Old May 19th, 2012, 07:45 AM   #1
LoneRonin
LoneRonin's Avatar
Motorcycle(s): 09 Ninja 250r
Do both brake lines need to be stainless steel?
I'm looking to upgrade my front brake line to a Speigler SS one. Is it necessary to also have the rear brake line changed? I use my rear brake very little, usually only when rolling to a stop going slow enough where I could probably stop if I just put my heel down...
LoneRonin is offline   Reply With Quote
Old May 19th, 2012, 07:49 AM   #2
leed
leed's Avatar
Motorcycle(s): Time will tell
Well, you don't absolutely need it. In other words, it will not hurt you to have a stainless front brake line and regular rear brake line.
Old May 19th, 2012, 10:13 AM   #3
rainking
rainking's Avatar
Motorcycle(s): 2008 ZX10R & 2009 250R
In my opinion, I would only do the front. The rear locks up pretty easy as is. Replacing it with SS would only make that worse. I'd say, just do the front.
"Sometimes it takes a whole tankful of fuel before you can think straight."
rainking is offline   Reply With Quote
Old May 19th, 2012, 11:41 AM   #4
cuong-nutz
cuong-nutz's Avatar
As for the rear is not needed as mentioned here. It's more for looks.
HalfFast Racing Team
Old May 19th, 2012, 12:30 PM   #5
i have front steel lines but i have stock rear brake and lines. i know racers who have almost no rear brake literally. if you aren't using it dont bother upgrading it
Old June 2nd, 2012, 08:41 PM   #6
tooblekain
tooblekain's Avatar
Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike)
Anyone know the length of their SS front line? I may see if I can do some transplant surgury using my SS front brake line from my D675 and use it on the ninja.
I would do this myself but unfortunately my girlfriend has my bike at the track and I am on limited mobility at the moment
tooblekain is offline   Reply With Quote
Old June 2nd, 2012, 09:11 PM   #7
word!
Old June 2nd, 2012, 09:25 PM   #8
ator
ator's Avatar
I have the Venhill lines, good price and quality. And...you get both, use one or both.
Also, you can get the rear longer then stock if you want. Add 5 inches to the rear when you order and you basically have 2 fronts. Sell one here and make some of your $$ back
http://www.ebay.com/itm/Venhill-Brai...22d719&vxp=mtr
ator is offline   Reply With Quote
Old June 3rd, 2012, 11:03 PM   #9
LoneRonin
LoneRonin's Avatar
not a bad price at all for two lines...
Old June 13th, 2012, 01:01 PM   #10
GaryTX
Motorcycle(s): '06 EX250 '03 VFR800
I didn't do my research and did this for my pre-gen. Turns out the rear brake line for a 2006 is 5" shorter than the 2008. Would this 52cm line with 06 banjo bolts be useful to an 08 owner?
GaryTX is offline   Reply With Quote
Stainless steel braided brake lines install Bob2010 2008 - 2012 Ninja 250R Tech Talk 8 June 11th, 2016 07:01 AM
Galfer Stainless Steel Brake Lines tfkrocks Motorcycle-related 1 May 23rd, 2014 06:06 PM
stainless steel brake lines (ZZR) Csmith9 1986 - 2007 Ninja 250R Tech Talk 4 February 17th, 2011 01:50 PM
[roadracingworld.com] - Video: Installing Braided Stainless Steel Brake Lines On The Ninjette Newsbot Motorcycling News 0 November 15th, 2010 12:40 PM
[roadracingworld.com] - British Manufacturer Of Braided Stainless Steel Lines Enters Ninjette Newsbot Motorcycling News 0 April 9th, 2009 11:00 PM
