad less than he does). I'm at a loss.
Old January 8th, 2014, 10:12 AM   #14
WTF 15!!! 15 full turns or quarter turns? If they are full turns there is your problem. lol
Old January 8th, 2014, 10:15 AM   #15
That would make sense. No sense getting beat to death, so let the suspension eat up all those bumps. My setup is a bit rough at a street pace but is butta smuve at track pace.
Old January 8th, 2014, 10:17 AM   #16
cuong-nutz
cuong-nutz's Avatar
HalfFast Racing Team
Last futzed with by cuong-nutz; January 8th, 2014 at 10:18 AM. Reason: too slow of a response. will have to read the posts above lol
Old January 8th, 2014, 10:22 AM   #17
TnNinjaGirl
Ms. Personality
What are your settings including fork oil weight? Front and rear.
Old January 8th, 2014, 10:39 AM   #18
I will have to dig up my paperwork or recheck everything. But I did run out and check my high and low speed settings on the forks.
Low speed - 4 clicks out
High speed - 2 turns out (complete revolutions of the 12mm nut)
Dayummmm... it's cold in my garage.
Old January 8th, 2014, 10:41 AM   #19
cuong-nutz
cuong-nutz's Avatar
How many miles are on the bike? Might just need new oil. If the oils dark, then it's time for an oil change.
How much suspension travel you are using?
Back off the high speed compression and see how it feels.
Old January 8th, 2014, 10:45 AM   #20
TnNinjaGirl
Ms. Personality
Thanks Chris. When I get home I'll double check everything.
The roads here are smoother than some track surfaces.
I'll measure how much of the travel is being used. I want to say there is 3-4 inches at the bottom. Once again, I'll double check everything in a few hours.
Old January 8th, 2014, 10:59 AM   #21
3-4 inches at the bottom? Yep, he rides her easy.
Old January 8th, 2014, 03:59 PM   #22
TnNinjaGirl
Ms. Personality
Sag: (Front 34) (Rear 31)
Compression: (Front High 2) (Front Low 3) (Rear High 2.5) (Rear Low 13)
Rebound: (Front 10) (Rear 7)
Travel: (1.5" left at bottom)
Old January 8th, 2014, 04:09 PM   #23
How many lines of front preload?
Rider depending... those settings are within "go real fast" range. Is it safe to assume that the oil wasn't checked when the baseline was done a while bike? Let's see what the oil looks like, change it out if needed and kinda go from there.
I will hit my garage to find my paperwork or recheck everything and write it down, again.... lol
Old January 9th, 2014, 07:06 AM   #24
TnNinjaGirl
Ms. Personality
Ugh. I guess I'll have to check the preload tonight and the oil as well.
They may very well in the "go fast" settings but it feels scary when you are going fast, especially if you have to stop at any point in time. He doesn't really care how it feels but I tend to like a much stiffer ride.
Suck it up Chris it's supposed to be "warm" today. haha
Old January 9th, 2014, 07:30 AM   #25
Heading to the garage in about an hour. In the mean time, give this a quick read. It gets straight to the point without a lot of fluff. The only thing it kinda leaves out is rear rebound in the braking zone.
A thing that I learned when doing suspension setups is that sometimes multiple/compound adjustments need to be made to achieve the "feel" a rider is after but nearly everything I read said to only change one thing at a time. So I got a workbook and kept a running log of changes. Here is an example;
8/15/2010 - Front: Preload=2, HSC=3, LSC=4, RE=10 Rear: No Change (initial settings)
8/19/2010 - Front: Preload=2, HSC=2, LSC=3, RE=12 Rear: No Change (felt mushy while hard on brakes, not planted on corner entry)
8/20/2010 - Front: Preload=3, HSC=3, LSC=2, RE=12 Rear: No Change (felt better on entry, still not quite)
9/15/2010 - Front: Preload=3, HSC=3, LSC=4, RE=12 Rear: No Change (felt even better on entry, just a bit of dive on initial bite of brakes)
9/15/2010 - Front: Preload=3, HSC=2, LSC=4, RE=12 Rear: No Change (dats da spot! but rear chatters a bit, needs a bit more rebound)
Doing it like this allows you to return to any time/spot in your adjustments.
Last futzed with by csmith12; January 9th, 2014 at 08:45 AM.
Old January 9th, 2014, 07:31 AM   #26
That's what she said.
Old January 9th, 2014, 11:34 AM   #27
TnNinjaGirl
Ms. Personality
Really?
Old January 9th, 2014, 12:16 PM   #28
Really?
Sorry, just havin' a bit of fun.
Anyway, went out to the garage like I promised. Here are my complete settings.
Front: OEM Forks
Sag: 35mm
Preload: 3 lines
Rebound: 7 clicks out
NOTE MY OEM SHOCK IS DIFFERENT THAN YOURS, in respect to the high and low speed compression adjusters
Rear: OEM Shock
Sag: 27mm
Ramp Preload: Topped out
Low speed: 15 clicks out
High speed: 7 clicks out (right at 2 turns)
Old January 9th, 2014, 12:20 PM   #29
Oh, on stock weight oil too. 195lbs (give or take a few lbs) fully geared.
Old January 9th, 2014, 12:30 PM   #30
TnNinjaGirl
Ms. Personality
haha get on your knees and check those settings!
Thanks for checking those settings. On first look they look similarishly closeish to his settings. Also I think I'm going to refer to it as my r6 because I do all the work on it and I like it. Anywho you weigh a wee bit more so I suspect the settings should be different.
Signs are pointing back to bad oil so I had him pick up some for oil for my r6 on his way over. I guess we will be doing fork fluid tonight. w00t
Old January 9th, 2014, 12:51 PM   #31
Yep, on my knees in the cold to help you out but for my benefit too, since I can't find my workbook.
Claim that bike!
Also, even though my weight is a bit more. 20lbs or so isn't gunna effect the settings all that much. It's much more about corner speed and how aggressive you are with the brakes and throttle. Those forces are much more than the 20 or so lbs.
Another MAJOR factor is tire pressure but we will get to that later but +1 on the Michelin/Yami combo. There isn't much better.
Old January 9th, 2014, 02:45 PM   #32
TnNinjaGirl
Ms. Personality
Should I start one of those posts like you do about physics and at a given velocity and/or change of velocity 20 pounds carries substantially more energy. Blah blah boring blah go make me a sammich blah blah
Headed home here in a bit. Got a report that my YZ was wrecked a couple of times... friggin friends.. I'll get to the r6 suspension and report the oil condition.
Old January 9th, 2014, 04:25 PM   #33
You will hear no physics from me young lady. This is about as close to physics as I get.
Old January 9th, 2014, 06:31 PM   #34
^^ Totally legit. No physics lectures from my corners on that one.
Old January 11th, 2014, 04:31 PM   #35
TnNinjaGirl
Ms. Personality
Sooooo... The fork oil was toast...
Old January 12th, 2014, 09:36 AM   #36
Hopefully fresh oil will make the front feel better. May make the rear feel even worse though. Watcha gunna do if that is the case?
Old January 12th, 2014, 11:47 AM   #37
TnNinjaGirl
Ms. Personality
Since it's not my money to spend.... Penske!!
Old January 13th, 2014, 09:42 AM   #38
TnNinjaGirl
Ms. Personality
Putting her back together. Honestly it was easier to put the engine back in than I thought it would be. We basically put the engine on a cart and lowered the frame onto the engine. Repacked the bearings. Cleaned as we went along. The rearsets are being painted and the exhaust was painted. We also added an LED in the front thing (I don't know what it is called).
The main things we are waiting on are:
front tire
chain
sprockets
ECU
plastics
Pretty excited to see this gal taking shape again. Hopefully it starts on the first try and the suspension feels better with this new oil in it.
Old January 13th, 2014, 02:11 PM   #39
Cool progress! What oil did you go with?
Old January 13th, 2014, 02:26 PM   #40
TnNinjaGirl
Ms. Personality
Ended up using Bel Ray 5wt. Guess I'll see how it goes. I guess if we need to we can change it. I've gotten pretty good at taking this thing apart and putting it back together.
I should be tearing into my 250 soon. In between I'm supposed to be working on an '06 636 track bike. I should start a shop...
winter project almost complete justopelt 1986 - 2007 Ninja 250R Farkles 10 May 5th, 2014 02:00 AM
2012 Ninja 250r SE - Winter Project...Streetfighter Version. SuperAmp13 2008 - 2012 Ninja 250R Farkles 6 April 3rd, 2014 04:34 PM
Winter project; 250 engine enko11 2008 - 2012 Ninja 250R Tech Talk 8 March 29th, 2013 01:43 PM
iPhone/iPod Dashboard - Winter project binlagin 2008 - 2012 Ninja 250R Farkles 47 September 13th, 2010 05:55 AM
My Winter Project maxedpenny 2008 - 2012 Ninja 250R Farkles 51 March 11th, 2009 05:09 PM
