Go Back   ninjette.org > Marketplace > Motorcycle-related
Old March 5th, 2012, 01:19 PM   #201
Ninja250gurl
M@ry M@ry
Ninja250gurl's Avatar
Motorcycle(s): 2012 ninja 250 Red/Black
I think if you go to the very 1st page, he put "shipped" beside everyone he shipped out to.
~M@ry
Beside me or behind me... real woman dont ride b*t<h!
Ninja250gurl is offline   Reply With Quote
Old March 6th, 2012, 07:16 PM   #202
Makenza
Lurker
Motorcycle(s): 2010 Red Ninja 250R
Received my package, installed the tail lights already!
Looks sweet!
Will be working on installing my diodes along with the front flushmounts!
Thanks again Tri!
Makenza is offline   Reply With Quote
Old March 6th, 2012, 10:14 PM   #203
Makenza
Lurker
Update! Installed everything, and as expected, everything works!
Thanks once again Tri!
Old March 6th, 2012, 11:49 PM   #204
Kstorm21
Kstorm21's Avatar
Motorcycle(s): 2009 Ninja 250R SE
Got pics?
Kstorm21 is offline   Reply With Quote
Old March 7th, 2012, 07:21 AM   #205
massacremasses
Avid Kitteh Poster
massacremasses's Avatar
Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT
I got mine but Im prolly a week out before I install in it. I am to busy doing the week. and will be gone this weekend
I powdercoat stuff Help me pay for my addiction
I say funny stuff. http://twitter.com/JustinPWNSyou sometimes...
I write like a 12 year old too, http://justinpwnsyou.wordpress.com/
massacremasses is offline   Reply With Quote
Old March 7th, 2012, 01:53 PM   #206
student driver
i'm installing this right now...i plugged in the relay for my front led's along with the tail light. If someone can help me figure out why I get hazard-light flashing when i use the turn signal, i'd appreciate it
student driver is offline   Reply With Quote
Old March 7th, 2012, 03:29 PM   #207
Makenza
Lurker
If you have LEDs up front, and LEDs at the back for your turn signals, not only will you need the relay, but you will also need the DIODE mod!
That's why you're getting the hazard lights where everything blinks together.
Old March 7th, 2012, 03:48 PM   #208
student driver
I didn't have the diode kit installed properly, they work now....Tri's customer service and my stupidity know no bounds!
Old March 7th, 2012, 04:15 PM   #209
lc86
lc86's Avatar
Motorcycle(s): 2010 Ninja 250r (RIP)
Well, now I get to test my bounds of stupidity...so I am having a problem with my front leds flashing together. The integrated signals work perfectly, but the front ones are flashing together. I installed a couple resistors and that fixes the front blinkers, but then the integrated blinkers stop working...I have the new relay installed as well as the diode kit.
lc86 is offline   Reply With Quote
Old March 7th, 2012, 04:20 PM   #210
Makenza
Lurker
If you have the diode kit, as well as the correct relay, it SHOULD work.
Something may be wrong with your installation/wiring.
Double check your diode installation, also, which relay do you have.
While i'm asking that, did you get the diode kit from Tri?
CustomLED Integrated Tail Light // Front LED Flushmounts // Woodcraft Clip-ons // ZG DB Light Smoke Windshield // OEM Solo Seat Cowl // ProjektD FE
Old March 7th, 2012, 04:21 PM   #211
student driver
Here is the link for the diode install:
http://www.ninjette.org/forums/showthread.php?t=79621
Old March 7th, 2012, 04:21 PM   #212
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
Sometimes you need to use some sand paper at ur ground contact. You shouldn't need to install resistors with both the relay and diode kits.
The www.ModMy250.com guy
Old March 7th, 2012, 04:24 PM   #213
Makenza
Lurker
Tri, I have a question, before cleaning everything up, I tested everything out, WITHOUT grounding the diode kit. Everything still worked just fine, but for good measure, I grounded the diode kit anyway.
Whats the usual symptoms if the diode kit is improperly grounded?
Old March 7th, 2012, 04:28 PM   #214
oreX
oreX's Avatar
Motorcycle(s): 2013 636 - ABS
Got everything installed this afternoon, here is a pic of the tail.
oreX is offline   Reply With Quote
Old March 7th, 2012, 04:31 PM   #215
lc86
lc86's Avatar
That's what I originally thought, but it was just strange how only the front ones were acting that way. I'm going to go sand it real quick and see if that fixes the problem.
Old March 7th, 2012, 05:32 PM   #216
CThunder-blue
ModMy250.com
I think if you don't ground it, the indicator doesn't work.
Old March 7th, 2012, 05:35 PM   #217
CThunder-blue
ModMy250.com
Let me know how that goes. If it still doesn't work, I'll send you another diode kit. I'll need the old one back for testing though. Also, make sure you have a clean ground on the relay wire too.
Old March 7th, 2012, 06:46 PM   #218
lc86
lc86's Avatar
Alright, I figured it out. It was actually a mix of problems. I sandpapered the ground to ensure it had a good seating and it started to kind of work, but it was acting weird. I double checked the wiring and found that the red wire in the diode kit broke off of the little metal tab thing, but it was kind of sort of touching it, so I fixed it. Then I pulled off the 9-pin connector, made sure everything looked alright, and when I plugged it back in the blue wire broke from the little metal thingy. I thought to myself "you have got to be ****ing kidding me" and then I fixed that. Afterwards I tested it and it now works perfectly Heres a pic of the finished product.
Old March 7th, 2012, 11:32 PM   #219
CThunder-blue
ModMy250.com
so the connectors broke off from the wire?
Old March 8th, 2012, 12:09 AM   #220
lc86
lc86's Avatar
Yeah, pretty much. It happened at the point where the wire connected to the actual metal tab on both of them. I thought I might have accidentally been rough with it when I saw the red one was broken, but I watched(and heard) the blue one break off when I plugged in the connector. I'm not too worried about it, it took maybe 2 minutes to fix and it looks so much sexier now. I think it was just a little brittle at the edge of the solder points.
Old March 8th, 2012, 08:20 AM   #221
CThunder-blue
ModMy250.com
Thanks. I'll keep that in mind. I've made over 50 units the same way and this is the first one to do that. Sorry about that.
Old March 8th, 2012, 11:38 AM   #222
lc86
lc86's Avatar
Don't worry about it, I have notoriously bad luck with pretty much everything. For instance when I first attempted to install fuel injection with the ecotrons throttle body, I went to install the throttle cable and as soon as I went to put it in the holder, the bracket broke in half. I had barely put any pressure on it and I just kind of stared in disbelief. I am pretty sure I am the only person that has ever happened to
Old March 8th, 2012, 12:51 PM   #223
jack_bm
Ex ninjette!
jack_bm's Avatar
Motorcycle(s): Suzuki GSXR 600 K4, Kawasaki ninja 250r 08
Cannot wait for this the kits are lookin real good
Mods: Puig Double bubble windscreen, Targa Fender eliminator, Custom LED integrated Tail light, Exhaust Hanger, Two brothers titanium exhaust More on the way!
jack_bm is offline   Reply With Quote
Old March 9th, 2012, 10:29 AM   #224
EthioKnight
Super Noob
EthioKnight's Avatar
Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc
GOT MINE MOFOs!!!!! sorry, just a bit excited
Tri my man, you freaking ROCK! Can't wait to put it on.
Thanks a lot bud
EthioKnight is offline   Reply With Quote
Old March 9th, 2012, 11:30 AM   #225
massacremasses
Avid Kitteh Poster
Gonna put it on today
Old March 9th, 2012, 11:41 AM   #226
MikeBudd
MikeBudd's Avatar
Motorcycle(s): RED 2010 Ninja 250r
Haven't received mine yet, but that's to be expected with international shipping
SO looking forward to this, I should get it along with my new gloves, and probably even new tires. So much win!
MikeBudd is offline   Reply With Quote
Old March 9th, 2012, 07:41 PM   #227
massacremasses
Avid Kitteh Poster
I am BIIIIG dummy. I didnt install the diode mod cause I was like look it totally works without it. Then I looked and both front ones were blinking... DOH. Im a dummy. Ill throw that in tomorrow.
Old March 11th, 2012, 12:38 AM   #228
MikeBudd
MikeBudd's Avatar
LOL. Get it installed properly today?
Old March 11th, 2012, 08:28 AM   #229
EthioKnight
Super Noob
Installed it (with the Diodes of coarse, unlike some people ) and loving it. I especially like the initiating sequence when you turn the key on and the tail light goes color crazy . Anyway, very happy with the result, but still gotta check if my blinkers work (was too tired last night). Here are some pics >> http://www.ninjette.org/forums/showp...postcount=1610
Old March 11th, 2012, 10:50 AM   #230
taz_250R
Tinkerer
taz_250R's Avatar
Everything installed without a hitch... it all fits very nicely especially with Proton LED front blinkers... the package really cleaned up the body lines...
There is nothing I can suggest to improve here everything was very PnP... Thanks Tri for your excellent products...
2011 Ninja 250R - Custom Decals / Solo seat cowl / Rearset Adjusters / Frame sliders / swingarm spools / Mirror extenders / fender eliminator / Shimmed needles (1.00mm)
taz_250R is offline   Reply With Quote
Old March 11th, 2012, 05:23 PM   #231
massacremasses
Avid Kitteh Poster
lol no I took my wife to SF to see a ballet. And its at work so I didnt do it when I got home today... Its gonna rain all week so ill do it at some point this week. lol
Old March 12th, 2012, 03:36 PM   #232
dma
dma's Avatar
Motorcycle(s): 09 Ninja 250
I may gotten lucky, but Tri shipped my order out on Saturday and I got it today (Monday) Also received two silver ninjette.org decals and an awesome bible bookmark
Can't wait to get everything installed with my smoked HotBodies undertail, will post pictures when everything is installed
dma is offline   Reply With Quote
Old March 12th, 2012, 03:45 PM   #233
Kstorm21
Kstorm21's Avatar
@dma what part of the "Chicago suburbs" are you from? I grew up in Calumet City (south suburb) and lived in Palatine and Arlington Hts for 4 yrs. Can't wait to see pics with the undertail.
Old March 12th, 2012, 03:52 PM   #234
dma
dma's Avatar
Awesome, I'm actually nearby in Bartlett (close to Schaumburg)
Hawaii now, eh? Lucky, must be nice to have gotten out of the cold winters Will definitely keep you posted with pics
Old March 12th, 2012, 07:39 PM   #235
Kstorm21
Kstorm21's Avatar
Yeah, I know where Bartlett is. I love the movie theater in Schaumburg. Best theater I've ever been to.
Oh...my husband is in the military so it takes us everywhere. We were lucky to get sent here.
Old March 13th, 2012, 05:55 AM   #236
Ninja250gurl
M@ry M@ry
Got my tail light and flush mount front turn signals in the mail on saturday, since i was out of town i had to put them on last nite. Took me 3hrs total, taking plastics off, and putting them back on. Love the tail light, and the lcd flush mount front lights!!
~M@ry
Old March 13th, 2012, 04:00 PM   #237
Kstorm21
Kstorm21's Avatar
Very nice! Do you have a Corbin seat? Also, did you try putting your turn signals upside down. It might flow better with the bike.
Old March 13th, 2012, 08:57 PM   #238
MikeBudd
MikeBudd's Avatar
Unless its a fake she has one. Look closely in some of the other pictures and you can see the branding on the side :P
But yea, definitely try the turn signals upside down. With those 2012 new graphics, it probably would look awesome
Still haven't gotten mine, although I am not sure exactly when Tri shipped it, i'm sure i'll get it this week sometime!
Old March 13th, 2012, 09:03 PM   #239
massacremasses
Avid Kitteh Poster
she does there is a thread around here somewhere.
Old March 13th, 2012, 09:04 PM   #240
Kstorm21
Kstorm21's Avatar
I like the red accents on it. Very cool! I just wish they weren't so darn expensive.
Modmy250.com promo sale! CThunder-blue Motorcycle-related 0 December 9th, 2012 05:45 PM
CustomLED Integrated tail light special sale! CThunder-blue Motorcycle-related 8 October 30th, 2012 01:29 PM
New Brake Light Modulators for sale~! Limited introductory sale!! CThunder-blue Motorcycle-related 15 October 5th, 2012 08:09 PM
Wire integrated tail light such that the brake light stays off while signal flashes? CZroe 2008 - 2012 Ninja 250R Tech Talk 6 March 4th, 2012 06:36 PM
