Old April 5th, 2014, 09:34 PM   #1
mrudich
mrudich's Avatar
Motorcycle(s): 2005 Kawasaki Ninja 250
Replacement Chain and Sprockets
My current chain is seeming like it needs to be replaced, and so I'm going to replace the chain and both the sprockets (Thinking of changing front sprocket to a 15t instead of a 14t). I'm not sure what to get though. What chain and sprockets do you guys use? Is there a certain brand that's superior? A specific chain in particular? Same goes for sprockets.
Note: I'm trying for as cheap as possible (as I'm sorta stripped for cash) But I obviously don't want to get a crap chain/sprocket and have it wear out really quick (Or even break).
Thanks for the help!
mrudich is offline   Reply With Quote
Old April 5th, 2014, 09:37 PM   #2
Look at the bottom of this page; there are quite a few threads that should help point you in the right direction.
Old April 5th, 2014, 09:37 PM   #3
I wrote up a perfect response to this question before, if I could only find the link....
Old April 5th, 2014, 09:39 PM   #4
Here it is...
http://www.ninjette.org/forums/showt...23&postcount=2
Old April 5th, 2014, 09:42 PM   #5
mrudich
mrudich's Avatar
Alright I'll check out those links.
Thanks!
Old April 5th, 2014, 10:10 PM   #6
mrudich
mrudich's Avatar
Does changing the sprocket size change the chain size?
I'm switching my front sprocket to a 15t instead of a 14t. Normally the ninja 250 uses a 106 link chain, and I was wondering if the chain length has to be changed to match the sprocket teeth increase. Thanks!
Old April 5th, 2014, 10:25 PM   #7
/merged
No, there is plenty of extra slack in the stock chain length to make up for going up one tooth in the front. We only need to consider a longer chain if we're going up something like 3 or more teeth in the rear, and even then it depends.
new chain and sprockets yogurtpooh 2008 - 2012 Ninja 250R Tech Talk 11 January 31st, 2015 02:11 PM
chain and sprockets replacement jcsalazar 2008 - 2012 Ninja 250R Tech Talk 6 August 24th, 2014 02:19 AM
Chain and sprockets... LoneRonin Items Wanted 5 February 25th, 2013 07:06 PM
New chain and sprockets. erbarry88 2008 - 2012 Ninja 250R Tech Talk 3 October 15th, 2012 09:59 AM
Sprockets and Chain indr 2008 - 2012 Ninja 250R Tech Talk 8 February 6th, 2011 04:51 PM
