Old October 19th, 2010, 06:00 AM   #1
cbowman78
cbowman78's Avatar
Front sprocket, help!!
Hey guys and gals.
I know a lot of people have used the 15T sprocket to help bring the RPM down a little on the highway as well as making first gear a little more useful. What sprocket are you using as I have viewed the JT Sprocket website and they do not make a 15T for this model (08-10 250r). I dcided to use this sprocket once I ordered my R-0990 filter and Factory Pro Jet Kit.
http://www.jtsprockets.com/52.0.html...sel_uid=963&p=
I have searched and have found no definitive answer. If you have done this sprocket swap, I would love to hear which one you used. Also, can I still use the factory chain or does that need to be replaced as well?
Thanks in advance!!!
cbowman78 is offline   Reply With Quote
Old October 19th, 2010, 06:02 AM   #2
cbowman78
cbowman78's Avatar
Originally Posted by cbowman78 View Post
Hey guys and gals.
Duhhh! Just found this.. http://www.ninjette.org/forums/showthread.php?t=55430
Can anyone else that has done this swap that has a full exhaust, R-0990 filter and jetting inform me how their bike performs now compared to when it was stock? I do not want to slow the bike down with a 15T sprocket, I am hoping that the additional power from the above mentioned mods will over come that and make the top end a little better.
Old October 19th, 2010, 06:09 AM   #3
want1sobad
Ninjette CPT
want1sobad's Avatar
Motorcycle(s): Black 08 250r
factory chain is fine.
here is the sprocket you need:
http://www.motorcycle-superstore.com...-Sprocket.aspx
want1sobad is offline   Reply With Quote
Old October 19th, 2010, 06:18 AM   #4
cbowman78
cbowman78's Avatar
Hey want1sobad,
The link you attached is asking me for what model, year, etc. When I click on Kawasaki 250r, it only goes up to 2007? Am I missing something?
Old October 19th, 2010, 06:21 AM   #5
want1sobad
Ninjette CPT
want1sobad's Avatar
pre-gen and new-gen are interchangable. pre-gen is what you want, (order the 07').
ride happy
Old October 19th, 2010, 06:23 AM   #6
cbowman78
cbowman78's Avatar
Thanks for clearing that up! Much appreciated!!
Does anyone have any input on the 15T swap after riding with it?
Old October 19th, 2010, 06:28 AM   #7
want1sobad
Ninjette CPT
want1sobad's Avatar
happy reading
http://www.ninjette.org/forums/showt...=sprocket+swap
"search" is your friend......
btw, welcome to the forum
Old October 19th, 2010, 06:43 AM   #8
dubojr1
dubojr1's Avatar
Careful which one is ordered. MCSS doesn't show me a part #. Seems their website is not working for me right now. One has to be shimmed and one does not. Here's a link to one that doesn't require any shimmimg.
http://www.denniskirk.com/jsp/tpl/pr...=p80985&mmyId=
Old October 19th, 2010, 06:45 AM   #9
want1sobad
Ninjette CPT
want1sobad's Avatar
jd,
the '07 JT is the one we installed on mine.....
Old October 19th, 2010, 06:48 AM   #10
dubojr1
dubojr1's Avatar
jd,
Yeah I figured since it was the one you were recommending. The DK site actually shows the one I linked to fit the pre-gens also. Just wanted to make sure the part # was verified prior to him ordering.
Old October 19th, 2010, 11:54 AM   #11
randomwalk101
self wrencher
randomwalk101's Avatar
those are parts # for the old gen...
new gen the thickness is 9.3mm...
old gens the thickness is 8.8mm or 8.3mm...
So to get it PERFECT, you need a shim. Some run without shim...but they're not perfect
Old October 19th, 2010, 12:17 PM   #12
dubojr1
dubojr1's Avatar
Hmm... I may need to double-check myself I guess.
Old October 19th, 2010, 12:23 PM   #13
dubojr1
dubojr1's Avatar
Damn it... Looks like you are right.
http://www.jtsprockets.com/52.0.html...el_uid=5001&p=
Time to look for a shim I guess.
Old October 19th, 2010, 01:22 PM   #14
HKr1
IC2(SW)
HKr1's Avatar
http://www.kneedraggers.com/product/...aki-Ninja-250R
Old October 19th, 2010, 01:50 PM   #15
randomwalk101
self wrencher
^^ If I buy any, I would check part # against JT's website to be sure...cuz pre-gens will fit...just diff thickness...unless you use shim of course.
Old October 19th, 2010, 02:55 PM   #16
dubojr1
dubojr1's Avatar
I wonder if 1/2 a mm could really matter. My bike seems perfect...
Old October 19th, 2010, 03:06 PM   #17
Originally Posted by dubojr1 View Post
My bike seems almost perfect...
Old October 19th, 2010, 03:15 PM   #18
dubojr1
dubojr1's Avatar
Originally Posted by Alex View Post
Ok...ok...
Anyone know where I can find a shim. My guess is it will be a $.42 part with $9 to ship.
Old October 19th, 2010, 03:45 PM   #19
headshrink
headshrink's Avatar
http://www.cheapcycleparts.com/model...semblies/25721
or
http://www.bikebandit.com/houseofmot...-250r/o/m17215
Part# 92200A-1389 (92200A is the common part number both retailers use - I think the full number is the "official" number).
This is a splined washer that is used inside your transmission, but is also the perfect shim (also what I use).
Old October 19th, 2010, 05:36 PM   #20
dubojr1
dubojr1's Avatar
or
Couple problems...
1. Part listing only says "washer" How thick is it?
2. Part is on back-order
3. $15 for a washer... Maybe a new sprocket would be better
Old October 19th, 2010, 09:22 PM   #21
randomwalk101
self wrencher
If I were doing it I'd buy it from local dealer for a buck or so. But if I install it already I wouldn't worry it. Def not going to pay $9 for shipping.
Old October 19th, 2010, 11:20 PM   #22
headshrink
headshrink's Avatar
Couple problems...
1) Yes, it does call it a "washer," but it is nice that it is splined because it fits the shaft nicely. It is 1mm thick.
2) I know, it sucks.... I'm waiting on a break rotor, which isn't due until mid Dec.
3) It is insane what you pay for shipping for these little nothing parts, which is why it is usually best to wait until you have a substantial shippment, or use it as an excuse to buy a nice tool or accessory to justify shipping. And yes, it would be ideal to get the sprocket that is specific to the '08+, but if you are unable to get your hands on one and have to go with the pre-gen model, shoot me a PM... I'll hook you up.
Old October 19th, 2010, 11:33 PM   #23
vnranger
vnranger's Avatar
Motorcycle(s): Candy Thunder blue 2009 kawasaki 250r, 2010 Dark Stealth Ducati Monster 696.
I bought mine from here: http://www.solomotoparts.com/product...cat=319&page=1
it was same thickness as stock sprocket(measured with caliper), installed and worked perfect without any shim or washher .
vnranger is offline   Reply With Quote
Old October 20th, 2010, 05:35 AM   #24
dubojr1
dubojr1's Avatar
1)3) It is insane what you pay for shipping for these little nothing parts, which is why it is usually best to wait until you have a substantial shippment, or use it as an excuse to buy a nice tool or accessory to justify shipping. And yes, it would be ideal to get the sprocket that is specific to the '08+, but if you are unable to get your hands on one and have to go with the pre-gen model, shoot me a PM... I'll hook you up.
Does this mean you have a used pre-gen 15T available or you have the shim? I'm thinking at this point the shim is not the best solution either. Adding a 1mm shim still would have the "perfect" setup off by 1/2 a mm.
Old October 20th, 2010, 06:09 AM   #25
cbowman78
cbowman78's Avatar
I think I am just going to buy the 43T rear sprocket that JT offers for the 08-up Ninjas.
I dont want to worry whether I have to shim or not..
Thanks for all the input.
Old October 20th, 2010, 06:31 AM   #26
dubojr1
dubojr1's Avatar
That will cost much more.
Old October 20th, 2010, 08:11 AM   #27
almost40
ninjette.org Monkey Spank
almost40's Avatar
Swapping a 42T in the rear is the closest to a 15T front.
If your planning on fully modding the bike as described and you weigh less than 150 lbs a 41T is the fastest in the quarter mile. 175 lbs i would run a 42T. 200 lbs and I would run the 43T for the 1/4.
Black 250R
Full Area P QC
Old October 20th, 2010, 09:37 AM   #28
headshrink
headshrink's Avatar
I have extra shims.
Old October 20th, 2010, 11:46 AM   #29
cbowman78
cbowman78's Avatar
Thumbs up
Still researching this...
Actually, a 1mm shim would be almost factory spec. The 08-up front sprocket is 9.3mm thick, while the pre-gen is 8.5mm thick. So it is actually a .8mm difference between the two.
I am definitely going to purchasing the pre-gen front 15t sprocket with the above mentioned shim.
Thanks for the help guys!!
Old October 20th, 2010, 11:59 AM   #30
some info on the shims...
http://www.kawiforums.com/ninja-250r...-sprocket.html
Old October 20th, 2010, 12:05 PM   #31
dubojr1
dubojr1's Avatar
The one I ordered for both my bikes is 8.8mm from the link above.
Old October 21st, 2010, 11:32 AM   #32
headshrink
headshrink's Avatar
If you couldn't order a shim from the same place (no additional shipping charge), send me a PM and I'll send you a shim.
Old October 21st, 2010, 03:07 PM   #33
Sailariel
Sailariel's Avatar
Vince, Congratulations on producing a very fine catalog.. You have a fine line of products. Found a few things I would like to get. Keep up the good work.
Ninjette, Sold. New Bike: 2010 Honda NT-700V/VA, 73 Honda 550, 74 Honda 550
Old October 21st, 2010, 03:27 PM   #34
want1sobad
Ninjette CPT
want1sobad's Avatar
Alex,
thanks, much appreciated. Jason (dubojr1, from above) actually put the catalog together - so he deserves the recognition. i look forward to doing business with you, pm me with questions about items, pricing, etc.
thanks again!
Old November 14th, 2010, 10:52 AM   #35
red
Motorcycle(s): TR7, Trident, SuperIII, BMW, HD, Duc, Vespa, MP3
The Drivenracing.com sprocket 1098-520-15T measures to 9.3mm if anyone is searching.
red is offline   Reply With Quote
Can't get front sprocket cover off Jason5885 2008 - 2012 Ninja 250R Tech Talk 8 April 4th, 2021 04:33 PM
13t front sprocket greatwhiteninja 2008 - 2012 Ninja 250R Tech Talk 14 August 3rd, 2011 09:35 AM
Front Sprocket Archerzz 1986 - 2007 Ninja 250R Tech Talk 66 June 29th, 2011 10:22 AM
15 Tooth Front Sprocket FerociousNINJA 2008 - 2012 Ninja 250R Tech Talk 5 September 14th, 2010 05:21 AM
front sprocket miniguns167 2008 - 2012 Ninja 250R Tech Talk 4 September 27th, 2009 11:59 AM
