March 20th, 2014, 07:03 AM | #1 |
Join Date: Jul 2013 Motorcycle(s): ZX-3R (ok, ex300) Posts: 160
air filter + slipon
been searching and reading but can't find a solid answer..
on a 300, will I need a fuel tuner if I run a K&N air filter with a slip-on exhaust? has anyone run a higher flow filter and slip-on without using a tuner? |
March 20th, 2014, 09:23 PM | #2 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
You shouldn't "have" to, a slip on wont change much besides weight, and sound. the filter will just flow better. You will get a little more out of it if you run a tuner, but if you are trying to up your performance you should save up for a full exhaust like an areaP, an def run the tuner!
I know a guy running a slip on with no tuner, he hasn't seen much change good or bad. |
March 21st, 2014, 09:19 AM | #3 | |
March 21st, 2014, 09:40 AM | #4 |
MOTM - Jan '18, Sep '13
I think the reasoning for getting a tuner is that the stock bike runs lean already and getting better air flow would make it run even more lean.
March 21st, 2014, 11:24 AM | #5 |
Like she said... Your gonna run lean, the bikes already run lean, a tuner fixes that. I probly wouldn't put the k&n in without a tuner, you won't blow it up though.
March 21st, 2014, 11:42 AM | #6 |
yeah.. I'm on the fence between keeping the bike and throwing some fun new toys on it or selling it and getting a bigger bike.. decisions decisions..
thanks for the replies, I was hoping someone with a filter and slipon only would chime in.. no biggie though. I know a tuner is worth the money, just not sure I want to spend the money if I'm going to get rid of it this riding season.. |
March 21st, 2014, 11:47 AM | #7 | |
Here is what Area P had to say...
Air filter help. | ranma3030 | 2008 - 2012 Ninja 250R Tech Talk | 5 | January 13th, 2014 12:02 PM |
K&N air filter to stock air box | Graugaard | 2008 - 2012 Ninja 250R Tech Talk | 29 | July 28th, 2012 06:33 AM |
Anyone know an air filter I can replace the OEM filter with? | Monkeytofu | 1986 - 2007 Ninja 250R Tech Talk | 5 | July 22nd, 2012 09:34 AM |
[sportrider - latest stories] - K&N Air Filters Named as Official Air & Oil Filter Su | Ninjette Newsbot | Motorcycling News | 0 | June 11th, 2012 06:00 PM |
akrapovic slipon, no kleen air, still issues | ninjaflav | 2008 - 2012 Ninja 250R Tech Talk | 7 | August 28th, 2011 07:38 PM |
