January 30th, 2013, 07:03 AM | #1 |
Join Date: May 2012 Motorcycle(s): ninja 250 r Posts: 48
engine tapping sound
does anyone have any idea what this is.. my brother thinks its the tapits in the valves but i have no knowlage of 4 stroke engines http://www.youtube.com/watch?v=rEpRGwmrBWM
January 30th, 2013, 07:26 AM | #2 |
dirty boy
MOTM - Apr '14
@bandit_fosky
Here is a related thread I had similar sound with my bike when i got it brand new but, it was and is never as bad as the one in the vid you linked, is that yours? Mine always goes away after engine is warm if i hear it at all. It seemed like not many people could agree on what the cause was. If you are not mechanically inclined, just take it to the shop and make sure they hear exactly what you are talking about ect... http://www.ninjette.org/forums/showt...ht=rock+engine |
January 30th, 2013, 07:30 AM | #3 |
How many miles?
Service history of valves? Ever? Oil level full? When was the last oil change?
January 30th, 2013, 08:42 AM | #4 |
January 30th, 2013, 08:48 AM | #5 |
Hmmm... intersting. What did the old oil look like? Did it look thinned out? Did it smell of gas?
January 30th, 2013, 09:59 AM | #6 |
sounds like something nasty gummed up an oil passage and then passed through. i would look at the metal oil screen
January 30th, 2013, 01:31 PM | #7 |
oil was BLACK the glass looks all steamed up always and there a little bit of solid oil at the bottem. i gave her a full oil change today aswell as oil filter i may have over filled it ever so slithly but i dont think that would make much diffrence would it? when the bikes running the oil goes right down to just below the minimum level
January 30th, 2013, 02:54 PM | #8 |
A little bit overfilled is ok, a lot is bad. Major no no. When in doubt drain some out and refill to proper level.
January 30th, 2013, 02:54 PM | #9 |
Solid oil?!?!?!? hahahahahah It was time then aye?
March 14th, 2013, 09:16 AM | #10 |
ringing this thread back to life the noise is back and i dont want to run the engine for risk of destroying the engine what shall i do? :/
March 15th, 2013, 06:25 AM | #11 |
Join Date: Mar 2012 Motorcycle(s): Ninja 250r 2010 SE Posts: 573
Here's what is happening.
The liquid oil after a while turns into solid gunk. This gunk is blocking your oil passages but more importantly it is stuffing your clearances. You have none at start up. Then things get moving, warm oil gets flowing the gunk gets cleared away by the cams and the tapping noise goes away. The tapping sound you are experiencing is similar to worn camshaft lobes. But your camshafts are fine. You need to get that gunk out of there. If you want to do it properly you need to pull it apart and clean everything with brake cleaner. If you dont have the time you need to use an engine oil flush. Liqui moly make a really good one. I know 2 people who are experiencing this same problem on cars and have fixed it using liqui moly on my advice. |
March 15th, 2013, 06:34 AM | #12 |
P.S
When you drain the oil. You will still have about 50 to 100 cc's left in the head. This is more oil then you think and is a lot more than is needed to gunk up and make your engine tick/tap and run like and old washing machine. I can only imagine what is sitting above the number 1 cylinder. |
March 15th, 2013, 01:08 PM | #13 | |
dirty boy
MOTM - Apr '14
I had this sound with my brand new bike, i noticed it at 80 miles. Took it to the shop for 600 service and they were like "normal sounds for this bike" I called BS on that but they still had no answer. I have not noticed it lately. I first noticed it when it was cold and i think it might of had something to do with my oil getting foamy for some reason or another. I will see if i can still hear it now. I have 3500 on the bike now, i got it last October and have had no issues, bike runs good. |
March 15th, 2013, 07:05 PM | #14 |
This sound isn't normal for this bike. I have never heard this sound on my bike, nor on any ninja 250 I have heard start up.
It sounds exactly the same as my mate's Holden Commodore VX with 120 000 miles. Now it runs smooth but only after a flush and oil change. His motor was all varnished up on the inside. You can fix this problem temporarily without pulling it apart, but I doubt your engine will last very long. Just because your engine is new doesn't mean it is in good condition. Here's a crankshaft main bearing after only 6000 miles. I change oil every 1200 miles. More during break-in. To give you an idea of the oil left in the head after draining it check out this photo. Here's what a clean head looks like. If you have solid oil in the bottom where oil flow is good. Your definitely going to have some serious build up in the head where the only oil flow comes through a small banjo bolt oil hose. |
March 16th, 2013, 01:52 PM | #15 | |
March 17th, 2013, 04:16 AM | #16 |
underneath the head. I don't have a photo of them on the bike
I mis read your post subzero. If your bike is brand new (under 200 miles) I would think that the sound may be from the break in process and be completely normal. If your bike has 1000 miles or over and is still making this noise then something isn't right. |
March 17th, 2013, 07:59 AM | #17 | |
dirty boy
MOTM - Apr '14
no worries, i listened on friday and no noise but, it has not been as cold. regardless i have not heard it since 600 service. again i think it had something to do with foamy oil and cold conditions in my instance |
Engine won't start. Clicking sound | zzrguy | 1986 - 2007 Ninja 250R Tech Talk | 17 | October 27th, 2014 08:25 AM |
Wheezing engine sound and horrible idle | chich | 2008 - 2012 Ninja 250R Tech Talk | 7 | February 18th, 2014 09:30 AM |
Engine ticking sound | Nosajong | 2008 - 2012 Ninja 250R Tech Talk | 4 | May 21st, 2013 07:57 PM |
engine sound is much deeper pitched. | EvnEvn724 | 1986 - 2007 Ninja 250R Farkles | 4 | July 26th, 2011 11:07 AM |
Does my engine sound normal? | Betlog | 2008 - 2012 Ninja 250R Tech Talk | 12 | February 5th, 2010 10:53 PM |
