Old October 6th, 2015, 01:11 PM   #1
JayJay
Question Chain & Sprocket?
I'm confused, and worried.
I have a '12 250. Recently, probabbly right around 1k miles ago, i put him in the shop, got new tires, had a new sprocket and new chain put on and all was well. We had to do a little adjusting because we were riding crooked for a bit, but we got it handled and everything was torqued tight and all was well again.
Rode about 5-600 miles, then tightened the chain, like normal. All was STILL well.
I rode him to work yesterday. noticed i heard what sounded like the chain jump ONCE on my way to work, didn't think anything of it because we have a rocky road, i figured it was a rock hitting something, rode fine. Rode home, round trip about 75 miles. Heard the chain making racket on the way in. So when i got home my boyfriend and i checked it out. The chain was EXTREMELY loose. He says like loose to the point of it not being able to be tightened. We looked on the chain, at every link, for any marks or signs of stretching or anything abnormal. nothing was off.
Can someone help?? I'm at a loss. and terribly sad that i can't ride my bike in the gorgeous weather.
Also, sorry for the ridiculous long post, just wanted to include as much as possible.
JayJay is offline   Reply With Quote
Old October 6th, 2015, 01:39 PM   #2
Ghostt
Ghostt's Avatar
My first question is how many links is the chain? If the correct amount of links it should be adjustable.
Count the links, and also what gears did the shop put on, how many teeth?
Pictures of the adjustment?
violente et ignorantia
ZX-2R BLOG
Old October 6th, 2015, 02:04 PM   #3
JayJay
Not sure about how many teeth, It was correct before this happened though.
It's geared 14/45? It's geared stock still, we just put new sprockets on it.
Old October 6th, 2015, 02:28 PM   #4
Ghostt
Ghostt's Avatar
Yes that's the OEM gearing, so now you need to count the links, if too many, then that's why your chain is already at the maximum adjustment.
ZX-2R BLOG
Old October 6th, 2015, 02:37 PM   #5
JayJay
I'm not sure, when i had the shop put it on they said they cut it down to be right. The chain fit perfect for a while, and when we tightened it, it was very minimal. After we tightened it after that, it was great until recently.
Old October 6th, 2015, 02:41 PM   #6
Ghostt
Ghostt's Avatar
OEM length is 106 links, since they cut it, I would take the time to verify it.
After that I would bring it back to the shop, and have them check it out, a new chain shouldn't stretch that much.
ZX-2R BLOG
Old October 6th, 2015, 02:44 PM   #7
JayJay
Okie dokie. I'll check it out tonight.. That atleast gives me somewhere to start.
My dad told me to check that my rear axle didn't move forward.... but we will see....
Old October 6th, 2015, 03:53 PM   #8
cbinker
cbinker's Avatar
pictures are worth a thousand words in this situation.
TEAM ALFALFA
www.apexassassins.com
Old October 6th, 2015, 07:29 PM   #9
JayJay
I'll get some pictures in the morning. My boyfriend and i worked on it some this evening. We tightened the chair, got everything tightened up and situated. He took it on a little test ride. About a mile. Came back, the chain was LOOSE. Like 2 inches of slack. :/
Old October 6th, 2015, 07:38 PM   #10
cbinker
cbinker's Avatar
TEAM ALFALFA
Old October 8th, 2015, 09:11 AM   #11
JayJay
Not gonna provide pictures, but that's just because we found the issues.
Volar chains are no bueno. I got the phone call from the shop and they told me the chain is just stretching as soon as any tension is put on it.
DID here we come.
Old October 8th, 2015, 03:55 PM   #12
DID here we come.
Good choice.
Old October 8th, 2015, 04:26 PM   #13
Ghostt
Ghostt's Avatar
DID here we come.
Didn't the shop put the chain on? Didn't they supply the chain?
ZX-2R BLOG
Old October 9th, 2015, 09:32 AM   #14
JayJay
The shop did put the chain and sprockets on, but we supplied the chain and sprocket set. We made a decision to buy the chain and sprocket set online, got a decent deal, but didn't realize the poor quality due to the lack of reviews. All in all, a $50 lesson. Nothing to break the bank, and no injuries, Thankfully!
Old July 8th, 2016, 07:25 PM   #15
Fluidlogic
Fluidlogic's Avatar
Motorcycle(s): 2017 Ninja 300
Originally Posted by cbinker View Post
Wait, WTF? What's up with your "TEAM ALFALFA Fluidlogic swallows" stuff?
Fluidlogic is offline   Reply With Quote
Old July 9th, 2016, 12:04 AM   #16
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
It's a code this forum uses to replace the tag with the username of the person logged in. So, you see your name on your screen, while I see my name on my screen.
Understand, Unregistered?
(Click quote to see the code.)
<-- Linky
Old July 9th, 2016, 07:35 PM   #17
cbinker
cbinker's Avatar
hahahaha
TEAM ALFALFA
Old July 10th, 2016, 01:49 PM   #18
Fluidlogic
Fluidlogic's Avatar
Gotcha. I accidentally piss off so many complete strangers that I've lost track of it, but I rarely post here, so I was confused.
Getting a new chain and sprocket kittyslasher 2008 - 2012 Ninja 250R Tech Talk 10 December 9th, 2013 12:55 AM
New chain & sprocket suggestions! hawker1693 2008 - 2012 Ninja 250R Tech Talk 12 September 23rd, 2013 07:30 AM
Chain and Sprocket Discoveries... ExpatJohnny 2008 - 2012 Ninja 250R Tech Talk 10 January 25th, 2012 10:02 AM
Racing: Tires & Chain/Sprocket setup... Order Ninjettes At Speed 30 March 4th, 2011 11:26 AM
Gold chain and sprocket?? Tintkng 2008 - 2012 Ninja 250R Farkles 15 March 29th, 2010 01:31 PM
