Old August 28th, 2011, 04:02 AM   #1
Sfor6285
Motorcycle(s): 2011 Kawasaki Ninja 250r
Hard to start
I just bought a 2011 250r about a week ago. It is really hard to start and takes forever to warm up. I only have 250 miles on it. It makes it really hard to just jump on it and ride somewhere. I have friends with bikes (not 250s) that don't have this problem. I was wondering if I'm always going to have this problem or if it will get better after the bike gets broke in or if there is something I can buy that could help this problem.
Sfor6285 is offline   Reply With Quote
Old August 28th, 2011, 04:56 AM   #2
Live2ride
Live2ride's Avatar
Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r
It can be normal for the bike to take longer to warm up than most other bikes because our ninja 250's are carburated in the U.S. unlike other parts of the world and other fuel injected bikes. With fuel injected bikes, the bike automatically adjusts the fuel / air ratio to have seemingly no warm up time. Unfortunately carburated bikes can't auto adjust the fuel / air ratio, therefore it takes time to warm up.
I never wait for my bike to warm up; I either start it and go or just let it run while putting my gear on which doesn't take anymore time than normal. Once you get use to just firing up and going it won't be a problem; or at least it isn't for me. I taught myself how to control the throttle while the bikes warming up so I lose practically no time at all. If you absolutely just can't deal with that then there is a kit that allows you to change over to a fuel injected system but that would set you back around $500-$600 and it takes a lot of know how to install it.
P.s. you can ride the bike while the choke is engaged.
Live2ride is offline   Reply With Quote
Old August 28th, 2011, 05:04 AM   #3
greatwhiteninja
Ridin Dirty
Motorcycle(s): 2011 white se 250r , 2008 zx6R
i shimmed my bike fairly early on , probably 200 miles on it.. but it started alot easier with the carb shimmed.. most times without even using the choke. if i were you, i would shim the carb with 2 washers and remove the snorkel.. will most likely start alot easier and even run better.
#1
greatwhiteninja is offline   Reply With Quote
Old August 28th, 2011, 08:21 AM   #4
Live2ride
Live2ride's Avatar
+1 I did this and it does tend to start easier; plus it only costs $1 for the washers.
Old August 28th, 2011, 09:09 AM   #5
Are you using the choke lever?
Old August 28th, 2011, 09:17 AM   #6
Sfor6285
Talking
Cool I know how to remove the snorkel. But I don't understand About shimming carbs. Do you know where I can find some instructions or pics would be cool. I've worked on alot of things but a motorcycle isn't one of them.
Old August 28th, 2011, 09:22 AM   #7
Check out the DIY ("Do it Yourself") sticky at the top of the tech section. There are a few great threads on shimming, jetting, etc.
Old August 28th, 2011, 09:22 AM   #8
Boom King
So, where's the reverse?
Boom King's Avatar
Part and parcel of owning a carbed bike. Starts are harder in cooler weather and if the engine hasn't been run in a few days or more. When you say it's hard to start, is the engine turning over? Normal warm up, meaning warm enough so that you can ride it gently for the first 5 minutes should not take much longer then about 3 minutes or so.
Old August 28th, 2011, 09:24 AM   #9
Sfor6285
I'll start it w/o the choke and It will run for a few mins then die. The only way I get it to start then is use the choke. Then I let it run like that till it soundslike it has stopped sputtering. Disengage the choke and it usually runs fine then.
Old August 28th, 2011, 09:27 AM   #10
Don't disengage the choke. Just get on the bike and ride with the choke engaged, and turn off the choke only after you've gone a minute or two, and all will be fine. Warming it up while stationary for that long isn't necessary, and it doesn't do a great job of warming it up anyway. Under a light load, everything gets up to temp right quick.
Related threads:
http://www.ninjette.org/forums/showthread.php?t=77150
http://www.ninjette.org/forums/showthread.php?t=16276
Old August 28th, 2011, 09:33 AM   #11
Sfor6285
No it turns over fine. I live in Louisiana so the weather usually stays pretty warm 24 hours a day. Ive never really timed it but I know it's longer then 5 mins. I have to wait till my legs start sweating because the motors so hot. If I twist the throttle any time before then it feels like the engine is lug back.
Old August 28th, 2011, 09:43 AM   #12
Boom King
Boom King's Avatar
It should not normally take longer than 5 mins if you've been using the bike on a regular basis. Are you killing the choke right away after you start it? Let it idle with the choke open until the tach needle runs > 2000 rpms and let it sit there for about a min and then smoothly close the choke. Your tach should then read around 1200 rpms. Let it run there for about another min or so and you should be good to go. Smoothly rev, but don't kill the throttle a couple of times to make sure the engine is responsive. You can also run it the first few minutes with the choke open like Alex said.
The only times I've been able to start with no choke is when we get a few days straight of hot and humid weather or when the bike is still warm from a ride. People who shim their needles are also able to do this.
Hard to start sometimes? SwagenGTI 2008 - 2012 Ninja 250R Tech Talk 3 May 7th, 2013 08:38 PM
Hard start in Hot Weather Lou 2008 - 2012 Ninja 250R Tech Talk 17 July 13th, 2011 01:33 PM
[roadracingworld.com] - Rossi Ready To Start 'Hard Work' On Friday At Indianapolis Mo Ninjette Newsbot Motorcycling News 0 August 27th, 2009 04:20 PM
Hard to start after sitting in 100 deg heat all day voodoomaster 2008 - 2012 Ninja 250R Tech Talk 6 August 5th, 2009 05:09 PM
hard to start conchwanab 2008 - 2012 Ninja 250R Tech Talk 4 May 7th, 2009 02:30 PM
