Old July 28th, 2012, 10:39 AM   #1
oblivion007
"scandal!"
Motorcycle(s): 2011 250R(Crashed 2/26/2014), 09 ER6n
How much extra load can the alternator take?
Anyone looked into this before? I searched, no find and I'm not well versed in the art of re-charging batteries.
oblivion007 is offline   Reply With Quote
Old July 28th, 2012, 03:09 PM   #2
fatestkid
fatestkid's Avatar
Motorcycle(s): ninja 250
I don't have the answer but maybe you can list your application/products that you want to use.
Work smart, play stupid.
fatestkid is offline   Reply With Quote
Old July 28th, 2012, 03:14 PM   #3
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
80w
AFM #676
Supersports are for n00bs
Old July 29th, 2012, 07:58 PM   #4
get a battery tender if there's any question of draining batteries. They're simple and intuitive.
Posted via Mobile Device
Old July 29th, 2012, 09:53 PM   #5
oblivion007
"scandal!"
Home made product, on top of some LED's.
Old July 29th, 2012, 11:40 PM   #6
greg737
Motorcycle(s): -
I can say it has enough to run everything in my do-it-yourself fuel injection system and my heated grips at the same time. (But I'm cheating slightly because I replaced all the brake lights with LEDs)
Old July 30th, 2012, 09:05 AM   #7
g21-30
g21-30's Avatar
http://www.ninjette.org/forums/showthread.php?t=31087
Old July 30th, 2012, 09:07 AM   #8
none because the bike doesnt have an alternator, it has a stator.
Old July 30th, 2012, 09:55 AM   #9
oblivion007
"scandal!"
I also understand it has a rotor which in combination makes an alternator.
http://faq.ninja250.org/wiki/Alternator_Information
Old July 30th, 2012, 09:57 AM   #10
oblivion007
"scandal!"
Originally Posted by Jiggles View Post
80w
0= so you weren't trolling.
- http://www.ninjette.org/forums/showthread.php?t=31087
Old July 30th, 2012, 11:07 AM   #11
i believe them being separate items means it is not what you call an "alternator" you are referring to the output that the stator gives. the rotor is part of the crank shaft. you can replace the stator with a higher output stator. check out places like rickystator.com or all pro electronics. ive used stators and pickup coils (hell even main coils) from them a few times. cant say anything bad about either except maybe rickystator's communication went down a bit after ricky died
Old July 30th, 2012, 12:13 PM   #12
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Whats that?
AFM #676
Old July 30th, 2012, 12:50 PM   #13
Whats that?
it confused me at first as well...
0= is actually supposed to be :O
Old August 1st, 2012, 08:51 PM   #14
Originally Posted by g21-30 View Post
Alternator Wire Gauge indr 2008 - 2012 Ninja 250R Tech Talk 2 June 27th, 2013 07:23 PM
Problem with the alternator or regulator or electrical or all of the above? Gunner 2008 - 2012 Ninja 250R Tech Talk 14 May 26th, 2012 09:37 AM
Troubleshooting Battery/Alternator Help bkh2 2008 - 2012 Ninja 250R Tech Talk 2 February 20th, 2012 11:45 AM
Alternator MiniCog 1986 - 2007 Ninja 250R Tech Talk 3 January 31st, 2011 08:19 PM
Alternator output?? gogiburn 1986 - 2007 Ninja 250R Tech Talk 1 July 25th, 2010 10:41 PM
