April 9th, 2014, 01:58 PM | #1 |
Join Date: Mar 2014 Motorcycle(s): 2009 Kawasaki Ninja 250r Posts: 41
Self chain adjustment
Hi guys I'm struggling trying to adjust my chain. So long story short I can't loosen the axle nut. I put the open wrench 24mm that comes from the kit and 17mm socket on the other nut. I try to go left on 24mm to loosen it but the 17 also keep moving??? How do I loosen the nut?
April 9th, 2014, 02:05 PM | #2 |
Join Date: Nov 2012 Motorcycle(s): 2012 Ninja 250R, 2007 Ninja 650R, 2001 F650 Dakar Posts: A lot.
You have to use another wrench to brace/hold the 17, while loosening the castle nut.
April 9th, 2014, 02:12 PM | #3 |
I only have a socket and ratchet for 17mm don't have any other tools. So for the 24mm I go left and the 17mm also right to loosen? Do I have to loosen the adjuster nut before I loosen the axle nut?
April 9th, 2014, 02:15 PM | #4 | |
Got a friend with some tools?
April 9th, 2014, 02:24 PM | #5 |
Unfortunately I don't have any friends that have tools. Can I somehow loosen the castle nut while the axle bolt turning?
April 9th, 2014, 02:27 PM | #6 |
I usually just hold the 17 static while loosening the 24. If you don't brace it, you won't be able to loosen the castle nut. If you don't have the tools, call the local hardware store and get what you need. You'll probably have to adjust the chain in the future, so it's a worthwhile investment and shouldn't cost much.
April 9th, 2014, 02:35 PM | #7 |
I see your right lol I'm dumb the axle bolt was inside the castle nut. Could you please tell me the tools that I need. I will go get them on the weekend.
April 9th, 2014, 02:38 PM | #8 |
Depends on what you have. I usually just hold the 17 with a crescent wrench, and loosen the 24 using a socket wrench. Make sure you have spare cotter pins, and you should be set.
April 10th, 2014, 10:59 AM | #9 |
Hmm I do have crescent wrench but the very big one I don't have the regular size one. I currently don't have anything that could brace the axle bolt from turning, and also the castle nut is so f****** hard to turn.
April 10th, 2014, 11:18 AM | #10 |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
April 10th, 2014, 11:23 AM | #11 |
MOTM - Jan '18, Sep '13
Breaker bars are your best friend
April 10th, 2014, 12:47 PM | #12 |
I looked up on the internet and it seems like breaker bar will do the job of loosening the castle nut. I guess for right now I will invest on breaker bar first since its cheaper than impact wrench. But what would you guys suggest me use to brace+hold tight the axle bolt from moving? what did you guys normally use?
April 10th, 2014, 05:33 PM | #13 |
Breaker bar for the castle nut. Regular old ratchet on the other side. Never had a problem.
May 10th, 2014, 09:52 AM | #14 | |
Put the shock adjustment tool into one end of the pipe handle piece and the axle nut wrench into the other. This will be quite a bit longer than the axle nut wrench + pipe handle alone and give you much more leverage. |
May 11th, 2014, 07:48 AM | #15 |
Join Date: Apr 2014 Motorcycle(s): 08 Ninja 250r Posts: 26
you can use a pipe for the breaker bar it just needs to fit over the ratchet or the wrench you are using.
May 12th, 2014, 08:27 AM | #16 |
A 1/2" drive ratchet and socket should do it. You may have to put a wrench on the other side and, while standing directly behind the rear tire, pull up on the nut with the ratchet while also holding the end of the bolt (pushing down) with the wrench at the same time to stop it from spinning. I've never needed a breaker-bar, but it might help if you are working alone.
If it's that tight, having a helper will make it a lot easier. Here's a link to a good video showing the proper way to set the chain tension - http://www.canyonchasers.net/video/chain.php |
May 12th, 2014, 08:34 AM | #17 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
silly question, but did you take the pin out of the nut?
I just took mine off with 2 crescent wrenches, and as far as I can tell it hasn't been loosened yet. it was tight, but not prohibitively so
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
May 12th, 2014, 09:12 AM | #18 | |
Other than that, it all sounds like great advice! |
Hope i did this right - chain adjustment | reaperw | 2008 - 2012 Ninja 250R Tech Talk | 15 | September 29th, 2022 11:40 PM |
Chain Adjustment | reabo | 2008 - 2012 Ninja 250R Tech Talk | 17 | October 3rd, 2013 06:28 AM |
Chain adjustment, now new noise | MagicMike | 2008 - 2012 Ninja 250R Tech Talk | 9 | August 27th, 2013 03:11 PM |
Chain Adjustment | Old Guy on a '08 | 2008 - 2012 Ninja 250R Tech Talk | 21 | October 18th, 2012 05:29 AM |
Chain adjustment | SteveL | General Motorcycling Discussion | 3 | March 21st, 2010 03:08 PM |
