June 30th, 2014, 08:52 AM | #1 |
Daily Jap rider
Join Date: Dec 2012 Motorcycle(s): 2012 Ninja 250r Posts: A lot.
so F-ing pissed right now
So I decided to take off the tank slapper protector I had on for last two years and put on a regular tank protector. I bought the $20 one at cycle gear and followed the directions completely. The 3M tape stuck fine to my tank, but the protector itself peeled off from the adhesive. I then tried to put it back on and tape it down with making tape overnight to see if it would form to tank, to no avail this did not work. Then I went balls out and put clear silicone on it, still won't stay down and my tank looks like a ****ing disaster! Don't know what to do next, or how to even remove the 3M adhesive. Please help!
June 30th, 2014, 08:54 AM | #2 | |
Blind 250 Loving Whore
June 30th, 2014, 08:58 AM | #3 |
Daily Jap rider
June 30th, 2014, 09:00 AM | #4 |
Join Date: Mar 2011 Motorcycle(s): 09 Ninja 250r Posts: 634
clean it proper and apply a ProGrip tankpad...
”Any man dies with a clean sword, I’ll rape his f***ing corpse!”- The Hound |
June 30th, 2014, 09:02 AM | #5 |
After you get it all off and you get your new tank pad, make sure to clean the area with Isopropyl Alcohol/water mix before putting it on. Like 50/50 in a spray bottle is fine.
June 30th, 2014, 09:05 AM | #6 |
Pro hillbilly trick: try an eraser, maybe a bit of heat from a hair dryer too
When the job is big or really tough a 3M adhesive eraser wheel normally does the job with ease, but.... you can knock off the clear with those wheels on a drill.
June 30th, 2014, 09:20 AM | #7 | |
Daily Jap rider
Yeah, that's what I'm afraid of, clearing off the clear coat |
June 30th, 2014, 09:22 AM | #8 |
Daily Jap rider
What makes the progrip better than the speed metal? Don't they both use the 3M adhesive? The speed metal one from cycle gear does
June 30th, 2014, 09:28 AM | #9 |
The most difficult part to remove will be the clear silicone you put on. The other adhesive should roll-up with sideways pressure or try some duct tape to pull it/slide it off.
Next step would be adding heat from a hair dryer. Then using Goo Gone or some type of solvent that will not harm the finish. The silicone doesn't breakdown easily though, and most likely will be the most difficult to remove. I've used Mineral Spirits and Acetone to help remove dried silicone, but you need to be careful of the paint. As noted - clean it very well before trying to apply a new one. Because of the silicone, I would spend some extra time cleaning. If nothing is working, post a photo. |
June 30th, 2014, 09:50 AM | #10 | |
Daily Jap rider
June 30th, 2014, 10:21 AM | #11 |
If the problem started with the adhesive pulling off of the pad itself, I would contact the company - that's their responsibility. Getting it to stick to the tank is yours.
June 30th, 2014, 10:25 AM | #12 |
Join Date: Mar 2014 Motorcycle(s): 2013 Ninja ZX6R, 2009 Ninja 250R Posts: 256
I never use the adhesive that comes along with the pads. They always suck for me. I peel it off and use silicone adhesive and let it cure over night. To remove, blow dryer followed by goo gone.
June 30th, 2014, 10:31 AM | #13 |
dirty boy
MOTM - Apr '14
just for future reference WD40 works fairly well for removing adhesive glue whatever.
June 30th, 2014, 11:35 AM | #14 |
EX500 full of EX250 parts
http://www.mag-knight.com/ may be of interest to you... The 500's tank doesn't have a regular "sportbike-shaped" crotch area, so I got a couple of the universal ones. After a little trimming and softening it with the heat gun, it fits pretty well. It's stuck on there until I peel it off, but it's not permanently glued to it.
June 30th, 2014, 12:44 PM | #15 | ||
Join Date: Feb 2012 Motorcycle(s): '09 Ninja 250r (SOLD) - Black. 2011 ZX-6R Green/Black - 2001 Garbage Bag Green KLR650 Posts: 275
It can happen even to a reputable company. When I bought my Tech Specs the same thing happened on one of the pads. I took pictures, emailed them to Tech Spec and they replaced it with no other questions asked. Shipped it for free and everything. |
June 30th, 2014, 12:52 PM | #16 |
Buy jar of natural peanut butter, the kind that separates.
Use the oil to soften the adhesive. I'm not kidding. Don't know if this works on silicone or not, but it work great on stickers.
July 1st, 2014, 09:58 AM | #17 | |
Join Date: May 2012 Motorcycle(s): 2011 Ninja 250R Special Edition (sold), 2017 CRF250 Rally Posts: 384
Goo Gone works very well, on OEM stickers (got my 2011 SE stickers off and the remaining adhesive cleaned very well with that) and some tape for hockey pad (wanted to protect my tail section while touring with saddle bags (but with the sun exposure and heat, the adhesive decided to stay on the bike and not on the tape) And bonus, it smells citrus... |
July 1st, 2014, 10:40 AM | #18 |
FYI they sell goo gone at 99 cents store.
July 1st, 2014, 03:36 PM | #19 |
Daily Jap rider
July 1st, 2014, 07:57 PM | #20 |
July 1st, 2014, 08:08 PM | #21 |
I see that the title was censored.
Hope it cleans up easily, OP. |
July 9th, 2014, 10:59 AM | #22 |
Daily Jap rider
So I returned the tank pad back to cycle gear, which wasa horrible experience. The female employee there was a complete c**t. She always is, but this time she pissed me off enough that I contacted customer support, needless to sayi will not be going back there. Hated having to drive thru the ghettos of Houston anyways. Thank you to all that suggested the Goo Gone. It worked perfectly. My new pro grip tank pad will be arriving in the mail today. Hope all goes well with this one. Will post a follow up after installation.
July 9th, 2014, 02:41 PM | #23 |
Daily Jap rider
Just got new pad put on. What a difference in the adhesive quality. One difference though is the speed metal pad was real carbon fiber and was thicker, but I think that the thickness was part of the reason it wouldn't form to the tank.
2014-07-09 16.39.04.jpg |
any help id'ing this 2 into 1? | tiii | 1986 - 2007 Ninja 250R Tech Talk | 7 | September 30th, 2014 06:30 PM |
F***ing Cyclists getting in the way | rojoracing53 | Videos | 49 | September 13th, 2013 12:18 PM |
****ing cagers! | Joshorilla | !%@*#$%!)@#&!%@ I crashed! | 20 | December 15th, 2012 10:11 AM |
****ing Pig | Kevin2109 | Videos | 21 | December 30th, 2011 08:20 PM |
F'ing thieves | Cab305 | General Motorcycling Discussion | 13 | October 31st, 2010 01:04 PM |
