April 11th, 2016, 05:10 PM | #1 |
Join Date: Apr 2016 Motorcycle(s): 2007 ninja 250 Posts: 6
2007 ninja 250r sticky throttle
just trying to figure why my throttle seems to be so sticky. i try reving the bike and it kills it sometimes, i probably need to get the carbs cleaned but it still doesnt make sense as to why when the bike is up to temp i can pull the throttle all the way back and have no response in revs from 2k and then have it kick back in at 8k. any ideas or help? please
April 11th, 2016, 05:32 PM | #2 | |
I would say there is a blockage somewhere. With no load on the engine it doesn't take much throttle opening to rev up. Read this section carefully a few times before working on them - http://faq.ninja250.org/wiki/How_do_...n_the_carbs%3F |
April 11th, 2016, 05:37 PM | #3 |
Join Date: Dec 2015 Motorcycle(s): 2008 Ninja 250 Posts: 210
Does it start and idle fine?
Does it stumble from idle and you have to baby the throttle to get it going? Is the Power intermittent and cuts out all throughout the rpm range? Dirty carbs or vacuum leak would be my guess. But you may need to provide some more info to receive a helpful answer. Do you have any mods on the bike? Or is it all stock? |
April 11th, 2016, 05:49 PM | #4 |
all stock as far as i know. it does start and idle okay after its warmed up with the choke fully on. it left me stranded at walmart one day because it had been going perfectly fine and then the throttle kept cutting out on me which would kill the bike. :/
April 11th, 2016, 05:51 PM | #5 |
thanks for the help.
I would like to thank everyone who has/will reply, i really appreciate the help, just trying to get my bike running again so i can get off my permit and onto my actual license
April 11th, 2016, 05:52 PM | #6 |
Going with jkv45 on this one. Give the carbs a thorough cleaning and that should take care of it.
April 11th, 2016, 05:52 PM | #7 | |
April 11th, 2016, 06:26 PM | #8 | |
I like Techron Concentrate better than Seafoam for serious cleaning, but I still don't know that it will fix the problem. |
April 11th, 2016, 06:48 PM | #9 |
Wolf-
there is no substitute for a comprehensive, physical cleaning note your bike is 9 years old, coming out of winter storage, i'd guess? modern ethanol fuels do not help at all, "dropping out" quickly
April 11th, 2016, 07:09 PM | #10 | |
That means that you manually open the butterfly, but the injection of fuel into the airstream depends on the resulting vacuum induced by the engine during the intake strokes. It seems to me that the one or both diaphragms could be damaged or the guides/slides are dirty enough to difficult the free up and down movement of the plunges/needles.
April 12th, 2016, 05:44 AM | #11 |
^ very difficult pinpointing diagnosis via keyboard with info provided
the suggested carb pull/cleaning would reveal obvious faults upon disassembly and inspection The correct repair path does entail going way beyond pouring some Seafoam in the tank, though.
April 14th, 2016, 10:40 PM | #12 |
i started her yesterday with the help of starter fluid but it seemed to only live off the starter fluid. revving it killed it after that, if that helps
April 15th, 2016, 05:33 AM | #13 |
the induced fuel source is bypassing your clogged fuel flow from within the carburetor(s) thus allowing temporary running. Yes, a carb pull/inspection def necessary.
April 15th, 2016, 05:46 AM | #14 |
^this
April 18th, 2016, 10:38 PM | #15 |
thanks you to all for the help. once i can get some vacation days off i will be pulling the carbs and hopefully cleaning them myself
Oil Leak and Sticky Throttle | hamburglar | 1986 - 2007 Ninja 250R Tech Talk | 12 | June 4th, 2014 05:11 PM |
[2009 250R] Sticky Throttle (?) + Poor Idling | 255 | 2008 - 2012 Ninja 250R Tech Talk | 8 | May 30th, 2013 01:00 AM |
possible sticky throttle? | gt_turbo | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 9th, 2012 03:53 AM |
brand new Ninja, stiff/sticky throttle | reaubideux | 2008 - 2012 Ninja 250R Tech Talk | 5 | April 4th, 2011 11:08 AM |
