September 19th, 2014, 06:13 PM | #1 |
Join Date: Aug 2014 Motorcycle(s): 2007 Ninja EX250 Posts: 19
Please help, oil in air box.
I was taking my air box out of my bike and noticed that there was a bunch of oil in the bottom of the box. It was coming up through the little rubber hose attached at the bottom that leads into the where the oil is. Is this a breather for the oil sump? Why is this happening?
September 19th, 2014, 06:41 PM | #2 |
It is part of the crankcase ventilation system. The intake creates a vacuum and pulls the oil vapors from the crankcase. Overtime the vapor condensates and deposits at the bottom the airbox. I am not quite familiar with the older ninja 250s but I would imagine there be a drain. Excess amount of oil could be due to over oiling the air filter, overfilling the crankcase, or from tipping the bike over. Also doing wheelies will do it too.
September 19th, 2014, 07:01 PM | #3 |
Why? Did you recently change your oil or add oil? Could be slightly overfilled.
air box | John D | 1986 - 2007 Ninja 250R Tech Talk | 10 | September 4th, 2012 08:07 PM |
K&N air filter to stock air box | Graugaard | 2008 - 2012 Ninja 250R Tech Talk | 29 | July 28th, 2012 06:33 AM |
Loss of oil and Air filter soaked in Oil | 08ninja250 | 2008 - 2012 Ninja 250R Tech Talk | 19 | August 9th, 2010 05:35 PM |
Oil in air box... | Masson | 1986 - 2007 Ninja 250R Tech Talk | 16 | June 15th, 2009 09:16 AM |
Issue with leaking oil ... no hose on air box ? | thsadmin | 1986 - 2007 Ninja 250R Tech Talk | 10 | May 9th, 2009 06:18 PM |
