Old May 9th, 2013, 06:38 AM   #1
SON1C
Motorcycle(s): 2006 Ninja 250
Clutch issue?
Shifting gears and my clutch (lever?) became stuck backwards? Like permanently back almost vertical, is mine damaged or can yours do this? Been learning to shift softer lol
SON1C is offline   Reply With Quote
Old May 9th, 2013, 06:44 AM   #2
cuong-nutz
cuong-nutz's Avatar
Not sure what you mean by being stuck backwards. Are you meaning the lever is pressed against the grip/handle bar is if you were disengaging the clutch to shift gears? Perhaps your clutch cable is frayed and getting caught at the point where the cable attaches to your lever.
Vertical? Adjustable/folding levers?
HalfFast Racing Team
Old May 9th, 2013, 06:46 AM   #3
SON1C
No it's like this
-- normal
If you hit it too hard l
http://i857.photobucket.com/albums/a...ps2080efbb.jpg
Old May 9th, 2013, 06:54 AM   #4
It should move freely, without any snagging anywhere. Start by lubing and adjusting the cable. Check the barrel connection where it attaches to the lever and grease it as needed.
Vertical?!?!?!? I am scratching my with Cuong..
Old May 9th, 2013, 07:13 AM   #5
DaBlue1
DaBlue1's Avatar
Sounds like you have a loose bolt on your shifter link. Loosen the bolt as much as possible. Inspect the splines on the shaft to make sure they are not stripped. Put the link and shifter pedal back close to a normal position, tighten the bolt and find neutral, loosen the bolt, re-adjust the the shifter link to a good position without moving the shaft from the neutral position, re-tighten the bolt.
Old May 9th, 2013, 07:14 AM   #6
/thread moved to pre-gen tech
Old May 9th, 2013, 07:17 AM   #7
DaBlue1
DaBlue1's Avatar
...I am scratching my with Cuong..
ooo, that sounds weird.
Old May 9th, 2013, 07:18 AM   #8
cuong-nutz
cuong-nutz's Avatar
LOL. Looks like Blue solved this one
Old May 9th, 2013, 07:20 AM   #9
hahahahahah yea, seems I left out a word there.
Old May 9th, 2013, 07:32 AM   #10
DaBlue1
DaBlue1's Avatar
$500 Daily Double
I am scratching my ______ with Cuong..
Alex...What is.....
This can be real fun
Clutch Issue Help Please! R6 RandomPhantom General Motorcycling Discussion 13 March 21st, 2015 05:53 PM
Clutch return issue eddyble 2008 - 2012 Ninja 250R Tech Talk 17 November 3rd, 2014 03:04 PM
Clutch issue ZX-Dominance 1986 - 2007 Ninja 250R Tech Talk 8 July 2nd, 2013 10:23 PM
09' clutch/trans issue cdupont03 2008 - 2012 Ninja 250R Tech Talk 6 April 17th, 2013 01:57 PM
Clutch Issue Shaol1n Monk 2008 - 2012 Ninja 250R Tech Talk 3 November 25th, 2011 09:22 PM
