Old January 7th, 2015, 09:32 PM   #1
double1185
Motorcycle(s): ninja 250R 2009
Unhappy Please help!
Hi everyone
Firstly my English is not very good yet I try my best to describe the situation
I got a 09 Ninja made in Thailand with FI, I have the wheels replaced with Pirelli Diablo Rosso ii 120/60/17 front and 150/60/17 back. It was really great during cornering and boost my confidence so much, yet about a week a go when i took a left-U-turn (to change direction) I scratched at about 50 kmh since I have a frame slider everything seem fine to me, no significant scratch on the fairing, but start from then the bike feel very off-balanced, when I ride with no hand, the bike seem to lean to the left, the problem seem to only occur when i ride up to 50kmh, above that, it seem to be much less worse.
I went to 2 different service shops, I had my rear wheel check for pressure, balance, the chain checked for if it too tight or too loose, no problem at all, and the guys at the shops all said that my front forks need to be balanced (i dont know the word but basically they make them straight again) the thing is after they did straightened them, at start it seemed ok but after few hours riding the problem occured and seem worse. In Vietnam where i stay we dont have real professional guy for Ninjas and big bikes (it pretty much all honda, yamaha and most of them are just 150cc under). So after 2 tries with the mechanics here, I guessed they r not good enough and I'm pretty much on my own, so please guide me what could cause this kind of problem and how to fix them. Many thanks
double1185 is offline   Reply With Quote
Old January 7th, 2015, 09:39 PM   #2
Sorry to hear Yen, I hope you are fine after the down.
This is the info you're after. I know it's for the 07 and earlier models but will work just the same for your bike. I am hoping you don't have any fork tubes bent.
Best of luck getting everything straightened out, it's a pretty easy job.
Also, Welcome to Ninjette!
Old January 7th, 2015, 09:46 PM   #3
double1185
Thank for ur help, I guess I just go with the alignment again, btw, when the mechanic take my front fork, he showed me a thing look like a round disc with small steel ball cover in oil (?), there are a quite long scratch on its surface he said that it may affect the steering, I'm trying to purchase the replacement on ebay but I cant find the exact word for it to search, please help!
Old January 7th, 2015, 10:09 PM   #4
Ghostt
Ghostt's Avatar
Look at the pictures, can you find the part your looking for?
violente et ignorantia
ZX-2R BLOG
Old January 8th, 2015, 05:11 AM   #5
double1185
Thanks, i will go to a services mechanic to see what part number it is
Old January 8th, 2015, 05:42 AM   #6
SteveL
old git
SteveL's Avatar
Motorcycle(s): BMW K1300S
You did not say if the front wheel came to rest against a curb or other solid object, it does not take much to bend or misalign the forks or triple tree. One thing to do is check the height of the fork tubes against the triple tree top they should be the same look to see if the handle bars and wheel are aligned. If all this is OK lift the front of the bike and remove the front wheel if there is misalignment it will be difficult to reinsert the front axle.
Good luck Steve
Some mistakes are too much fun to make only once.
SteveL is offline   Reply With Quote
