Go Back   ninjette.org > General > Ride Reports
Old August 12th, 2012, 08:13 AM   #1
the big mike
the big mike's Avatar
Motorcycle(s): 2008 Ninja 250r, Fazer8
Flat tire and a horrifying outlook for tomorrow
so, yesterday I decided to spend the day riding my beloved ninjette. It was beautiful outside with a clear sky and a very nice temperature. After about 150 km, and still 50 km away from my house, I felt like it was time for a break.
The moment I got off my bike, I started hearing a sissing sound and after looking for about a minute, I found this guy in my tire (see pic)
I called my insurance and they sent a truck to pick me and the bike up. I decided it was best to drop the bike at the dealer so that the tire could be replaced the day after.
The problem is that I just found out today that the dealer is on holiday for another two weeks and the bike is just standing there where I left it, only protected by a brake disc lock.
So, as I know nobody with a suitable trailer and don't want to pay for transport, nor leave it there... I'll put on some sport clothes tomorrow and push a 169kg bike with a flat rear tire for 20km to bring it home again.
Looks like I'll be having my own olympics I'm gonna die
I can not be a true player by playing around.
the big mike is offline   Reply With Quote
Old August 12th, 2012, 08:20 AM   #2
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Plug it and ride it home.
Old August 12th, 2012, 08:25 AM   #3
the big mike
Plug it? with what?
and to be honest, I've never done anything with my tires
Is it as easy to pump it up as with a bicycle? I suppose I'd need another pump though...
Old August 12th, 2012, 08:26 AM   #4
lgk
you could plug it, buy a 12v compressor, and ride to your house...
just get a kit made for tubeless cars tires, from your auto parts store or your equivalent of walmart.
or get a good workout...
you expend more energy than a marathon, but less than the ironman triathlon.
since the tire flat i imagine it will be tough.
Old August 12th, 2012, 11:56 AM   #5
worst case is a gas a station fix..... but will get you home
1. tire plug kit $4.89
2. one can of fix a flat $3.98
Ride to nearest air station and inflate to proper psi and go straight home
Go slower and be safe
Old August 12th, 2012, 12:59 PM   #6
Originally Posted by the big mike View Post
Plug it? with what?
Yup, just needs to be plugged to get you home. When you say you've never done anything with your tires, were you at least checking their pressure every couple rides?
Old August 12th, 2012, 01:25 PM   #7
the big mike
Other than kicking them every couple rides? no
Tire pressure is checked during maintenance every 6 months... Me, I don't have a clue, we even don't have the needed material...
Now please don't think I neglect my bike. I actually spend a lot of time keeping it clean, lube the chain regularly and I'm sure that I would notice and recognize a problem with my tires. Still a mechanical noob though
Old August 12th, 2012, 01:29 PM   #8
Noted.
Impossible, I tried.
Keep the tires at the proper pressure and your bike will feel transformed; it will handle exactly as intended with no surprises. (somewhere around 28 psi front, 32 psi rear, depending a bit on your chosen tires). The thing about tire pressure is that even if it is absolutely perfect today, is that 3 - 4 weeks from now it is guaranteed to be lower than perfect; all tires lose a certain amount of air over any extended period. If you need an owners manual for the bike, it's downloadable at the top of the tech section.
Old August 12th, 2012, 01:43 PM   #9
Mountain Dew
Ambrosia.
Mountain Dew's Avatar
Motorcycle(s): 1974 Honda CB550K0 W.I.P.
There is no way you're pushing almost 400 lbs with a flat tire 20km. Plug the hole, pump up the tire, and baby it home, or do another dealership.
1. Check your tire pressures, with a gauge every week.
2. Keeping your chain clean means nothing if your tires are too flat coming around a corner and going into a ditch.
Life's better on the Mountain.
Mountain Dew is offline   Reply With Quote
Old August 12th, 2012, 01:53 PM   #10
the big mike
Ok, thanks a lot you guys
I'll look into this plugging thing tomorrow.
Old August 12th, 2012, 02:02 PM   #11
strytnyne
Motorcycle(s): 2012 250r
i been riding with a plugged rear tire for 600 miles.
strytnyne is offline   Reply With Quote
Old August 12th, 2012, 02:24 PM   #12
the big mike
I believe I've read once that a tire that has been penetrated completely is no longer safe to ride as if it's new... Am I wrong?
Either way, I'll put on a new one
Old August 12th, 2012, 02:25 PM   #13
flynjay
flynjay's Avatar
A regular bicycle pump will do. It will take a little bit of pumping but it will get it done.
If I only need to add 2 psi or so I will bust out the bicycle pump (takes about 20 pumps).
http://www.youtube.com/watch?v=fpmxWY4I8kQ
Old August 12th, 2012, 02:51 PM   #14
the big mike
Exactly what I needed to know, thx
Old August 12th, 2012, 03:17 PM   #15
cuong-nutz
cuong-nutz's Avatar
Buy yourself a tire plug kit and bring along bicycle pump. I have my portable mountain bike bike pump with me on long rides and let me tell you, it'll take like 100 pumps to get inflated to proper psi. You could get away with half that and ride to your local gas station or tire place.
You should check your tires daily if not every other day or worse case weekly. Our tires do not hold a lot of air and small changes in temperatures affects tire pressure. Also rubber is slightly porous so you will lose a small amount of air over a period of time.
What really sucks is when you have a nail or puncture in your brand new tire!!!
HalfFast Racing Team
Old August 12th, 2012, 07:49 PM   #16
strytnyne
well im a conservative rider , hyper mile for the most part . don't think a plug would lead to anything catastrophic
Old August 12th, 2012, 08:23 PM   #17
Joule
Joule's Avatar
Motorcycle(s): Black 2011 Ninja 250R FI
w00t is this felony O_O
if u have a punctured tire, then get it patched up or simply do it yourself =_=?
dafuq, why would u replace the tire LOL
http://www.team-bhp.com/forum/tyre-a...-puncture.html here is a DIY for tire repair.
i myself have a puncture repaired, with many nails still inside tire lOl. they don't make tire leak any air though so i never took them out because taking them out means i gotta repair them lol
And i have been riding mine for 6 k kilometres.
whatsup =_=? don't u guys plug your tires and ride them?
dat road rash game
Joule is offline   Reply With Quote
Old August 12th, 2012, 08:33 PM   #18
Joule
Joule's Avatar
it's not gonna blast or something =_=
dat road rash game
Old August 13th, 2012, 01:12 AM   #19
the big mike
but such repairs are only a TEMPORARY solution. perfect for me right now, but I won't keep riding around with it...
Old August 20th, 2012, 10:14 AM   #20
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
In the last three+ years and 46,000 miles that I've ridden I've plugged four flats. One was a double puncture in the front with 15K on that tire, I rode it until it was worn out at 27K. The rest have been rears, and I've worn those tires out with plugs in them. Each time I replace the tire I examine the plugs to see how they look, and they're fully intact. I have zero qualms or concerns riding with a plugged tire. But, I also check my pressure daily so if a plug started to leak I'd catch it before it got too far. So far, though, not a single one has leaked, not even the tiniest amount.
Old August 20th, 2012, 11:31 AM   #21
flynjay
flynjay's Avatar
I'm with frugal.
I got a nail in the rear within 100 miles of installing my current set of tires. I've got 4000 miles them now.
Old August 20th, 2012, 11:51 AM   #22
Vampyre
Vampyre's Avatar
Motorcycle(s): 2011 250R Black, 2005 ZX-6R Blue
My buddy got a nail on his 955i 2 weeks after getting a new rear tire. I plugged it and he rode it down to the wear bars just fine, and not exactly cautious riding either.
Vampyre is offline   Reply With Quote
[motorcycledaily.com] - Tomorrow?s Superprestigio Brings Together MotoGP and Flat Tra Ninjette Newsbot Motorcycling News 0 December 12th, 2014 03:20 PM
[cyclenews.com] - AMA Flat Track: Grays Harbor Rescheduled For Tomorrow Afternoon Ninjette Newsbot Motorcycling News 0 July 20th, 2014 05:10 AM
Have You Ever had a Flat Tire on Your Street Bike? kkim General Motorcycling Discussion 17 August 31st, 2009 11:35 AM
Flat Tire Strategy sm0kediver General Motorcycling Discussion 15 March 8th, 2009 03:26 PM
[roadracingworld.com] - Only One Tire Vendor Will Be Available At Tomorrow's Track Da Ninjette Newsbot Motorcycling News 0 September 18th, 2008 03:40 PM
