December 1st, 2010, 06:49 PM | #1 |
Join Date: Sep 2010 Motorcycle(s): 2008 Kawasaki Ninja 250r Posts: 139
Where to have O2 sensor bung welded ?
So, I have decided to purchase an AEM UEGO - I will have an exhaust shop drill the hole and weld the bung on for me.
The guy on the phone said to bring along a stainless steel nut (which I assume he means the bung) if not a mild steel one and just mark where I wanted the hole. I said that it may need to be an extended bung (due to the size of the pipe inside), he said use 2 nuts or he might be able to find a solution..... **I have a full Yoshimura system installed** Question is : Where is the best place to mount it ? I saw a picture where someone on these forums mounted there O2 sensor where the cat would be on stock headers...from some research this seems like a bad position because it gets too hot ? I was thinking somewhere down the line but before the second piece of the exhaust (the muffler). any help would be much appreciated, cheers |
December 1st, 2010, 06:53 PM | #2 |
Howdy! Curious about this myself. There is some info in this thread, had you seen this already?
December 1st, 2010, 07:04 PM | #3 |
Yeap, that's the one - came across it and within about 5 minutes I had found another way to spend money on my bike It's worth it if you ask me...$280AU + / - a bit or $$$ for a new motor...
thanks for the reply |
December 1st, 2010, 07:58 PM | #4 |
I haven't measured the inside diameter of my exhaust (the header side) but I plan too, unless someone has specs and can post them but I found nothing
I believe the total length of the O2 sensor - a Bosch LSU4 - (included with the AEM UEGO) is 84mm. The threaded part is M18 with a 1.5mm thread pitch, from looking at some technical documents my understanding is that from the start of the thread to the end of the sensor is 30mm... I'm trying to figure out how much space the sensor is going to take up in the exhaust...before purchasing everything (although I believe the AEM UEGO also comes with a bung..not sure if it's mild steel or stainless steel). A standard bung is ? ? ? long An extended bung (Innovate Motorsports) is 25mm long << This would need to be cut down. cheers guys |
December 1st, 2010, 08:06 PM | #5 |
I know this isn't going to help much, but if anyone searches for "ninjette bung" on google this is now the top hit, so we're obligated to come up with a good answer.
December 1st, 2010, 08:32 PM | #6 |
ha ha ha I started seeing it pop up in my searches !
last post for now .... in the thread that was mention by Alex, looking closely - a person with a stock pipe used a standard bung and a person with an Area P exhaust used an extended bung (would have thought that would be the other way around lol). If I can use a standard bung good (I can pick a stainless steel one up for $15 about 5 minutes from me), if not I have to order an extended bung in from the US and i'll just have to wait. Still no idea whether the AEM UEGO comes with a bung and if it does, what material it's made out of...dam eBay sellers ! Well, I have done my research throughly...i'm taking a break - hopefully someone can help cheers |
December 1st, 2010, 10:14 PM | #7 |
just to update, a standard bung is 14mm (top to bottom)...and there is a bung included with the AEM UEGO, it's mild steel...
IF from the top of the thread to the bottom of the sensor is 30mm, and the bung (top to bottom) is 14mm ... 16mm of the sensor will be sticking into the pipe. Any more or less wouldn't be to bad either I think. To me, this seems perfect...absolutely no reason for an extended bung or any reason to think that it will start to have a restrictive effect. In the meantime, it's time to buy buy buy Still the question remains un-answered....where is the best place to make the hole for the O2 sensor. cheers guys |
December 2nd, 2010, 07:32 AM | #8 |
Though WBO2 sensors are typically heated, you do want to mount the sensor as close to the beginning of the exhaust as possible, but still be in the combined stream from both cylinders. That means somewhere just after the two separate pipes join to one. Other than that, just mount it so that it isn't sticking out such that road debris can hit it and so that the wiring doesn't come in contact with moving/hot parts.
December 2nd, 2010, 08:48 PM | #9 |
Cheers, that's what I was thinking...well I shall post back when it's all done (maybe a few days or a week)
cheers guys |
December 2nd, 2010, 10:17 PM | #10 |
MOTM - Sep '18, Feb '16
I put my sensor at the Y where the two pipes come together You have to get the angle right .It will hit the fairing or the engine if you get it wrong. Mine is for a data logger.
December 2nd, 2010, 10:43 PM | #11 |
hmmm ok I see - three questions
You have used an extended bung...is this really necessary ? Would you be able to tell me how much of the sensor sticks into the pipe (e.g 10mm of it sticks in the pipe) from memory ? What sensor are you using ? cheers mate |
December 3rd, 2010, 12:14 PM | #12 |
IC2(SW)
Sensor needs to stick into the exhaust stream for sure
December 3rd, 2010, 12:32 PM | #13 | |
Actually Kerry at Area P says minimal protrusion is best but debatable....
December 3rd, 2010, 01:08 PM | #14 |
IC2(SW)
December 3rd, 2010, 01:34 PM | #15 |
I use the sensor( Bosch) that came with the Innovat lm2 datalogger.the tip bairly sticks into the pipe. It is not like most O2 sensors that breath from the side. This sensor only has holes at the tip.it is no restriction at all.
I do all my tuning on the dyno. There is no better way to set up the bike for racing. But Landspeed racing is real world. I must have the data from th e last run in order to make an intelegent change or no change for the next run |
December 4th, 2010, 12:51 AM | #16 |
hmm I am assuming that the Bosch sensor you use (Racer X) is equivalent if not the same as the one provided with the AEM UEGO (Bosch LSU 4.2)
If you (Racer X) say it barely sticks into the pipe, and your using an extended bung (which I will assume to be 25mm top to bottom ?) ...... then why don't I get an extended bung, take a few mm's off and have the best of both worlds ? I'm still waiting on the AEM UEGO to arrive, once it does I can make measurements and compare a standard bung to an extended bung. HKr1 thanks for the picture, now I see where it should be mounted sorry if it seems like i'm posting to much, just trying to get as much information as possible before I get someone to drill a hole and weld something to my pricey exhaust |
December 11th, 2010, 08:50 PM | #17 |
My O2 wideband bung is in Oz so I should receive it tomorrow (maybe have it welded in that day or the next) - less than 14.7 is rich and more than 14.7 is lean. Maximum power is between 12.5 to 13.3
If you have a wideband sensor or you have dyno'ed your bike please comment on what your A/F ratio is along with jet size, needle position etc cheers |
December 11th, 2010, 10:50 PM | #18 |
Here's why I used an "extended length" bung on my project......
During my build I discovered that I needed to use an "extended length" bung because of the narrow (when compared to an average car's exhaust) diameter of the Area P EX-250 exhaust. If I'd used a standard depth bung the oxygen sensor would have protruded way too far into the relatively narrow exhaust pipe. I didn't do the math to figure out what percent of the Area P exhaust tube would be blocked by the oxygen sensor if I'd used a standard depth bung, but when I was preparing to weld it I mocked up with the standard length bung and the sensor really filled the tube and just looked wrong. With the standard length bung it looked like the oxygen sensor would have had a restricting effect on the exhaust gas flow (possibly even to the point of negating the advantage of installing the Area P in the first place). With the extended length bung only the nose of the sensor peeks out into the flow of gases in the Area P exhaust tube. As far as I can tell, this setup works perfectly. It updates/varies quickly with throttle changes just like it's supposed to do. |
December 12th, 2010, 03:49 AM | #19 |
That's why I chose an extended length bung, if it happens to be to long (it's 25mm SS from Innovate Motorsports) then I can sand it down or cut some off but I think it will be ok
I had to wait longer, but i'd rather do it properly then screw an expensive exhaust system...as for where I will mount it, i'm thinking about mounting it where the cat on a standard system will be (where the 2 pipes come onto a Y like Racer X said). cheers |
December 14th, 2010, 02:00 AM | #20 |
Ok, so I got the extended bung today...screwed the sensor in only hand tight and the tip of the sensor (that looks like \__/ ) pokes out past the end of the bung by about 5mm. Once tightened down it will probably poke out a few more mm but it's perfect.
So, to anyone wondering, an extended length bung (25mm) is what you need. I have an appointment with the exhaust shop tomorrow, i'm mounting it right before the 'end weld' at the end of the Y. When I did a test mock-up the sensor sits in a little pocket at the front of the crankcase, it doesn't hit anything although I didn't have the fairing on (i'll have a look now). I'm confident it will be ok since it's 'behind' the oil cover if that all makes sense I'll wire it up tonight...and post some pics of things tomorrow appreciate all the help guys ! cheers |
December 18th, 2010, 11:55 PM | #21 |
Sorry for no update, got busy, crappy weather etc...
Here are some pictures of where I had the O2 sensor bung welded: As you can see it's just perfect That's a 25mm Stainless Steel bung from Innovate Motorsports, the wires inside the tube are protected and will not melt. The gauge is good quality, only downfall is with a clear windscreen in the day time you cannot see the leds (I have a dark smoke puig waiting to be put on). I wired it up with a 12v 30A relay (overkill) with a fuse inbuilt in the relay. Once I get everything tuned properly i'll take a few more pictures. I plan to customize the gauge by replacing the 3 red 8 digit number displays with blue ones. Maybe even customize my gauge cluster with white/red leds too while i'm at it cheers guys |
December 20th, 2010, 03:09 PM | #22 |
Here's a picture of my 2005's front fairing (removed from the bike).
I mounted my Innovate O2 sensor guage on a little metal bracket that I attached to the turn signal mounting bolt. On the other side you can see my clock (mounted to the other turn signal bolt). This puts them in a very visible position when viewed during normal riding and direct sunlight almost never falls on the guage. My O2 guage is the red-digital model. This mounting postion is also very weather-proof. The clock and the O2 guage stay clean and dry. Since both the O2 guage and the clock aren't "primary" instruments I didn't want to try and mount them up with the tach and speedo. |
February 19th, 2011, 08:34 PM | #23 |
Moroccan Gold Imports
Join Date: Sep 2010 Motorcycle(s): '03 ZX9R, '03 ZX7R & wife's '09 250R Posts: 136
I found this thread while searching about oxygen sensors. I bought the Tyga exhaust which has a bung for the stock ninja 250 FI oxygen sensor. However, my AEM wideband sensor does not fit into the bung. The threading is the same size, but the end of the sensor itself is too big to fit down into the hole. Does anyone know what the size of the stock FI 250 oxygen sensor is? Or whether there are any wideband sensors available that are smaller in diameter at the sensing portion?
[visordown.com] - Caption that The crash bung firm was determined to outdo the compet | Ninjette Newsbot | Motorcycling News | 0 | October 9th, 2014 07:00 AM |
Chopped, welded and cafed. | triumphtriple | 1986 - 2007 Ninja 250R Farkles | 35 | February 2nd, 2014 10:43 PM |
Koso Oil Temp Sensor Adapter & Water Temp Sensor Adapter | StaylorT | 2008 - 2012 Ninja 250R Tech Talk | 10 | January 24th, 2014 12:38 AM |
636 fork conversion- steering stem welded in? | joes280 | 2008 - 2012 Ninja 250R Tech Talk | 15 | April 16th, 2012 07:43 PM |
Where is the water temp sensor? | wild-bill | 2008 - 2012 Ninja 250R Tech Talk | 2 | December 24th, 2010 10:32 PM |
