September 5th, 2014, 07:40 AM | #1 |
#squid
Join Date: Jul 2011 Motorcycle(s): Track dedicated 2008 ZX6R Posts: A lot.
MOTM - Jul '16
Tire change questions
Should I remove the rotors? I have a lot of room in the rear but up front I have two fairly large rotors and it might be easier to remove them. If I do, will I have to mount them the same exact way ? Should I flip/rotate them ? Will they warp and be unomountable afterward ?
September 5th, 2014, 07:51 AM | #2 |
When possible, keep everything the way it is. And no, you don't have to remove the rotors to get a tire changed. If you're changing your own tires, then you might consider removing them if you feel you may hit them.
September 5th, 2014, 08:07 AM | #3 |
#squid
MOTM - Jul '16
I don't think I will hit them but things nearly never go as planned lol
Also, how do you guys feel about balancing on the bike ? My other idea was to put the wheel on to jacks and have it rest on the axle. What should I do? Maybe I could just do it on the bike though. I'm gonna duct tape them this time. I think my rear wheel threw a weight and it scratched up my wheel. Darn.
September 5th, 2014, 08:12 AM | #4 |
The jacks will be fine as long as you can level it out, I use 2 jack stands. Losing wheel weights happens, we duct tape them over at the track so they don't become bullets. Use pink duct tape lol, it's a good conversation starter.
September 5th, 2014, 08:17 AM | #5 |
#squid
MOTM - Jul '16
I already bought green and pink duct tape
Thanks a bunch man. Here's a batch of coookies
September 5th, 2014, 05:32 PM | #6 |
ran when parked
Join Date: Aug 2013 Motorcycle(s): Freeride 250R, KLX250SF, mopeds Posts: A lot.
MOTM - Sep '17, Dec '14
go to a shop with a tire machine and digital wheel balancer and get them to do it for you
September 5th, 2014, 06:06 PM | #7 |
#squid
MOTM - Jul '16
If I can do it for free...
September 5th, 2014, 06:42 PM | #8 |
ran when parked
^my every other sentence
Lots of oil change questions. | Ninja Rob | 1986 - 2007 Ninja 250R Tech Talk | 130 | January 8th, 2015 04:27 PM |
Tire questions | capriccio | Ninjettes At Speed | 2 | May 31st, 2012 01:53 PM |
Tire questions | Bols | 2008 - 2012 Ninja 250R Tech Talk | 1 | September 6th, 2010 11:59 AM |
More Tire Questions | minuslars | 1986 - 2007 Ninja 250R Tech Talk | 4 | August 28th, 2009 11:17 PM |
Did 1st oil change--have questions | birdy | 2008 - 2012 Ninja 250R Tech Talk | 9 | March 19th, 2009 10:20 AM |
