August 22nd, 2013, 09:43 AM | #1 |
Name: Not Applicable
Join Date: May 2013 Motorcycle(s): 2007 Blue Ninja 250 Posts: 171
Getting off the line (15/45)
So my ninja is basically stock except for the 15tooth in the front, I don't want to change the gearing because I like how the bike runs at lower RPMs on the highway but I will if it's recommended.
When I get into town, I sometimes find the bike "chugs" along sometimes if I don't rev the engine enough and engage clutch fully sooner when I get off a red light in 1st gear. Now this isn't a huge issue for me but sometimes I want to get going quicker to avoid strange situations like Sally on her phone coming up behind me when the light turns green. Questions: Whats the best RPMs to have the bike at before slipping the clutch? How will this affect my clutch plates? What about giving a large push with my leg during take off? If I do go back to stock gearing, is running the bike at 10-11k RPM on the highway for 30mins-1hour that good for it? I've read that it may burn oil when rode like that... Note: I do plan on removing the air box and installing an efi kit in a couple of months (whenever I have some damn time...) for some extra power to compensate. Thanks for reading/skimming this. |
August 22nd, 2013, 09:50 AM | #2 |
dirty boy
MOTM - Apr '14
Sounds like you need to work on your throttle and clutch control for take offs. The bike is more than capable with stock gearing or 15t front sprocket.
As far as high rpms for long durations. With stock gearing I hit around 80mph indicated while in 6th gear at 10k rpms. Most states have highway speed limits at 65mph, obviously there are a few with higher but 80mph is still fast enough. I have heard that the oil pump does not work well past 12k rpm, it is something I would look into if it concerned me.... it doesn't. These bikes like to be run hard IMO
August 22nd, 2013, 09:57 AM | #3 | |
August 22nd, 2013, 10:36 AM | #4 | |
2. I have 20K miles on my original clutch. 3. You're already sitting on 35+ hp. If 1 additional leg is needed to get it off the line, something is wrong. 4. I commute daily and spend 10-15 min at a time in the 10K-11K range. Never burned any oil. For street riding, I like 15/45 much better than stock. An EFI kit will help with cold starts but it is not going to make anymore power. As subxero said, it sounds like a throttle/clutch timing issue. If not, it could be dirty carbs or incorrect jetting.
August 22nd, 2013, 10:42 AM | #5 |
15t/45t here, hold 10k rpms when you get just over 1/2 clutch feathered out, PIN IT and dump the rest. hahahahahhaha jk yo
The street is a scary place sometimes. Work on your 6th sense and you will not need to launch so much. But when you do... you really need to. Good luck out there.
August 22nd, 2013, 10:44 AM | #6 | |
August 22nd, 2013, 10:45 AM | #7 | |
August 22nd, 2013, 10:50 AM | #8 |
You don't have to be crazy with the launches to get a smooth and quick launch from a light.
Give it a good twist, maybe 1/4-1/3 throttle, feather the clutch to keep the rpm's around 3000 until the engine and transmission are at the same speed, then keep on the throttle. If you're getting chugging or jerking, go to a parking lot and practice stops and starts a lot. You'll see quick improvement in your clutch and throttle muscle memory. |
August 22nd, 2013, 10:52 AM | #9 | |
Join Date: Mar 2013 Motorcycle(s): 2011 Ninja 250 Black Posts: 30
If the clutch is still partially engaged at 6K+ it will probably wear faster. Have you tried pushing your bike while sitting on it? I can barely get it moving... Running at high RPMs is normal for this engine. AFAIK a bit of oil burn is also normal. |
August 22nd, 2013, 10:53 AM | #10 | |
August 22nd, 2013, 10:58 AM | #11 |
Yep, that's in stock dress. 32+ is a well tuned bike with a full system/air mods/jetted. 35 is kinda tough to get.
August 22nd, 2013, 11:10 AM | #12 |
Yes, sorry. Meant 25, not 35.
August 22nd, 2013, 11:25 AM | #13 | |
Weak or not due to wrong mix or low compression, your engine should deliver abundant torque at higher rpms'. As a palliative, you need to slid that clutch as much as needed and to open that throttle gradually (clutch-out slowly while twisting the right wrist slowly) for not killing the high rpms', while you are feeling that pushing force forward (don't look down onto the tachometer, just feel the vibrations and hear the noise of the engine). No need for worries, you cannot damage that clutch by doing that. Practice much until you master it. It is going to become handy when riding two-up or uphill.
August 22nd, 2013, 11:43 AM | #14 |
Join Date: Jul 2013 Motorcycle(s): Green Ninja 250 2008!!!! Posts: 202
My bike never chugs off the line, although mine is a newgen and I drove a manual so my takeoff is pretty good. Sounds like your bike may have an issue, i think motofool said you have too many mods, he might be right cuz the bike should be zippy when your on the gas, it always is for me.
Also, by the engine chugs along, do you mean the engine is bogging? Because it shouldn't ever bog in the correct gear unless you have mechanical issues... |
August 22nd, 2013, 12:21 PM | #15 | |
August 22nd, 2013, 01:07 PM | #16 |
MOTM - Mar '13, Jun '14
I thought it was raining up there!
August 22nd, 2013, 01:08 PM | #17 |
August 23rd, 2013, 06:00 AM | #18 |
Join Date: Aug 2011 Motorcycle(s): Black '09 Kawasaki Ninja 250 Posts: 51
Fuel line came loose from somewhere? | Kurgan | 2008 - 2012 Ninja 250R Tech Talk | 9 | November 22nd, 2014 08:46 PM |
Red-Line Changes | quarterliter | 1986 - 2007 Ninja 250R Tech Talk | 11 | September 29th, 2013 12:26 PM |
Was I out of line? | ai4px | General Motorcycling Discussion | 78 | August 24th, 2013 08:43 PM |
New rear brake line? | CaptainPlatypus | 1986 - 2007 Ninja 250R Tech Talk | 3 | May 21st, 2013 08:07 PM |
Any admin on line. | SteveL | Help | 8 | April 14th, 2009 11:47 AM |
