August 17th, 2015, 04:56 PM | #1 | |
Join Date: Aug 2015 Motorcycle(s): 2011 Ninja ex250r Posts: 8
Can not remove the front sprocket guard
Hello, I'm new to the forum and what brought me here was an issue I can not fix. I will include pictures and possibly a video.
To sum up my problem and how it happened; my chain snapped while riding and it chipped my sprockets,caused countless other collateral issues. But I was fine. My bike not so fortunate. I can not remove the front sprocket cover, even after removing the 3 bolts holding it in place. It will not budge even after striking it with wood trying to loosen it up. Tl;Dr my bikes chain snaped, I can't remove the front sprocket cover. I will add pictures in the comments if possible. Edit: it's a 2011 ninja ex250r Link to youtube video of the problem since it wont let me post it: https://www.youtube.com/watch?v=oM38ne3oPGg SOLUTION: Quote:
Last futzed with by ieoz; August 19th, 2015 at 01:53 AM. |
August 17th, 2015, 06:27 PM | #2 |
Certified looney toon
MOTM Jul '13, Jul '14
On mine it was the gunk basically acting like epoxy.
I wedged a thick standard screwdriver between the cover and whatever I could brace it against (frame, shifter, engine) and just gently pried it all the way around the cover. Eventually it broke loose enough I could pull the cover off. Light taps on the handle by a hammer also helped me.
August 17th, 2015, 07:01 PM | #3 |
Common problem, due to the pins part#92043, which there are two of them.
NevadaWolf is right on how to get it off.
August 17th, 2015, 07:33 PM | #4 |
Wannabe Reborn
OP, wasn't mentioned, but just to be clear, you removed the shift lever correct?
August 17th, 2015, 07:47 PM | #5 | |
Front sprocket noise | ChaoSS | 2008 - 2012 Ninja 250R Tech Talk | 9 | November 30th, 2012 04:42 AM |
Do you need to remove the front fairings to do a valve adjustment? | Monkeytofu | 1986 - 2007 Ninja 250R Tech Talk | 15 | September 11th, 2012 05:41 PM |
Front Sprocket | Archerzz | 1986 - 2007 Ninja 250R Tech Talk | 66 | June 29th, 2011 10:22 AM |
Front sprocket, help!! | cbowman78 | 2008 - 2012 Ninja 250R Tech Talk | 34 | November 14th, 2010 10:52 AM |
front sprocket | miniguns167 | 2008 - 2012 Ninja 250R Tech Talk | 4 | September 27th, 2009 11:59 AM |
