May 3rd, 2015, 09:51 AM | #1 |
Join Date: May 2013 Motorcycle(s): '06 Ninja 250 Posts: 70
High-beam out, replace bulb? Model?
When I turn on my high-beam, I get the blue light on the dash, but the light turns off completely. Low-beams work perfect. I just wanted to check here whether that's the bulb that needs replacing, or something else.
The replacement procedure is easy enough, but I was curious what bulb model(s) I can use to replace it. I assume I can pick up something fairly common from the auto parts store? |
May 3rd, 2015, 10:08 AM | #2 |
It uses an H4 bulb, which has 2 filaments; one for low, one for high. It only runs one filament at a time, either low or high. So basically, your high beam filament is burnt out. It can be found at any auto parts store.
May 3rd, 2015, 10:20 AM | #3 | |
May 3rd, 2015, 01:56 PM | #4 |
Thanks, Snake & Motofool!
I went and bought a standard Sylvania Silverstar Ultra 9003/H4. I decided to spring for the Ultra model, in hopes that it'll be a bit brighter than the bulb that came with the bike when I got it from a third party. I'll get it installed and test out the visibility with it tonight! |
May 3rd, 2015, 03:37 PM | #5 |
You are welcome
May 3rd, 2015, 10:13 PM | #6 |
Good call on the ultra silver star, you'll be very happy, also take the time to properly aim the headlight to optimize it.
June 2nd, 2015, 07:40 PM | #7 |
Loved the new bulb, while it worked...
It's been exactly one month (and only 150 miles), and the high beam is out again (low beam still working) on the brand new bulb. Is there a reason this could happen? |
June 2nd, 2015, 08:00 PM | #8 |
A number of reasons, bad bulb, did you touch the bulb, bad connections, excessive vibration.
June 2nd, 2015, 08:12 PM | #9 |
I definitely know I didn't touch the bulb, but it seems like there wouldn't be any more vibrations than there were previously. Wouldn't the low beam go out as well if it were vibrations causing the filament to fail? Is there any tests I should run before installing another bulb? I'd hate to just waste another one for a few miles of high beams.
June 3rd, 2015, 03:31 AM | #10 | |
You can check the connector at the bulb, also check the grounds, and the hi/lo switch, your looking for either a bad connection, or corrosion.
I assume you purchased a Sylvania ultra silver star, be warned they don't last as long as regular halogen bulbs, From Sylvania website, https://www.sylvania.com/en-us/innov...ages/FAQs.aspx Quote:
http://www.consumerreports.org/cro/m...ulbs/index.htm Another option is going LED, or HID, but no matter what you choose, you'll still be limited to the OEM fluted lens, and reflector of the headlight. A much brighter bulb like an HID will not be nice and crisp compared to one in a projector setup, but will offer much better light then a halogen bulb, but it will bleed so to speak of the light. I have HID DDM TUNING 55watt/5k H4 hi/lo set up, it's extremely bright, and it lights up the road, and once it's aimed correctly I've had no issues with oncoming traffic.
June 3rd, 2015, 07:41 PM | #11 |
Join Date: Nov 2013 Motorcycle(s): 01 gixxer 1k, 02 gixxer 600, 02 ninja 250, a slew of dirt bikes Posts: 52
That light should last much longer than that, like years upon years.
Has the wiring been hacked or modified?? Is your high low switch not working properly causing it issues. I don't believe vibration unless something about the mount has been modified. Although rereading your post, some of the problem could be the bulb itself. Sylvania brand regardless of weather its in your bike or house is junk. just my take on Sylvania brand. I do realize that they have a large market in the lighting sections but there are other better brands. |
June 4th, 2015, 03:46 PM | #12 |
No modifications of any kind to the electrical system aside from moving the turn signals to the tail light pods (I used the original hardware and wiring, though).
I do not have a way to test voltage currently, though that might be a good thing to check out at some point. I don't think there is a problem with the hi/lo switch, but I wouldn't know what to look for aside from obvious damage to the switch or wiring - neither of which I can tell by looking at it. What brand do you suggest? |
June 4th, 2015, 06:19 PM | #13 | |
Odds are you might just got a bad bulb, try another one and see, also buy it from Wal-Mart, they exchange anything!!
June 5th, 2015, 04:18 PM | #14 |
Ah, I did get this one at Walmart, but I'll be damned if I have my receipt. It's also been ~30 days. I'm not sure what their exchange window is off hand.
As for any corrosion, rust, or discoloration, I don't have any of that visible, which is a good thing. |
June 5th, 2015, 07:08 PM | #15 | |
http://www.harborfreight.com/7-funct...ter-98025.html If the voltage regulator is defective, bulbs will get burned more frequently. High voltage and vibrations are the enemies of incandescent filaments.
June 7th, 2015, 01:31 PM | #16 |
There's no corrosion or anything like that on the connections that I could tell by looking at everything at the battery, regulator/rectifier, and headlight connecter.
I went and bought a GE multimeter at the local Walmart, and took readings. I'm not 100% sure what's necessary to measure and what's not. I did do some looking around online and chose to test the battery off the posts, the stator leads and regulator output, as well as the posts at the headlight socket. I think everything is pretty normal, though the power for the highbeam is lower than the lowbeam by a small amount. I bought a new bulb. It's still a Sylvania, but just the cheapest model. I figure it's cheaper to replace if it dies as well. I didn't install it yet, though - I wanted to run the numbers here by you guys to see if I missed anything important. Battery: With the engine off (24hrs downtime), 12.90v Key on, engine still off, 12.55v Engine on, choke on, 3k RPM, low beam on, 14.75v Engine on, choke off, 1.2k RPM, low beam on, 13.09-13.26v Engine on, choke off, 6k RPM, low beam on, 13.98-14.50v Stator Resistance: All 3 wires read as 1.20 (I read that anything under 2.0 was fine) Regulator/Rectifier: Wire 1 (not sure which is which, this one is brown) 12.00-12.40v Wire 2 (red) 12.2-14.3v Headlight connection (numbers stayed the same with higher RPMs): Lowbeam on: lowbeam wire, 14.1-14.3v - highbeam wire, 0.02v Highbeam on: lowbeam wire, 0.00v - highbeam wire, 13.85-14.01v |
June 7th, 2015, 02:30 PM | #17 | |
At idle rpm's, the max reading should be 14.7v. http://faq.ninja250.org/wiki/How_doe...system_work%3F I would wait and see how long the new bulb lasts.
June 7th, 2015, 03:47 PM | #18 |
So a little high on the battery terminals, but elsewhere, it seems to be under the maximum? Perhaps a sign of the regulator beginning to fail?
I went and tossed the new bulb in and put it back together. It's working, for now. We'll see if it dies quickly like the other one, though. |
June 7th, 2015, 04:05 PM | #19 | |
June 7th, 2015, 04:07 PM | #20 |
I'll keep my fingers crossed. I did check the fuses again, and none of them are blown (I'm sure I would have known if it were, but sanity checks aren't bad)
June 7th, 2015, 07:48 PM | #21 | |
If the R/R ever dies, upgrade to a mosfet R/R I've done this many times, always with excellent results. Full write-up, Who wants to see a MOSFET R/R upgrade?
June 8th, 2015, 07:51 AM | #22 |
EX500 full of EX250 parts
FYI, the brown wire is what the R/R uses to detect the bike's voltage. The red wire (the wiring diagram shows it as white?) is the output of the R/R to the bike.
July 6th, 2015, 02:44 PM | #23 |
Well, it's been a month since I installed the cheap model headlight, and it's still working fine. Maybe it just hates high performance bulbs? Strange.
low beam or high beam brighter? only choose one | passive101 | General Motorcycling Discussion | 3 | July 26th, 2013 06:27 AM |
Low Beam Good, High Beam dead | FvnnyL3tt3r1ng | 1986 - 2007 Ninja 250R Tech Talk | 4 | February 21st, 2013 03:44 PM |
New bulb for my ninja *short beam* | Graugaard | 2008 - 2012 Ninja 250R Tech Talk | 9 | September 18th, 2012 11:28 AM |
make high beam into low beam? | DaMan22 | 2008 - 2012 Ninja 250R Farkles | 2 | July 12th, 2012 06:34 PM |
Has anyone tried to put a high beam bulb in | divingtigger | 2008 - 2012 Ninja 250R Tech Talk | 16 | April 7th, 2010 12:03 PM |
