Old May 9th, 2023, 06:37 PM   #1
MCPhotographer
Motorcycle(s): EX 250, 06 CBR 1000, Duc 848, 100yr Road King, VTX 1300
Engine dies due to no gas because vacuum isn't strong enough
Hey everybody. Thanks for taking a look at this post. I have a question because I can't seem to figure out the reason why this is happening. I've rebuilt the carburetor, it's been dipped in berryman's and ultrasonically cleaned. This carburetor was rebuilt not that long ago wit a rebuild kit and is only been sitting for a few months. I decided to thoroughly clean it before trying to get it running again just to make sure that I didn't have any idling issues or throttle issues. Anyways I've got it in and installed and the bike would not start. I decided to check to see if there was fluid flow because it did not seem like the engine was getting gas. Sure enough there was no gas running into the carburetor. So I attached a brake bleeder to the vacuum side of the petcock and applied pressure to it. The gas started to flow freely and the engine runs fine as long as the brake bleeder is connected with pressure. Once I remove that and connect it back to the carburetor with the hose the bike will run for a while and eventually just shut off because it's not getting any gas. So the problem is there's not enough suction to cause the venturi to allow the gas to flow. Does anybody have any suggestions or has experiqenced this problem before? Has the petcock gone bad? Or is it the carburetor that's got the issue? I don't know if the carburetor is not producing enough suction or if the petcocks faulty and requires more suction than it should.
MCPhotographer is offline   Reply With Quote
Old May 12th, 2023, 07:01 AM   #2
Guaire
Motorcycle(s): 2005 EX250, 2014 Royal Enfield Continental GT
Is there compression on the cylinders?
Guaire is offline   Reply With Quote
Old May 12th, 2023, 01:57 PM   #3
please post a pic of this setup with brake bleeder installed
Old May 15th, 2023, 08:53 AM   #4
MCPhotographer
Ducatiman, the carburetor is currently assembled and situated in the bike. I literally took a Mighty Vac and connected a hose to the petcock vacuum tube and gave it a couple of squeezes and let it dangle. The bike ran fine when this was done.
Guaire - Not sure I understand the question. I assume there's compression. Bike runs fine as long as there's sufficient suction on the petcock.
Old May 15th, 2023, 09:09 AM   #5
Vacuum petcocks take very little vacuum to open when they're working properly. They have to be designed that way since if you hold the throttle wide open for a while, causing the vaccum to be only slight, you can't have the fuel stop flowing. If you put the vacuum hose in your mouth, it should take only a little sucking to make it open. A Mighty Vac is way overkill.
Old May 15th, 2023, 09:24 AM   #6
Hey good job figuring petcock wasn't getting enough vacuum. This is out of Honda manual, but same idea.
Check your hoses on carbs. Make sure they match this layout.
Note petcock should have dedicated vacuum hose that's not shared with anything else. Make sure there's no cracks in hose and both ends securely clamped.
Measure how much vacuum it actually takes to open petcock. It might have leaky diaphragm and needs rebuild.
Old May 15th, 2023, 09:25 AM   #7
MCPhotographer
I appreciate the input. So then what do you think might be causing the issue then? What would cause the carburetor to not generate enough suction as it ran?
Old May 15th, 2023, 02:22 PM   #8
It may not be carbs. Petcock hasn't been confirmed fully operational. Hook up vacuum gauge again and measure what vacuum-level is required to open up petcock to full flow. And leave it for while and see if vacuum drops. Sure sign of leaking diaphragm.
Also want to verify that there's zero flow when petcock is at rest with no vacuum.
Old May 15th, 2023, 03:06 PM   #9
MCPhotographer
Hey Danno. I don't know why I didn't see the picture and diagram you listed earlier, but I didn't. That is definitely helpful. I will spend some time on it tomorrow. I'm thinking the vacuum hose is loose/leaking on one of the ends. Need new hose and new clamps to be sure.
[motogp.com] - Miller: “Being patient isn’t one of my strong points!” Ninjette Newsbot Motorcycling News 0 February 17th, 2018 06:21 AM
[motogp.com] - Kent: “Our pace here isn’t as strong as it was in Germany" Ninjette Newsbot Motorcycling News 0 August 8th, 2015 01:20 PM
88-07 Gas Cap Gasket, Petcock, Vacuum Slides shiftdrift06 Items Wanted 2 December 4th, 2014 02:38 PM
Gas and Vacuum line maintenance? ProdigyRacingLA 2008 - 2012 Ninja 250R Tech Talk 4 March 11th, 2014 10:16 PM
engine vacuum syncronization inspection Domagoj 2008 - 2012 Ninja 250R Tech Talk 1 June 8th, 2011 11:14 PM
