June 27th, 2013, 10:40 AM | #1 |
Join Date: Sep 2010 Motorcycle(s): Yamaha RD350, H-D Electraglide, BSA Lightning, Suzuki GS550 Posts: 12
07 250r battery issues
Hello!
My buddy has a 2007 250, and we aren't sure whats going on with it. The battery is basically new, but what happens is after a few days, it just won't crank the motor over (get the clicking noise and starter won't even try) but it will bump start. Put the battery on a trickle for a while, and it was back to normal. After a few days the same thing happened again. Originally, it was thought to be a short somewhere draining the battery, but after testing up and down for that, it doesn't appear to be a short at all. So we grabbed a volt meter to get the voltages of the batter with the following results: Off: ~13.3v Idle: ~14.9v Throttle: ~15.5v (This was done after it was on trickle for about a day, so the battery is fully charged essentially) Now, the voltage for off seems OK as far as I know, but I thought idle seemed a bit high, and figure under throttle it would show more than a ~.5v difference. Someone was thinking it was a stator issue, but I wanted to get an opinion here before getting any parts. Fuses look good, wiring looks good, and the bike seems healthy otherwise. Any ideas? Thanks in advance!!
03 H-D Electraglide, 75 Yamaha RD350 cafe, 79 Suzuki GS550L with sidecar hack, 71 BSA Lightning 650, 14 Ducati Monster 796 |
June 27th, 2013, 11:07 AM | #2 |
Battery may be taking a crap and check output of stator.
June 27th, 2013, 01:06 PM | #3 |
Someone else mentioned stator, forgot to add that in there. Ill see about testing that and post results.
June 28th, 2013, 01:45 PM | #4 |
Ok, so after testing I am pretty sure that stator is ok.
One thing we did too was remove the positive off the battery after starting the bike and it did stay running. I am leaning towards a flat battery now. It was a $40 battery from Advanced Auto I think, so it could have just been quality of the battery. It was bought new last year, ridden on for a few months, but the sat about 9 months with no tender.
Cold weather battery issues. | cuong-nutz | General Motorcycling Discussion | 9 | June 27th, 2014 08:16 AM |
Idle issues and battery problems | Knorf | 1986 - 2007 Ninja 250R Tech Talk | 4 | May 23rd, 2014 06:04 AM |
FS: Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger (Automotive) ta | Amazon Postbot | Amazon - Popular Motorcycling Items | 0 | April 23rd, 2013 04:52 PM |
Battery Issues | Stingray1000 | 1986 - 2007 Ninja 250R Tech Talk | 8 | April 13th, 2013 08:25 PM |
Electrical Issues (IMO battery related) | nikreinert | 2008 - 2012 Ninja 250R Tech Talk | 2 | July 14th, 2012 04:41 PM |
